| Tuning comparison: Chip vs. Powerbox | ||||||||||||
| ulf |
?![]() He should provide information about the background and risks of common tuning approaches for TDIs, so that decisions about chip tuning or box tuning (or even opting out of tuning altogether) are not solely based on typical sources of information such as advertising, casual conversations, internet forums, and overly enthusiastic test reports without long-term evaluations. Regarding statements about chip tuning: The author is not a professional tuner and is merely providing their limited basic knowledge and some information from the tuning scene in order to shed some light on the mystery of chip tuning in a way that is hopefully understandable to a wider audience. Constructive criticism, corrections, and additions are always welcome -> please post in the forum or send a private message. Modern turbodiesel engines offer tuning possibilities that earlier generations of drivers could only dream of: within just a few minutes, performance gains of 20% or more can be achieved through electronic modifications rather than mechanical ones. In this process, the design margins of the engine, clutch, and transmission are used up to a greater or lesser extent – or, in some cases, even exceeded. The "natural limits" of TDI tuning are fundamentally: 1) With significantly more torque, the transmission becomes overloaded and wears out prematurely, or the clutch will slip sooner or later during full acceleration. 2) For significantly increased maximum performance (the torque is generally considerably below the maximum at approximately 2000 - 2500 rpm, i.e. (While the transmission and clutch are less likely to be affected), the fuel injectors and turbocharger are often too small, as explained below. In the market, two main types of electronic tuning methods have become established: chip tuning and tuning boxes, the latter also known as power boxes or power plugs. Regardless of the method, a noticeable increase in the performance of a healthy engine always requires an increase in the fuel injection volume. The (engine speed-dependent) injection pressure in VP or PD-TDI engines cannot be changed without complex mechanical modifications. Therefore, increasing the quantity injected can only be achieved electronically by extending the injection duration. TDIs are typically operated with a high excess of air in their standard configuration for emissions-related reasons. A theoretically complete combustion requires a mass ratio of approximately 14.5 parts of air to 1 part of diesel – and in practice, even this ratio would cause extreme soot formation due to the non-homogeneous mixing and combustion. To minimize visible soot, the standard air excess at full throttle varies depending on the engine control unit (ECU) from approximately 10% (at low RPM) to 40%; at partial load and idle, it is significantly higher. A noticeable increase in performance can initially be achieved simply by extending the injection times, up to the point where the factory-set excess air is almost completely consumed, which is indicated by a significant increase in soot emissions. This is the simplest approach to tuning TDIs; further increases in quantity will no longer result in a noticeable increase in performance, but only more soot. If you want even more power, you also need to get more air into the cylinders. In the field of electronic tuning, this means an increase in boost pressure, which in turn has further consequences. Therefore, let's start with some words about the most important, fundamental goal conflicts in TDI tuning. 1. Extending the injection duration within the working cycle, in addition to increasing the Russian content, also raises exhaust gas temperatures. Overheating can cause damage, particularly to the delicate mechanisms of the VTG turbochargers. In extreme cases, the burning fuel injection jets can strike the upper, constricted edge of the combustion chamber, causing the metal to melt, which can lead to severe engine damage. The issue of piston bowl melting is less pronounced in pre-compression (PD) engines due to the higher flow rates (resulting in shorter injection times despite larger volumes), compared to direct injection (DI) engines. However, excessively high combustion chamber temperatures can still occur, potentially leading to premature cracks and holes in the piston, etc. With heavily modified PD (Plasma Display) units, there is a greater risk of the PD elements exploding. Reason: The injection pressure not only increases with engine speed, but also with the duration of the injection process. Therefore, it is highest when large amounts of fuel are injected at high engine speeds, and specifically just before the injector closes (PDE). Therefore, if the injection quantity is not only significantly increased but also maintained at a high level even beyond 4000 rpm, the pressure in the pre-combustion chambers can exceed the bursting limit, causing the nozzle tip to break off. If the start of injection is delayed further towards the compression stroke, soot values and exhaust gas temperatures decrease, and the efficiency can increase slightly (resulting in a reduction in fuel consumption related to power output). However, the pressures at the top of the engine are also increasing significantly: the cylinder head can be lifted from the engine block, the cylinder head bolts are overstressed, and the cylinder head gasket is damaged. A targeted adjustment of the injection timing can only be achieved through chip tuning. 3. Increasing the boost pressure reduces the proportion of unburnt fuel, creating room for further increases in injection amounts, but the peak pressures inside the engine also increase (which poses a risk to the cylinder head gasket, see item 3). Unfortunately, modern TDI turbochargers are very specifically tailored to the respective performance level: to minimize turbo lag as much as possible, the turbocharger is designed in such a way that it is almost too small for the maximum power output (Pmax) of the (unmodified!) engine. Therefore, at high speeds, there are hardly any usable reserves for increasing boost pressure, and consequently, for increasing the airflow. What does a tuning box do? "Currently available power boxes generally only increase the fuel injection volume. Injection timing and boost pressure remain unchanged (except possibly for..." Pressure increases can be caused by miscalibration of the control loop, see below. Therefore, as the effectiveness increases, you quickly reach the problem areas of high exhaust temperatures and excessive soot formation. Basically, the engine control unit (ECU) doesn't detect the increased power output because it believes that the normal amount of diesel is still being injected. Characteristic features of such operating conditions include, for example, a reduced average consumption reading compared to the amount of fuel added, or a lower instantaneous consumption reading at a constant speed x on a familiar route. When the emergency mode is