Boost behavior of VAG TDI engines, engine code AHF (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Technical Articles
dieselschrauber Post04-06-2003, 11:15
Here are some screenshots showing the turbocharger pressure behavior on the VAG 1.9l TDI engine AHF.
However, the engine was not original, but...
It was upgraded to 101 kW (137 hp) using an auxiliary control unit. Otherwise, only minor flow optimizations were made to the connections between the turbocharger and the intercooler. The charging curve looks similar, but at approximately 2000 minutes-1, the pressure is only about 0.85 bar.
At approximately 3200 minutes-1, the pressure is approximately 0.9 bar, which gradually decreases to 0.7 bar starting at approximately 4100 minutes-1.
Looking back, it can be said that the values may be considered too low, as the regulated boost pressure...
It should be at approximately 0.95 bar.
If someone measures their car and doesn't achieve the values shown in the diagrams, that's not necessarily a problem. The important thing is that the actual boost pressure roughly follows the target value. If the actual boost pressure is more than 15% (~a limit determined by experience) below or above the specified target value, even after several seconds of full load, a defect should be suspected.
In the meantime, ADAC Fürth has performed another power measurement. However, the results are only comparable to a limited extent because the first measurement was performed on a different test bench.
The measured value is now 103 kW (140 hp). This is an increase, but only within the range of measurement accuracy. However, it must be said that during the first measurement, a fan was blowing directly onto the intercooler, while in the new measurement, the fan was positioned relatively far in front of the car and was blowing very weakly; it was not producing more wind than a speed of 40 km/h. Well...
To explain the operation of the boost pressure control system
Maximum boost pressure is approximately 2000min{-1}
The color of the measured values corresponds to the color of the curves, the purple line.
For example, the engine speed is indicated, and at the vertical red line, it's approximately 4100.
min-1 reached.
However, the program has a few bugs regarding the units and labels (it recommends KDataScope, which did not exist at that time).
Mbar are correctly mbar, 'Engine Speed' (revolutions per minute) is correct, but the others are not.
The values represent the target boost pressure, the actual boost pressure, and the duty cycle of the magnetic valve used for boost pressure control.
'Left Cursor' is the green line on the far left, and 'Right Cursor' is the...
at the peak of the yellow curve (actual boost pressure).
This information can be read in the control unit under measurement block 11.
Slow decrease at 2700min-1
Further decrease at 3800min-1
From 3800min-1 it remains constant until 4116min-1, further measurements were not taken.
How the turbocharger pressure regulation works.
during the
TDI with variable turbine geometry
. This description was provided by the forum participant.
I would like to express my sincere thanks to Ulf for his assistance.
Before I give you an important note about measuring boost pressure: Only values obtained after at least 3 seconds of full throttle (held down!) and an engine speed above 2000min-1 are meaningful.
Under idling conditions or at partial load, the boost pressure drops to values slightly above atmospheric pressure.
Measured values for the regulated boost pressure are approximately 0.9-0.95 bar for the 90hp TDIs, and approximately 1 bar for the 110hp TDIs. The higher-performance pump-injector versions of the 1.9-liter engines are significantly more powerful.
  • The engine + turbocharger system has a tendency towards self-destruction:
  • - the turbocharger is driven by the exhaust gas flow.
    - the powered loader increases the fresh air or Blend promotion.
    into the combustion chambers.
    - More mixture in the combustion chambers results in larger...
    Exhaust gas volumes.
    - Larger volumes of exhaust gas drive the turbocharger more forcefully.
    "an . . ."
    - . . . which further increases the fuel-air mixture in the combustion chambers.
    etc.
    Since the exhaust flow is, in a way, the product of the air-fuel mixture and the engine speed,
    represents, this cycle occurs below a certain minimum speed.
    Despite being at full throttle, it doesn't engage, but on the other hand, it's driven by high RPMs.
    especially when operating at partial load.
  • In order to prevent this cycle from causing overload of the charger and / or
    To prevent damage to the engine, the turbocharger's boost pressure must be limited. At the VTG loading station.
    (Variable turbine geometry) is achieved through...
    Adjusting the guide vanes around the gas turbine. This will result in...
    Altering the airflow to the turbine changes the impeller speed, and consequently...
    The charging pressure is affected.
  • The force used to adjust the guide vanes (via...
    A ring mechanism
    in the charger is provided by a membrane dose.
    This is powered by a vacuum, which in turn is generated by a pump located on the engine.
