T4 Diesel Pump: Replacement & Repair
diestel
Post30-08-2019, 18:22    Subject: T4 Diesel Pump: Replacement & Repair Quote
Hello, I had to replace the diesel pump on my T4 1.9TD, manufactured in 1997.
Was anstelle der defekten Pumpe eingesetzt werden konnte, war eine identische, funktionierende Pumpe.
built-in.
Everything is marked, as far as I've adjusted it, timing belt and crankshaft position.
Unfortunately, it won't start.
You can see the pump drawing in fuel, but nothing is reaching the pressure lines that go to the injectors.
I'm slowly starting to feel lost.
Martin.
Translated on 23-09-2026, 19:29.
diestel
dieselschrauber likes this.
Post30-08-2019, 19:09    Subject: T4 Diesel Pump: Replacement & Repair Quote
Hopefully, I've found the problem: the magnetic switch is stuck.
Martin.
Translated on 23-09-2026, 19:30.
No new posts Volvo 740 Dieselpumpe Diesel Engine Technology
No new posts Diesel Pump Diagnosis: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts Druckfedern in der Dieselpumpe Diesel Engine Technology
No new posts Defective Diesel Pump: What to Do Now? Diesel Engine Technology