active (when performance is intentionally reduced due to detected faults), the device usually continues to operate, thereby diminishing the protective effect of the emergency mode. The principle of operation for box tuning is described in the technical article about 10c tuning; the simplest boxes actually contain only a resistor or a potentiometer, which are used to manipulate the quantity signal from the VP37 pump or the temperature signal from the diesel sensor in PD engines. PD-Power plugs falsely report a diesel temperature at the maximum of the measurement range to the MSG (Motor Steuergerät), thereby constantly triggering the longest possible injection duration at full throttle. The warmer the diesel engine gets, the smaller the difference becomes between the actual temperature and the temperature displayed, and therefore, as the engine gets warmer, the power plugs become increasingly less effective. More complex systems incorporate parameters such as air mass, boost pressure, and/or throttle position to more accurately adjust the sensor signal distortion (and thus the fuel increase) based on the specific situation, thereby improving exhaust emissions and driving comfort. More advanced "active" PD (Power Distribution) boxes process the signals from the MSG (Motor Control System) to obtain information about motor load and speed. After receiving the closing pulse from the MSG, they extend the opening current of the PD elements using their own power electronics. They are recognizable by their numerous electrical connections, which must be connected to the cable harness of the Power Distribution Units (PDUs), while the primitive diesel temperature "fake" boxes are simply plugged into the 2-pin cable leading to the diesel temperature sensor. Due to the complexity of the processes in the PDE circuit and the required precision in the time domain, the better PD boxes are based on microcontrollers and, in practice, often exhibit a delayed adjustment of engine power when there are rapid throttle movements, due to the real-time calculations involved in determining the multiple injection amounts. Furthermore, the opening duration of the injectors prescribed by the MSG (Maintenance Steering Group) does not provide a truly precise indication of the actual amount (better: mass) of fuel injected, because, especially in PD (common rail) engines, the actual opening duration varies significantly with the diesel temperature, even when the same amount of fuel is required. However, this value is not currently used as an input parameter by the active PD boxes that are known. A specific opening duration for the PDE (common rail direct injection) injector can either mean full power at low diesel temperatures, or the upper partial load range at higher diesel temperatures. However, a PDE processor module has no way of distinguishing between these two scenarios without information about the diesel temperature. To compete with the potential of chip tuning, many tuning boxes increase the fuel injection volume to a point where noticeable soot is produced, with all the negative consequences mentioned above. What does a chip tuner do? Basically, all of the above-mentioned options are available to him. Options (numbered 1 to 3) are still open. How skillfully he uses them depends solely on his knowledge and his ambition to deliver good tuning software. Most chip tuners significantly increase the turbocharger boost pressure in order to extract every last possible horsepower, and also to demonstrate their superiority over tuning boxes. Increasing boost pressure, especially in the Pmax range, requires a significantly higher power output from the turbocharger to force additional air through the compressor's restricted areas. Increasing the turbocharger's boost pressure to provide more power for the loader can only be achieved by increasing the exhaust back pressure (by further closing the wastegate/variable geometry turbine, or by not opening it sufficiently with increased fuel injection). In other words, from the exhaust side, increasing the boost pressure acts like a partial blockage, which is not conducive to achieving the desired increase in engine power. Conclusion: When increasing the boost pressure in the Pmax range of modern TDIs, the standard turbocharger sometimes only struggles against the increased exhaust backpressure it itself creates. This significantly increases the stress on the materials (exhaust and intake air temperatures, turbocharger speeds), while the actual increase in air mass is relatively small. Therefore, higher fuel injection volumes are converted into increased power less efficiently than with an engine that has a suitably larger turbocharger installed. So, if chip tuning aims for the next higher factory performance level, the fuel injection amount must be significantly increased beyond the corresponding factory setting in order to achieve the normal performance of the more powerful factory engine. After the tuning, a significant number of horsepower are lost due to excessive friction around the (now undersized) turbocharger, for example: In the mid-range speed range, TDI turbochargers, on the other hand, have significantly greater reserves, which many tuners exploit to achieve substantial torque increases - to the detriment of the clutch, transmission, and drive shafts... Increased fuel injection amounts (whether from a power box or chip tuning) fundamentally disrupt the turbocharger pressure control system because the turbocharger receives more power than intended in the programming. As a result, the turbocharger pressure increases to varying degrees, even if the turbocharger pressure map has not been changed. With a power box, the customer is generally helpless in the face of this phenomenon, while chip tuning offers the possibility of adjusting the control parameters to the increased power output, allowing for clean control behavior until the system reaches its mechanical limit (fully open wastegate or). (VTG) is the way to go. From that point on, it becomes dangerous because the exhaust gas volume flow is too high for the turbine housing, meaning the boost pressure can no longer be controlled, except in emergency mode or by shutting off the gas supply. Conclusion: No matter how much tuning is done, and whatever the tuners tell potential customers to reassure them, higher stresses always occur somewhere, which fundamentally reduce the lifespan of the relevant parts, as long as and whenever the extra power is used. In particular, no customer who has had their engine electronically tuned should fall into the false belief that their modified engine would still be as capable of sustained high-speed operation as the original, stock engine. Generally speaking, you can compare engine tuning (often referred to as "chiptuning") to something like this: :arrow:The effect of a box tuning on the engine tuning is roughly equivalent to shortening lowering springs in the chassis area. The car sits lower, and the suspension becomes stiffer, but a well-balanced