    (which also supplies the power brake booster).
  • Without vacuum, the VTG mechanism is moved into the...
    Rest position where the gas turbine is not supplied with air.
    is being. As the vacuum pressure increases, the guide vanes direct an increasing amount of exhaust gases.
    onto the gas turbine, and the boost pressure increases with sufficient exhaust gas flow.
  • To limit or The boost pressure is continuously regulated by the engine control unit.
    measured. If the pressure exceeds the target value specified by the characteristic curves,
    The engine control unit then electrically actuates a control valve (pressure converter valve).
    which reduces the vacuum in the VTG membrane cell, thereby decreasing the charging pressure.
    sinks.
  • The electric pressure-reducing valve has inlets for the vacuum.
    the motor pump and the (atmospheric) external pressure, as well as a...
    Starting point. It can not only be opened and closed, but also...
    depending on the control signal provided by.
    the engine computer (duty cycle between voltage on and
    Voltage drops can also cause intermediate states to occur in a very rapid sequence.
    so that its output is any pressure value between atmospheric pressure and vacuum pressure.
    mixed and thus the VTG mechanism can be continuously adjusted.
    Without tax pressure, the outside pressure is present at the outlet of the valve.
    In the event of a power failure affecting the pressure-regulating valve, the VTG (Variable Turbine Geometry) mechanism remains operational.
    in its resting position, and no boost pressure can be built up.
  • Since the loader requires quick response (small turbines with low
    The turbine speed would decrease significantly in every case.
    The VTG mechanism adjusts almost instantaneously and usually travels too far upwards.
    or, conversely, decrease, which would then require further adjustments.
    etc.
  • Such a fluctuating boost pressure would result in a rocking
    Make acceleration noticeable.
    To rule out such phenomena, the boost pressure control function was...
    The engine control unit was designed with a relatively slow response time through software. This leads to...
    with rapidly increasing boost pressure, leading to a brief exceeding of the...
    Set point values, until the control system has adjusted the pressure regulating valve to the point where...
    The boost pressure drops back to the target value.
    Near the target value, the regulation is also more careful.
    as in cases of significant deviations. This is how it works when all components are functioning normally.
    Even with abrupt accelerator pedal movements, the turbocharger pressure regulation can oscillate.
    certainly avoidable.
  • Below the target boost pressure, the pressure control valve operates depending on...
    opened only as far as necessary so that, in the event of a sudden...
    Accelerating the boost pressure until the control system intervenes should not cause it to shoot up excessively.
    However, under sudden full acceleration, the turbocharger pressure can increase from approximately 1,000...
    min-1 in 1st gear due to the rapidly increasing engine speed for fractions of a second.
    increase to approximately 1.3 bar (target: about 1 bar) before it rises within approximately...
    The system is adjusted to reach the target value in 2 seconds.
  • In the same maneuver, starting from approximately 1,500 min-1, the peak value reaches only about 1.2 bar; at higher...
    Gears have even fewer (measured due to the slower increase in rotational speed.
    on a 1997 AFN engine).
  • Shortening the VTG linkage only increases the aforementioned.
    Pressure peaks until the control system intervenes, against which the level of the regulated pressure is set.
    The boost pressure will not be changed (as long as a regulation is still possible).
    is), because the engine computer simply controls the pressure relief valve with a different,
    appropriate duty cycle to achieve.
  • Excessive pressure spikes can, in some cases, lead to charger damage (over-speeding).
    can lead to hose connections slipping in the intake passages, the intercooler bursting, or other damage.
    If the boost pressure, for example, cannot be reduced to the target value due to a blocked VTG mechanism or an excessively shortened VTG linkage, the engine control unit reduces the fuel injection quantity in order to lower the boost pressure in this way.
    At the same time, the engine power is significantly reduced.
 Ladedruck Sollwert im Motorsteuergerät.
 File size:  86.05 KB
 Viewed:  9205 times
Translated on 04-07-2026, 12:49.
Ratings - Boost behavior of VAG TDI engines, engine code AHF
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 4 - View ratings
No new posts Faulty Load Pressure Control Engine Identifier BRE Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Boost Pressure: Normal or Faulty? On-Board Diagnostics (OBD)
No new posts Boost behavior during throttle lift-off above 3000 RPM Diesel Engine Technology
No new posts AFF Engine Code: Meaning & Identification Diesel Engine Technology
No new posts Engine Code: Find Your Car's Engine Type Diesel Engine Technology
