Air Vents: Low Performance / Smoke Reduction
Go to page: 1, 2, 3, 4  Next
Gilliearnie
2009 Volkswagen Polo
Registered VCDS User
Post09-08-2012, 6:59    Subject: Air Vents: Low Performance / Smoke Reduction Quote
Hello.
I'm having a small problem with my Passat 3BG Variant.
The engine is an AVF 96kW series engine with approximately 230,000 kilometers, paired with a TT5 EYF transmission. (The timing belt was replaced at 176,000 kilometers).
I'm experiencing an inexplicable lack of performance; it feels like I'm driving around with the handbrake on. (Which is now released icon_cool.gif).
I then logged a test drive (MWB 8, 10, 11) and discovered that the soot limit constantly restricts the fuel injection.
That's probably the reason for the feeling of the handbrake being engaged.
When the air mass rises, the soot limit also increases, which, based on my extensive reading of technical articles, suggests a lack of air.
But I'm not entirely sure about that.
I already replaced the LMM (Mass Air Flow sensor) because the old one was showing a lower air mass reading (max. 600mg/H).
Yesterday, I also checked the basic settings for the VTG (Variable Turbine Geometry) and AGR (Abgasrückführung) systems (in the engine control unit).
The VTG (variable turbine geometry) adjusted its position, the engine speed increased to 1400 RPM, and the boost pressure fluctuated from 990 mbar to 1170 mbar.
The boost pressure actually follows the target value on the curve, but I'm not entirely sure if that's correct / if it's regulating quickly enough.
The VTG rod moved up and down quite quickly and reached its end position without any noticeable jolting. (It's hard to see, but after raising and lowering it about 10 times, I was sure of it.)
This morning, I opened the air filter housing and found quite a few insects inside the air filter. It was replaced during the last inspection, about 24,000 km ago.
I immediately exchanged it and put everything back together.
Attached are three logs, one from April, which looks quite messy because I didn't yet know how to properly create a log.
The other two show the power loss before and after the filter change.
However, the log from April shows that the turbocharger builds boost pressure more effectively and reaches the target value very quickly.
Should I perhaps remove the turbocharger and clean the variable geometry turbine (VTG)?
Here's everything I've done to the engine since April:
- AGR cleaned.
- Intake manifold removed.
- Vacuum hoses for EGR and turbocharger replaced.
- LMM replaced.
- Air filter replaced.
The inspection is due soon (in 2000 km). The diesel filter should also be replaced then. However, the missing mass airflow sensor shouldn't be related to the diesel filter.
Do you have any more ideas or suggestions that could help me regain my previous level of performance?
Do you agree with me that I seem to have a problem with air mass?
Thank you for your suggestions and feedback!
20120809 Neuer Luftfilter.xls
 Mit Leistungsmangel nach Luftfilterwechsel
 File name:  20120809 Neuer Luftfilter.xls
 File size:  79.5 KB
 Downloaded:  644 times
20120808MW008-010-011_4Gang Vollgas.xls
 Mit Leistungsmangel vor Luftfilterwechsel
 File name:  20120808MW008-010-011_4Gang Vollgas.xls
 File size:  43.5 KB
 Downloaded:  1289 times
20120423_Leistungsmessfahrt.xls
 Messfahrt im April, da war noch (für Mich) Alles i.O.
 File name:  20120423_Leistungsmessfahrt.xls
 File size:  71.5 KB
 Downloaded:  673 times
Translated on 31-10-2026, 14:34.
Gilliearnie
Post09-08-2012, 9:35    Subject: Air Vents: Low Performance / Smoke Reduction Quote
Hello.
I would like to re-enter my serial number, but I am unable to do so.
All I see is the following:
You can ask questions using your support key (e.g., the German VCDS serial number).
You can find the VCDS serial number on the 'About...' screen within the VCDS software. For GS-911 or Bavarian Technic, the serial number needs to be entered on the diagnostic cable itself.
You can purchase a corresponding diagnostic system with a support key, or just the support key itself, here.
But there's no way to enter the number.
Und eine PN konnte ich leider auch nicht zurückschreiben... Sorry!