tuning chassis with truly matching shock absorbers, stabilizer bars, wheels, and tires cannot simply be created in this way. Or, from the customer's perspective: A customer must trust a chip tuner much more often: - that he correctly adjusts the increase in fuel injection volume. - that he correctly regulates the increase in charging pressure. - that he correctly adjusts the timing of the injection start. - to ensure that the motor is not thermally overloaded. - so that he doesn't mess around with the engine software. Chip tuners who justify this trust, of course, provide engine tuning that is far superior to any generic box. Unfortunately, you won't find them on every corner - nor will you find "good" power boxes readily available. The amount of effort required from the factory, for example, to achieve 30 horsepower and 20 Nm more while maintaining roughly the same level of stability, can be seen by comparing the Ibiza Cupra (BPX) with the ASZ engine in the Ibiza: Although both engine blocks are essentially the same in terms of their basic design (pistons, crankshaft, bearings, cylinder head, valves, PDE, clutch, etc.), the BPX is upgraded with the following features, among others: -> to a larger water pump. -> a more powerful charger. -> extended intake passages. -> a large front-mounted intercooler that reduces the intake air temperature in the maximum power range by approximately 30K compared to the charge air cooler located near the wheel arch of the ASZ engine, despite an increase of 0.2 bar in boost pressure. Simply increasing the larger LLK (Low-Pressure Combustion) of the BPX would improve cylinder filling in the Pmax range by approximately 9% without any increase in LD (Lean Definition); conversely, the higher LD only provides an additional gain of about 8%. Overall, the cylinder filling of the BPX in the Pmax range is not only increased by the sum of improved intercooling and higher boost pressure (approximately 17%), but the larger turbocharger also generates less exhaust back pressure. This means less residual exhaust remains in the cylinder, allowing for a slightly greater amount of fresh air to enter. In the ASZ (turbocharger) with the relatively small air intake manifold, the air-to-liquid temperature (LLT) increases significantly with a boost pressure (LD) increase of only 0.2 bar. This, combined with the bottleneck issue of the small serial loader (see above, conflict of objectives No. 4), means that instead of the expected 8% increase in air mass flow, only 5 to 6% is actually achieved. However, many ASZs that have only been chip-tuned have to accept this limitation. The fuel injection volume is increased by approximately 23% for the typical ASZ chip tuning power range of 160 hp. Even with the increased boost pressure, this still results in a roughly 17% increase in the fuel consumption at full load. This inevitably results in significantly worse exhaust emissions and higher thermal loads compared to the BPX model. However, experience shows that the engines generally cope with this material stress, as long as the driver has a feel for the accelerator pedal and the chip tuning was developed with careful consideration rather than a brute-force approach. The safest approach when modifying the engine software for chip tuning is to adjust the fuel injection volume and turbocharger boost pressure to levels (closer to the original specifications) that reduce combustion chamber and exhaust temperatures to a still acceptable range, especially at high engine speeds. Material stress in boxing and chip tuning As described above, the soot levels, combustion temperatures, and exhaust temperatures increase significantly within the box, which means that, especially for the turbocharger, it quickly reaches a critical level. Consequently, during extended periods of full throttle, it operates close to the threshold of overheating, potentially leading to damage. Extreme temperature differences between the combustion chamber and the underside of the piston (which is constantly sprayed with cooling oil) cause significant material stresses, leading over time to what are known as "shrinkage cracks." These cracks can eventually cause the piston to completely split. Generally, drivers using tuning boxes are helpless against these risks, and the only way to mitigate them is to partially forgo the potential performance gains. A chip tuner, on the other hand, can significantly reduce thermal stress and soot emissions by moderately increasing the turbocharger boost pressure and advancing the injection timing. This reduces the thermal load on the turbocharger, but requires it to operate at higher speeds, which puts more stress on the cylinder head gasket. Chip tuning can shift some of the thermal stress from the pistons and turbocharger to the cylinder head gasket, allowing all components to handle it without issues, even under constant full throttle. However, the freedoms offered by chip tuning also pose risks, because excessively modifying multiple parameters can damage an engine even faster than with a power box, which only intervenes in one place, namely the fuel injection quantity. Chip tuning and MSG hardware The engine maps that are modified during tuning are stored in memory chips (such as EPROMs). In classic chip tuning, these chips are desoldered and replaced with chips containing the tuning data. In some cases, socket connectors are soldered in (if they are not already present) to allow for quick and easy updates or fine-tuning. "Soldering work inherently carries the risk of damaging the MSG or..." Malfunctions, which are immediately noticeable in a large number of these cases, manifest as the engine failing to start. Occasionally, soldering defects only become apparent after weeks or months. In the worst-case scenario, they can lead to disasters, for example, if the engine fails during an overtaking maneuver... In newer engines, OBD tuning (flashing) is common, meaning the reprogramming is done without modifying the hardware, either through the vehicle's diagnostic port or, if necessary, on the engine control unit (ECU) after it has been removed, without opening it. However, there is a possibility that a software update from the vehicle manufacturer will be installed later during routine maintenance, which could render the tuning ineffective. Whether a vehicle is OBD-tunable depends on the type or model. Determine the generation of the installed MSG. Some chip tuners also tamper with the MSG (Memory Storage Module), which can be reprogrammed, thereby reducing the (statistical, see above) reliability of the MSG. In some cases, even additional processors are installed, solely to prevent the extraction of tuning data (e.g., by competitors). While this also eliminates the possibility of accidental software updates, those interested in tuning should carefully consider whether the additional risk of malfunctions during driving is worth it. To avoid such risks, one should avoid "solder-in" tuners whenever other tuners for the same vehicle model definitely