Skoda Fabia 1.2 BME engine misfire
georgmech
Post27-02-2020, 19:30    Subject: Skoda Fabia 1.2 BME engine misfire Quote
The Skoda Fabia has an engine check light and an ASR (traction control) light that occasionally illuminate. This is followed by a loss of power and misfires in cylinder 3. Ignition coil and spark plugs have been replaced, compression is good.
Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Back to top Profile PM Email
Karma: +1354 / -0   Thank you, like it!
Post27-02-2020, 20:07    Subject: Skoda Fabia 1.2 BME engine misfire Quote
Hi DIYers,
Could you also provide us with more data, for example, about the "Autoscan" feature?
The glass ball is still dark.
Karma: +647 / -0   Thank you, like it!
Post27-02-2020, 20:47    Subject: Skoda Fabia 1.2 BME engine misfire Quote
Is the problem still occurring with the third cylinder?
Perform the pressure loss test, but first, set the Autoscan as described.
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Superb Estate (Wagon), 2012, Tailgate Actuator Defe... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASZ Fabia 131PD at 170HP/400Nm, Dyno Run Upload
No new posts ASZ Fabia 131PD @ 170hp 400Nm Upload
No new posts ASZ Fabia RS 131PD Intercooler Temperature Issue - Log Fi... Upload
No new posts ASZ Fabia RS 131PD Intake Air Temperature Problem Log Fil... Upload