EDIT:
I've updated the number; it should work now!
VW Caddy Maxi, 1,9l TDI BLS 6- Gang DSG
VW Polo 1,4l TDI BMS
Translated on 31-10-2026, 14:38.
Post09-08-2012, 11:14    Subject: Air Vents: Low Performance / Smoke Reduction Quote
ok, thank you.
Since the target pressure is being reached in your table, but the air mass is slightly too low, there are two possible causes:
- Air mass flow is too low in reality due to a bottleneck, e.g., a faulty silencer on the exhaust, a tilted catalytic converter ceramic core, a defective/stuck EGR valve, a piece of cloth sucked into the intercooler, etc.
- Mass airflow sensor defective.
If you experience excessive exhaust smoke (visible as a slight dark plume in the rearview mirror) at around 4000 rpm, with the boost pressure set and the accelerator pedal fully depressed, then there is likely a problem with the mass airflow sensor.
If the exhaust appears clean, it's likely that the air mass measurement is simply too low, although it's actually okay. -> Is the correct air mass sensor installed? Are +5V reaching the power supply of the air mass sensor? Are the cables/connectors to the air mass sensor corroded?
When it comes to air mass sensors, it's best to use original parts. The measuring element itself (which is inserted into the housing with just two Torx screws) likely costs around 80 EUR.
See also:
/viewtopic.php?t=3347&highlight=air mass meter
Translated on 31-10-2026, 14:41.
Gilliearnie
Post09-08-2012, 11:49    Subject: Air Vents: Low Performance / Smoke Reduction Quote
Okay, so far, it sounds like what I expected.
How can I check if the exhaust system has any leaks?
Because, unfortunately, a magnifying glass or something similar is not available. icon_lol.gif
So, does that mean taking it apart and looking inside? Or can you tell by tapping on the outside if something is rattling inside?
It is very unlikely that a cloth was sucked in.
I'm not ruling it out just yet.
The AGR (Automatic Gearbox Restriction) seems to be defective or deactivated.
During the initial positioning phase of the AGR, the air mass does not change at all.
I'll pay attention to the smoke again on my way back today.
I'm going to take the measurements again shortly. I also reprinted the technical article.
I had already read it.
Thanks for the information. I'll report my measurement results tonight.
Florian
Translated on 31-10-2026, 14:44.
Post09-08-2012, 12:12    Subject: Air Vents: Low Performance / Smoke Reduction Quote
dieselschrauber wrote:
... can be caused by two things:
I would actually rule out a piece of cloth in the intake manifold, because then the restriction would be located before the lambda sensor. However, a discrepancy in the mass airflow-lambda sensor relationship can, in my opinion, only arise systemically if the restriction is located behind the lambda sensor.
Another possible cause: Deposits from the EGR system in the intake manifold (including the valves!), which were not removed during the EGR cleaning mentioned in the post.
Translated on 31-10-2026, 14:46.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post09-08-2012, 12:30    Subject: Air Vents: Low Performance / Smoke Reduction Quote
Best regards, Florian
Carefully loosen the flange connecting the turbocharger to the exhaust pipe, and check how much exhaust is escaping.
reflexsilber met.
Translated on 31-10-2026, 14:47.
Post09-08-2012, 12:35    Subject: Air Vents: Low Performance / Smoke Reduction Quote
RedR32 wrote:
Carefully loosen the flange from the turbocharger to the exhaust manifold, and check how much exhaust is escaping.
It probably won't be very helpful if, like me, you don't have a sense of what's normal.
Tapping the exhaust pipe can quickly reveal whether the catalytic converter has dissolved or is in the process of dissolving.
Translated on 31-10-2026, 14:48.
Post09-08-2012, 13:07    Subject: Air Vents: Low Performance / Smoke Reduction Quote
Possibly, carefully loosen the flange from the turbo to the exhaust pipe,
and check how strongly it's blowing out. I agree with Matthias.
This method is only practical on a dynamometer, but even at full throttle, only a fraction of the exhaust flow rate achieved during on-road full acceleration is reached. Therefore, a potential exhaust restriction that significantly affects maximum power (Pmax) may not be clearly identifiable during dynamometer tests.