offer an OBD-based tuning solution. Owners of MSG devices that cannot be flashed should specifically inquire whether only the chips with the identification fields are being replaced or reprogrammed, or whether further hardware modifications are being made. Nowadays, there are also tuning chips available for DIY projects (e.g., on online auction sites). However, the probability of getting good overall results here is very low. In addition, there is a risk of damaging the engine control unit (ECU) during self-installation, which not only renders the car unusable but also requires a new, relatively expensive ECU to be sourced and adapted to the vehicle (including immobilizer systems, etc.). Topspeed: If one wants to achieve higher maximum speeds through TDI tuning, the only truly appropriate solution is to extend the gear ratio, unless the standard engine already reaches its rated speed in the highest (fuel-efficient) gear on a flat surface. However, if the engine already reaches its rated RPM in the highest gear from the factory, then a chip tuning focused on top speed must maintain the full fuel injection amount above 4,000 RPM – despite the poor fuel efficiency (due to the relatively low combustion speed of the diesel mixture, the piston falls behind the combustion process) and the speed-dependent stress on the engine, which, for example, increases by 21% at 10% higher speed. How does chip tuning work? The main parameters adjusted within the MSG's data set, such as fuel injection quantity, boost pressure, injection start timing, etc., are modified to increase the engine's torque or... Performance achieved. To achieve this, Chiptuner has found several methods. 1. Copying of datasets The simplest method is to copy the software from a more powerful (or already tuned) engine into the MSG (engine control unit) of a less powerful model. For example, tests are conducted to see how a 100 horsepower TDI engine performs when running with the standard software designed for a 150 horsepower engine, and so on. All combinations of these engines and third-party software, which are advertised as providing significantly more power, are being pushed onto customers. The customer then has to deal with the consequences, because in most cases, the aftermarket software is not compatible with the fuel injection system and turbocharger of the "tuned" engine. This can lead to bizarre torque and power curves, the turbo boost control can become completely erratic (too much or too little pressure depending on the RPM, extreme overboost, etc.), the fuel consumption display becomes completely inaccurate, the car may jerk, misfire, produce excessive smoke, and even go into limp mode, etc. Depending on the degree of compatibility between the original software and any third-party software, not all of these symptoms may occur, or they may be so mild that they don't bother the average driver – as long as nothing breaks. Depending on the internal communication between the various electronic control units (via CAN), malfunctions or unexplained error messages in other systems may also occur. In addition, a TÜV (German technical inspection agency) report may be included, which ideally matches the customer's vehicle, but does not necessarily correspond to the performance and operating parameters of the supplied software. Depending on the effort involved, these "tuners" require very little equipment for their business. In particular, they do not need software for engine mapping, the professional versions of which cost several thousand euros to acquire legally. Instead, just a few OBD tuning tools are sufficient for the most common vehicles, which allows tuners to start making profits in a short amount of time, even with very low prices. 2. Genuine tuning files "Alternatively, tuning guides are not provided by the vehicle manufacturers. Therefore, when it comes to new engines, the engine software must first be analyzed to identify the performance-relevant parameters and maps." "Tuner" experts then modify these data, aiming for (presumed) performance improvements, until practical testing yields a working result with the desired increase in power. The most basic tuning files simply replicate the "boxing" principle and, as a result, offer noticeable performance gains with minimal programming effort – but with all the disadvantages described above. The better a tuner understands the functions of the engine software and the interaction between the various components, the more areas they can modify to create a well-balanced tuning that, for example, reduces power output to prevent impending overheating problems, thereby keeping thermal loads from becoming too high. However, comprehensive knowledge of the software's functions alone does not make a good tuner. Only by combining knowledge of the effects of software changes on the engine, as well as the design margins of each factory performance level for the engine, clutch, transmission, etc., can a foundation be created that enables the development of truly excellent tuning software. "Particularly good tuning files have been refined through extensive dyno tests, involving measurements of various pressure, temperature, and exhaust values, to achieve an optimal balance between performance gains and increased stress/strain." It represents the material's durability, as well as its consumption and emission values. Correspondingly, such tuning software is sold at a high price, and it is highly sought after by tuning companies, as it can save them a great deal of work, for example, if they can read out the engine software of a particular car. However, this type of industrial espionage is not the only way that software expertise spreads within the tuning scene. Sometimes, (friendly) tuners help each other out by sharing tips or ready-made tuning files. Additionally, some officially sell tuning files to other tuners, provided they are willing to pay the required price to compensate for the development effort saved. However, almost every tuner tends to keep their advanced techniques and tricks for their own clientele, while only sharing basic concepts with colleagues or potential competitors, which are sufficient to satisfy the average customer's expectations. Unfortunately, many tuners, having seen such a standard TDI tuning file (which usually only modifies 3 to 4 maps compared to the stock settings), mistakenly believe that this principle can be easily applied to all power levels. They simply adjust the software settings they identify, increasing them in their minds to further enhance performance. This misconception leads to widespread conceptual errors in common tuning files, such as... - Lack of torque and power compared to the advertised specifications. - Excessive black smoke when accelerating. - Incorrect data in the consumption report, often with artificially low readings suggesting a fuel-saving effect from tuning, which proves to be false when calculating the actual fuel consumption. - the "diesel temperature fake-scrapbox" effect (see above: