Lubricate hinges and sliding rails
vag-driver
Post19-08-2019, 7:10    Subject: Lubricate hinges and sliding rails Quote
What type of grease do you use to lubricate door hinges and the mechanisms of panoramic sunroofs? VW reportedly uses a special grease for panoramic sunroofs to prevent sticking and hardening.
Andreas
klahaui
Avatar-klahaui
2019 Volkswagen Golf
dieselschrauber likes this.
Post20-08-2019, 8:48    Subject: Lubricate hinges and sliding rails Quote
Hey,
For all hinges, I use a Teflon spray from Makra.
With the panoramic sunroof, I can only guess that you need to use a specific type of grease. The rails should be cleaned thoroughly and then re-lubricated.
I had several customers who, due to lack of or improper maintenance, complained that the sunroof was no longer opening and closing correctly.
vag-driver
Post20-08-2019, 9:38    Subject: Lubricate hinges and sliding rails Quote
klahaui wrote:
With the panoramic sunroof, I can only guess that you should use a specific type of grease; the rails will be cleaned thoroughly and then re-lubricated.
Can I buy the oil from VW? How and with what is the cleaning performed?
Andreas
klahaui
Avatar-klahaui
Post20-08-2019, 18:07    Subject: Lubricate hinges and sliding rails Quote
There are original part numbers for the cleaner and lubricant, but unfortunately, it's been too long for me to provide you with more specific information.
Karma: +1357 / -0   Thank you, like it!
Post20-08-2019, 18:50    Subject: Lubricate hinges and sliding rails Quote
on the A4 8K
VAS 6764 Cleaning and degreasing tool.
Cleaning solution for seal D009 401 04.
Grease for seal G 052 141 A2.
Lubricant paste (cartridge) for rails G 060 751 A2.
vag-driver
Post21-08-2019, 7:17    Subject: Lubricate hinges and sliding rails Quote
Herbert wrote:
on the A4 8K
I have now also found this information online. However, for my Sharan, I need the grease fitting VAS6621, but it is not readily available. And without this scraper, cleaning wouldn't make any sense.
Andreas
Post21-08-2019, 20:58    Subject: Lubricate hinges and sliding rails Quote
And why don't you order it through Erwin?
vag-driver
Post22-08-2019, 6:20    Subject: Lubricate hinges and sliding rails Quote
Do they also sell to private individuals?
Andreas
No new posts Cable-operated shifting (and other plastics) "bulge" or "... Transmission, Chassis, Body & Interior