I would rather compare the behavior of the LD-TV (likely referring to a load detection system) in the MWB11 with vehicles that have functioning, motor-like components, because if there are restrictions on the exhaust side, the VTG (variable geometry turbine) needs to be closed further to achieve the desired LD value.
Unfortunately, this testing capability is compromised by various potential sources of error, such as misaligned VTG vanes, minor defects in the engine's pneumatic components (which do not lead to a complete system failure), and ultimately, the already reduced exhaust flow, as is the case here because the engine is running in a degraded state.
Based on my initial assessment, a 60% TV-Log value at Pmax doesn't necessarily indicate a clear problem originating from the exhaust side. Therefore, I would first thoroughly inspect the entire area between the LD sensor and the combustion chambers for any potential restrictions.
Translated on 31-10-2026, 14:50.
... there can be 2 things that are the cause:
I would actually rule out a piece of cloth in the air intake manifold, because then the restriction would be located before the lambda sensor. However, a discrepancy in the mass airflow-lambda sensor relationship can, in my opinion, only arise systemically if the restriction is located behind the lambda sensor.
Another possible cause: AGR soot deposits in the intake manifold (including the valves!), which were not removed during the AGR cleaning mentioned in the post.
Is that icon_wink.gif?
Translated on 31-10-2026, 14:52.
Gilliearnie
Post09-08-2012, 16:36    Subject: Air Vents: Low Performance / Smoke Reduction Quote
Okay.
So, I checked the voltages earlier. (Engine off, ignition on), and I had readings between 2 and 3 volts, and between 4 and 2 volts.
I'll check the printer hoses tonight or tomorrow night.
Sure, I'll translate the text and then perform the tapping test.
**Translation:**
"Please translate the following text from German to English. Provide only the translation, no explanations. Also, please perform the tapping test."
Best regards, Florian.
Translated on 31-10-2026, 14:54.
RedR32
Avatar-RedR32
Post09-08-2012, 20:14    Subject: Air Vents: Low Performance / Smoke Reduction Quote
Here's the translation:
"Or maybe a quick trip with a loose flange, using a MWB log. Just tapping it doesn't tell the whole story; you won't notice broken catalytic converter pieces that are stuck in the pipe."
reflexsilber met.
Translated on 31-10-2026, 14:55.
Post10-08-2012, 5:28    Subject: Air Vents: Low Performance / Smoke Reduction Quote
RedR32 wrote:
Or a quick trip with a loosened flange, using MWB logging. Just tapping doesn't tell the whole story; you won't notice broken catalytic converter pieces that are stuck in front of the pipe.
OK, that's how you could hide bottlenecks in the AgA (agricultural area).
What I also noticed in Log 4: The engine never comes out of the "haze" or "murk."
However, I believe that the usual bottlenecks in the gas passages only become more pronounced as the maximum pressure (Pmax) increases, meaning that the engine, for example, only starts to exhibit misfires at around 3000 rpm.
Here, the LuMa/LD trend seems to be completely shifted downwards in parallel with the normal logs - as if, for example, someone had connected a diode in the LMM signal line to reduce the AGR rate icon_eek.gif.
Translated on 31-10-2026, 14:56.
Karma: +1354 / -0   Thank you, like it!
Post10-08-2012, 7:15    Subject: Air Vents: Low Performance / Smoke Reduction Quote
Does the AGR
completely close at all? I would like to check that mechanically.
The AGR } definitely seems to be defective / deactivated.
During the initial positioning movement of the AGR, the air mass does not change at all.}
That doesn't prove anything; it merely shifts the suspicion in the same direction. If the AGR (Abgasrückführung - exhaust gas recirculation) valve is open, not enough fresh air is drawn in despite the boost pressure, and the engine remains in the soot reduction mode.
Translated on 31-10-2026, 14:57.
Gilliearnie
Post10-08-2012, 8:17    Subject: Air Vents: Low Performance / Smoke Reduction Quote
Good morning.
Okay, I disconnected the boost hose and the vacuum hose yesterday.