a cold engine produces more power than a warm one). - Charging pressure diagnostic data below the programmed maximum pressures. - Excessive boost pressure spikes during transitions to full throttle, and other boost pressure control malfunctions. - Overheating damage (e.g., VTG hot spots, piston cracks) caused by increased injection quantities and boost pressures that are not reduced in time as the load increases. - Suppress the emergency function when the boost pressure is too high. The latter is a typical, unintended, and widely unknown side effect of many tuning files, which occurs when the tuner doesn't consider the interaction between the desired boost pressure, the programmed limp-home threshold, and the measurement range of the boost pressure sensor. Such software allows the turbocharger to build up unforeseen pressures during overboosts or VTG (variable turbine geometry) hot spots, potentially damaging the cylinder head gasket, leading to engine disassembly due to over-revving, and ultimately sending compressor debris through the engine as destructive abrasive sand. At no point does MSG even consider pulling the emergency brake: a programmed total engine failure, the result of a superficial tuner who has simply pushed the tried-and-true "Tuning Schema F" a little further than usual, without understanding the consequences that would arise. In a tuning process, such as for a PD-TDI engine, where all the mentioned errors are avoided, a minimum of 8 parameter maps or characteristic curves must be adjusted, depending on the desired performance gain. The limits compared to the standard software have been changed, but most tuners are only familiar with the aforementioned 3-4 mapping tables. One of these well-known tuning parameters is often the throttle response curve, which can be used to create impressive "hot air" effects: If the desired amount of power is already raised to approximately 90% of the maximum value at only half the pedal travel, the engine will react extremely aggressively to even the smallest movement of the pedal, creating the illusion of a significant power gain (which is often necessary to mask objectively lean tuning results, as mentioned above). It's often the case that virtually nothing happens between 50% and 100% pedal travel, and this realization usually comes to the average customer so late that they are often too hesitant to file a complaint with the tuner. Just as a side note, with software like this, on smooth roads without ESP, you have almost no chance of achieving usable acceleration without the wheels spinning. What performance gains can I expect from chip tuning? General rule: If the promised performance gains from tuning are roughly in the range of "stock performance + 20%", then that is usually achieved. However, depending on the base software, there are often some obstacles that prevent achieving higher performance gains, so that only tuners with above-average expertise can actually achieve their performance promises. Furthermore, many TDIs come from the factory with a wide powerband, meaning that a tuner can achieve the advertised Nm and PS gains with a smaller increase than what the official data might suggest. It's likely that many tuners already factor in the typical performance gains of stock TDI engines when they create their offers. To quickly estimate the power gain in PD-TDIs based on diagnostic data: The market situation for chip tuning One would assume that quality-conscious customers, who generally don't buy cheap, low-quality products, would also value good software when tuning their car and would be willing to pay reasonable prices for it. However, the reality is often different, as TDIs (unfortunately) are often used to install even amateurish tuning files. For example, the fuel-air ratio, which has a significant impact on running smoothness, performance, and durability (e.g., overheating due to excessive fuel enrichment at high loads) in gasoline engines, is largely not a critical factor in diesel engines. TDIs consume almost any type of software, including the aforementioned design flaws, without completely failing. They may only produce "slightly" more soot, and they occasionally respond to particularly bad files (or very unsuitable copies from other engines) with jerking or limp mode, but thanks to their inherent design margins, it is often possible to drive for a while even with excessive increases in injection quantity, turbo boost, etc., before damage occurs. Due to this inherent "goodness," good and many bad TDI tuning files (and sometimes even copied original files from other engines) feel very similar to the untrained user in terms of comparable performance, making it difficult for the average customer to distinguish between them – as long as the engine doesn't go into limp mode. "As long as no clearly noticeable problems occur, a customer of a copier/budget tuner can be just as satisfied with the performance of their TDI as another driver of the same model, whose engine produces the same power from a conceptually clean overall tuning." Experiences like these inevitably appeal to the bargain-hunting mentality of potential customers: If the "popometer" (a device used to measure audio quality) consistently reports very similar results across different tuners, people are likely to buy from the place that offers the lowest price. Even at a budget tuning shop, the average customer's perception (lacking background knowledge about engine tuning, the associated risks, and the development effort involved) is dominated by the contrast between the visible amount of work and the price: "Someone is doing a casual, easy job on my MSG (which only takes a few minutes even with OBD tuning), and charging me several hundred euros for it. I would also like to have such an hourly rate! -> Therefore, more expensive tuners can only be bigger scammers... " This prevailing customer mindset creates price pressure on the tuners, which increasingly discourages the development of high-quality files or even excludes it altogether if the tuner wants to operate profitably. On the other hand, new types of "dumping tuners" are emerging, which often generate their profits from mass-distributing tuning software in on-site "I tune everything that moves fast enough" operations, pushing the limits of data waste. In summary: 1. For the majority of customers, TDI tuning files only need to be "good enough" to prevent freshly tuned engines from failing or going into limp mode, which would quickly spread negative word-of-mouth. 