There were no bottlenecks to be found, only oil stains on the walls.
The AGR valve was also clogged, so I cleaned it with brake cleaner.
I also removed the intake manifold, which was a pain, and cleaned it.
Die sah recht gut aus, 1- 2mm Ruß direkt am Eingang, mehr nicht. Als es sich aufteilte sah man (Mit Spiegel) das Metall durchschimmern. So, it was just oil.
I also checked the valves, and there was nothing there but oil.
The AGR (Abgas Rückführungssystem) is completely blocked, and there was a greenish, greasy sludge stuck under the valve seat (on the exhaust side). I have no idea where that could have come from...
The AGR is still moving.
Could it be that the vacuum valve is defective and constantly being activated?
Okay, now about the turbocharger: I didn't remove it, but I did turn the turbine.
An einer stelle geht es etwas schwergängig... Turbo bald im Arsch? Damage from improper storage?
Okay, in my opinion, it spins up to 120,000 rpm, right? And shouldn't it actually give a little nudge and then spin for 2-3 revolutions on its own?
But with that one... it always got stuck on one side, it was a bit awkward.
Damn it, dwt.
I'll disconnect the exhaust sometime tomorrow or Monday, depending on when I have time, and then log the data again.
Now, it's my youngest child's birthday icon_smile.gif first.
Best regards and have a nice weekend! Florian.
Translated on 31-10-2026, 15:00.
Post10-08-2012, 8:25    Subject: Air Vents: Low Performance / Smoke Reduction Quote
So, IMHO, it spins up to 120,000 rpm, right? And you should actually give it a little nudge, and then it should spin for 2-3 revolutions on its own, right?
That's bad and not normal. The loader shaft needs to rotate easily and without any resistance.
Theoretically, it is conceivable that due to increased friction, the VTG (variable turbine geometry) might need to be adjusted further to achieve the desired pressure, which would result in a lower air mass flow. However, in practice, this "increased friction" is unlikely to be significant, as the frictional heat generated would long ago have completely destroyed the bearing.
I could imagine that the difficulty in rotating the loader shaft was caused by carbon deposits resulting from overheating, which in turn was caused by a blocked exhaust system.
Have you checked the catalytic converter and muffler? Have you already done a test drive with the exhaust pipe loosely attached to the turbocharger with a 3mm gap?
Translated on 31-10-2026, 15:03.
Post10-08-2012, 9:05    Subject: Air Vents: Low Performance / Smoke Reduction Quote
Gilliearnie wrote:
The EGR is completely blocked, and there was greenish, greasy sludge stuck under the valve seat (on the exhaust side). I have no idea where that could have come from...
How is it blocked? With a solid, non-perforated plug?
Could it perhaps be that the vacuum valve is defective and constantly being activated?
If you're referring to the silver plate: the valve is normally closed by a spring and opened by pulsed vacuum pressure.
If you're referring to the solenoid valve: it can theoretically get stuck in the open position, but as far as I know, this happens very rarely, if ever.
Now, regarding the turbo, I didn't remove it, but I did turn the turbine.
But with that thing... it always got stuck on one side, it was a bit jerky...
You probably think of ball bearings with the expected lag. However, the GT1749 turbochargers have plain bearings, and in those, the engine oil immediately dampens any initial momentum. The feeling when rotating is similar to a spoon handle in clear honey. At hand-cranked speeds, the shaft might rotate a maximum of 1 revolution.
When the wave is tilted, it becomes increasingly difficult to turn. However, a noticeable resistance to turning, always in the same position of the wave, is not normal, as Rainer pointed out.
Translated on 31-10-2026, 15:06.
No new posts Document about lack of power in A4, 2.5 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Performance issues, black smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku V6 TDI AKE/AYM - Jerking and Lack of Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Low Smoke Suppression: Causes & Solutions On-Board Diagnostics (OBD)
No new posts Smoke Limitation Above Target Value On-Board Diagnostics (OBD)
No new posts Injection amount exceeds smoke reduction limit Diesel Engine Technology
No new posts G4 ALH: Troubleshooting Performance Issues Upload