2. The lower the standard prices of a tuner, the less (own) work can generally be included, and the more likely it is that a customer will receive poorly designed files or software for a different engine type, which will cause the engine to run more poorly than well, and the probability of premature damage increases accordingly. Anyone who, as a customer, believes that a TÜV inspection report for chip tuning automatically means that it is a cleanly programmed tuning file is gravely mistaken! The TÜV (German technical inspection authority) is primarily concerned with the exhaust emissions measured during the standard driving cycle (which practically does not require high engine loads and therefore gives tuners complete freedom in the full-load range), and whether, due to higher performance, the brakes need to be reinforced or... Tires with a higher speed index must be used. Therefore, almost any tuner, with a little thought, can create TÜV-compliant tuning files above the "copier" level. The biggest problem is the cost associated with the certification and whether the investment is worthwhile given the expected demand. The TÜV (German technical inspection authority) doesn't care what a tuning file (or "box") does to the engine when unlocking extra power, as long as the test vehicle only needs to pass the tests required for creating the parts approval certificate. Some low-cost providers also supply certifications for tuning files that are not actually certifiable, meaning they are ultimately forged certifications. How do I find a good chip tuner? Or, to put it another way: Where can you find mature software at fair prices? While customers can certainly assess the price, when it comes to software quality, any customer who isn't familiar with the intricacies of the engine software and doesn't have the tools to read and analyze it is reliant on their "butt dial" – a very imprecise and unreliable indicator that, moreover, can only be used *after* the car has already been modified. "Before-and-after comparisons of maximum speed (Vmax) are similarly unreliable, as measurement conditions (slope, wind, etc.) can significantly distort the results." Due to this conscious or unconscious sense of helplessness, most people interested in tuning try to assess the software quality remotely based on various substitute criteria. In addition to frequently cited experiences from other customers (which, regarding tuning, often only provide subjective impressions or questionable before-and-after data!), most interested parties pay attention to things like: -> Impressive promises regarding the torque and power output of the tuned engine. -> Pricing, discounts (attractiveness of deals!). -> a great website. -> Representative office buildings (with attractive women at the reception). -> Courteous and friendly advice. -> Involvement in motorsports. -> Alleged collaboration with engine developers at vehicle manufacturers (which may be limited to supplying items such as hats, breakfast rolls, etc.). -> offered guarantees -> TÜV inspection report. -> Promises to customize the performance characteristics. -> On-site tuning activities. -> In-house performance testing facility. etc. etc. To attract customers, many chip tuning companies therefore equip their premises with such (facade) features. For example, a dynamometer is indeed a tool for creating good tuning files, but whether the tuner actually uses it cannot be inferred from that - unless one can (randomly) observe dynamometer runs of vehicles that are equipped with measuring instruments. But even then, the tuning file for your own car might be derived from a simple, standard design. Test benches, incidentally, offer numerous possibilities for measurement errors, which can lead to the effect of the tuning (as the difference between before-and-after measurements) being completely exaggerated – for example, by entering incorrect values for ambient pressure or temperature, or by having the cooling fan blow directly past the intercooler during the series measurement, while during the tuning measurement, the clutch is not disengaged during the acceleration phase, and so on. While it's true that "established" tuners have likely kept their businesses afloat for a long time thanks to their marketing strategies, this doesn't necessarily prove they possess advanced tuning expertise. Overall, even the most basic TDI tuning software with only a modest performance gain can be deceptively marketed with a glossy facade, and conversely, experienced tuners working out of small workshops can provide sophisticated tuning solutions that many customers of large, established companies can only dream of. To increase the chances of getting good tuning software, someone who is not knowledgeable (as mentioned above) should not be swayed by superficial aspects or discouraged by them, but rather should focus on a few simple facts: "Specialists do something special." For example, as the owner of a 110 HP TDI vehicle, it would be incredibly fortunate to find a tuner who specializes exclusively in this engine family and possesses not only excellent knowledge of the engine control unit (ECU) software, but also practical experience working on the engine hardware, allowing them to successfully combine performance-enhancing modifications with the appropriately tuned software. As a customer, you can expect that the chosen tuner will pour all their (professional) creativity and passion into tuning the engines that you yourself drive. The more "side activities" a tuner pursues, deviating from this rather theoretical ideal, such as... - a vast range of tuning software for virtually all manufacturers and vehicle models with digital engine control units, but no tuning options in the area of engine hardware. - "Mass production" tuning services near you, offered by small businesses or individual entrepreneurs. - Chassis tuning. - Body styling, - Trading of new and used cars. - Sale of spare parts and accessories, car audio, etc. The more likely customers are to acquire pre-made tuning software, and of course, every businessman strives to spend only the necessary amount on acquired know-how. However, even if such a provider does not access the "most economical" (cheapest) software sources, it will, at best, be able to offer its customers second-rate tuning solutions for the reasons mentioned above. 2. Is there a preliminary check? Make sure the mechanic thoroughly checks the engine beforehand (using a diagnostic tool, if necessary). Compression test, etc.), because only engines in good condition are suitable for tuning. If a dyno test before the tuning reveals significantly lower power output than the stock performance, and the tuner ignores the problem or attempts to compensate for it solely through software adjustments instead of addressing the underlying cause, it is advisable to postpone the tuning (or seek a different tuner) until the defect has been resolved. While a low initial measurement might just be the first half of a fabricated result, intended to exaggerate the impact of the tuning (as mentioned above), the tuner deserves even more criticism if it leads to critical customers withdrawing. 3. If you have sufficient prior knowledge, ask the tuner what fundamental changes they will make to the engine management system. If the responses are just generic answers like "more fuel," which cannot be specified further, then the tuner probably doesn't really know what they're doing. (Who would let a doctor operate on them for something as vague as "cutting something small out"?) 4. One should avoid tuners that engage in price wars with each other, because in their range of tuning files, good files are a complete stroke of luck – something to hope for with more naivety than realism. This is also because tuners with more expertise tend to deliberately provide inferior files to their competitors, in order to eventually cause their customers to regret their "bargain" tuning. If the engine has been tuned, customers may recognize a very poor file or unsuitable software from other engines by new symptoms, such as strong knocking, jerking at partial load, excessive black smoke, shaking of the powertrain at full throttle (frequently experienced in high gears within the range of approximately 1300 to 2500 rpm), a fluctuating boost pressure gauge, and possibly audible pumping flow noises from the turbocharger. Then, you should immediately and carefully return the device to the tuner, reinstall the original software, and find a different tuner. If the engine exhibits a particularly aggressive response even with minimal throttle input, it may indicate the issue mentioned above. The "driver preference" map trick is often used to mask the fact that the promised performance has not been achieved. To clarify the achieved performance gain, the pull-through calculator can be helpful: The measured time between 2000 and 4000 rpm decreases approximately proportionally to the average increase in torque. Okay, gib mir den deutschen Text, den du übersetzt haben möchtest. Before the tuning, a specific car achieved a 0-100 km/h acceleration time of 6.5 seconds. The tuner promises an increase from 310 to 400 Nm of torque and from 160 to 130 horsepower. The increase factors are 1.29 for torque and 1.23 for power, resulting in an average increase in power of 1.26. With these conditions (identical to those used for the standard measurement!), the vehicle should achieve an approximate 0-60 mph acceleration time of 6.5 seconds / 1.26 = 5.16 seconds. If the vehicle significantly misses the calculated time, it is highly probable that the tuner has also failed to achieve the promised overall performance increase. If a car has an on-board lambda sensor (LDA), the driver can at least monitor the tuner's work in the area of boost pressure during the test drive. If someone doesn't want to change their turbocharger regularly, a general rule of thumb is to ensure that their chip tuner increases the boost pressure by no more than 0.2 bar compared to the standard at the same engine speed, and that the overboost during full throttle does not exceed the level before the tuning. As long as the tuner has not also reprogrammed the conversion of real data into diagnostic data (which is highly unlikely, because no performance can be gained from it), the diagnostic software VCDS (formerly VAGCOM) still allows for a few more insights into its operation. To do this, you take some data logs of the most important parameters before the tuning process. a) Injection volume (ideally, the volume limits). b) Turbocharger pressure and... c) Start of injection/pumping. under reproducible conditions, such as full throttle from 1200 to 4500 rpm in 4th gear. Okay. After the tuning process, the same measurement data blocks are logged again, and by comparing the differences, you can see what the tuner has changed (or not changed). "If the dyno readings show the same values as before the tuning, but the car has more power, then you likely received a basic chip tuning based on the '10c' principle." To confirm the results, it is also important to log the relevant measurement values. For the VP engine, check the block for fuel injection quantity and RWG (throttle valve) voltage. For the PD engine, check the block for water temperature, turbocharger air temperature, and diesel temperature (also verify that all values are within a few degrees Celsius of each other even when the engine is cooled down), and the relationship between engine speed, fuel injection quantity, and injection duration at full throttle. text If you log the data for the MWB 11 (mass airflow sensor) at full throttle from 1300 to 4500 rpm and calculate the LD (lambda) correction error (field 3 minus 2), you can see the effort the tuner put in: As long as the LD (lambda) control error remains significantly larger after tuning than it is in the standard configuration (where a maximum of +/- 50 mbar after stabilization is typical), the tuning is essentially a botched job. This is because the tuner either failed to find the correct pre-injection map, or simply wrote the file according to a standard template without considering the specific turbochargers used by their customers. If the boost pressure control duty cycle is already at its maximum (around 95%), the turbocharger is essentially operating at its limit, and it is advisable to reduce the injection quantity in the relevant speed ranges as quickly as possible. -> Some files reveal themselves as jokes through their obfuscation. When logging both air mass and the turbidity limit over longer distances (including partial load conditions), the turbidity should always be less than the air mass divided by 15, except during rapid speed or load changes. Otherwise, the tuner releases more diesel through the opacity, which exceeds the amount of air available for combustion, and this turns the TDI into a smoke-belching machine, depending on the engine's operating point. Unfortunately, the inverse logic "If air mass / fuel injection quantity > 15, everything is OK" doesn't always hold true: As soon as the tuner extracts a portion of the excess from the 10c principle (see above), the actual values behind the fuel injection quantity log values are higher, and the engine can still cause problems... -> To ensure the durability of the turbocharger, the start of injection/boost should not be advanced by more than approximately 2°KW at full load and the same engine speed (this is a rule of thumb, and the overall effect on the engine also depends on the pump's flow rate, the nozzle openings, the boost pressure, and the factory settings). -> To document the trick with the pedal map, you need to determine the relationship between engine speed, pedal position (in %), and the "driver demand" fuel quantity limitation in the partial load range. Since only minor adjustments to the engine's performance map are needed to make it feel more powerful, the trick can only be detected by carefully comparing "before" and "after" data specifically from the modified speed and pedal position ranges within the map. Warranties of the tuner With each modification, the risk of defects in the engine and drivetrain inevitably increases due to the increased stress on the materials. In addition, the vehicle manufacturer will, of course, refuse to provide any warranty coverage or goodwill arrangements for vehicles that have been (obviously) modified. "No problem," say the tuners, and they offer guarantees to ensure that the potential customer still feels secure. Essentially, there are the following types of tuning guarantees, which, of course, only become clear upon careful reading of the fine print. 1. Material warranty for the tuning It only covers items supplied by the tuner, such as the EEPROM containing the tuning data, or the power box. However, if the engine fails, the customer will likely face problems from the start, even if the product is still under warranty. 2. :evil:Warranty against damages resulting from tuning It also covers the engine, transmission, etc. Don't get too excited just yet: Clauses like "damages resulting from the tuning" mean that the tuner can easily evade responsibility by simply saying, "this defect would have occurred anyway, even without the tuning." And how, as a customer, does one prove the opposite? 3. The transfer of the manufacturer's warranty, according to its terms and conditions, to the tuner. At the very least, this is the only real form of protection for the customer: regardless of what breaks, whether due to the modifications or not, the tuner is now the point of contact. But always remember: first, read the fine print carefully, and then decide whether or not to purchase the warranty (if you even have the option). Deceptive: Lists of parts that are excluded from the warranty from the beginning. Sometimes, it includes classic tuning components like turbochargers and cylinder head gaskets, meaning that the customer pays for the most likely defects upfront from their own pocket. The actual value of such a guarantee is something that each person can assess for themselves... Some additional arguments that have not yet been mentioned... . . . per chip tuning Tuning boxes need to be connected to the wiring harness leading to the fuel injection pump or the common rail injectors. The additional connector, clamp, or solder connections required for this process increase the risk of defects, especially when performed carelessly, a risk that is not present with chip tuning. Adjustable tuning boxes particularly appeal to drivers from the "bro" demographic, encouraging them to increase the fuel injection volume to a point where excessive soot production occurs, significantly increasing the risk of serious engine damage. If a car like that is sold just before a major engine failure, the new owner may have to deal with the consequences. . . . per tuning box Tuning boxes are usually easy to install yourself, and they can often be adjusted to the specific vehicle based on its driving characteristics and exhaust emissions (using a control knob on or inside the box). For chip tuning or data correction, the engine control unit (ECU) must be sent to the tuner, or the vehicle must be brought to the tuner's location. When using tuning boxes, the software in the engine control unit (ECU) remains unchanged. Therefore, problems caused by faulty software (e.g., diagnostic issues, limp mode due to poorly implemented boost increases) are fundamentally excluded. Vehicles that meet the EU5 emission standard have a "checksum" in the engine control unit (ECU), which can be used to detect modifications, for example, with software like KOBD2Check: Tuning boxes can often be reused in other vehicles, while chip tuning incurs tuning costs for each individual vehicle. If you encounter any problems, you can disconnect the tuning box and continue driving with the vehicle's standard performance. To resolve chip tuning issues, the engine control unit (ECU) must be sent to the chip tuner for inspection and repair – unless it uses plug-in EEPROMs, which can be replaced by the user themselves with the appropriate technical expertise. If you keep the original data sets in the EPROMs, you can switch between the standard performance and a tuned version on your own. Advertising tricks Since chip tuners and box suppliers compete for customers, they often point out the disadvantages of the other method. In this case, a particular group, often referred to as the "chip faction," has found some potentially alarming formulations, and the actual background of these formulations is outlined here. The exact wording may vary in individual cases, but you often hear these three basic statements. 1. Tuning boxes can only inject additional fuel into the ongoing combustion process . Even with a standard full load, a significant portion is injected into the ongoing combustion process – this part of the statement describes the normal operating condition! Chiptuning allows for adjustments to both the start and end of fuel injection, while tuning boxes generally only delay the end of the injection. Therefore, the term "after-injection" is technically correct, but it also generally applies to chiptuning, as long as the extension of the injection time is not solely in the direction of a later injection, which could damage the cylinder head gasket. Occasional claims that chip tuning can maintain the same injection duration despite increasing the fuel quantity are simply nonsense (with the exception of common-rail engines, where the injection pressure can be increased independently of the engine speed). 2. All engine protection functions are deactivated. https://community.dieselschrauber.org/en/viewtopic.php?t=11885 Tuning boxes inject extra fuel, but the engine control unit (ECU) doesn't detect this additional fuel injection. Therefore, even with a reduced amount (such as in emergency mode or above the rated speed), a proportionally larger amount is injected, but the protective effect of the emergency mode is not completely eliminated. The engine speed may increase slightly, which reasonable drivers will hopefully only notice during the emissions test, when the engine runs a bit higher than it would without the air filter box. It's even possible to avoid that with boxes that can be switched off. Sophisticated PD-boxes can detect motor overload and, depending on the programming, operate in the partial load range or... The emergency mode should be completely passive, so that it does not interfere with the normal operation in any way. https://community.dieselschrauber.org/en/viewtopic.php?t=266463. Tuning boxes can lead to uncontrolled injection of fuel https://community.dieselschrauber.org/en/viewtopic.php?t=3939. Since tuning boxes can only function by somehow misleading the engine control unit (ECU), the ECU no longer has its usual absolute control over the fuel injection quantity. However, completely uncontrolled over-injection would cause the engine to fail. In other words, as long as the engine power is still well-controlled and responds appropriately to the accelerator pedal, the uncontrolled fuel injection is mainly just an exaggerated warning intended to deter potential buyers.https://community.dieselschrauber.org/en/viewtopic.php?t=29839
_________ MG4 Electric Translated on 03-07-2026, 14:19. |
| Ratings - Tuning comparison: Chip vs. Powerbox | |
Average rating: 4.95 - worst rating: 3 - best rating: 5 - number of ratings: 37 - View ratings |
Foren- und Portal-Software: V8.0 © 2003 - 2026 Kaufmann Automotive GmbH & Shop für Kfz-Diagnosegeräte. Parse time: 0.073s
