Skoda Superb 3 T Facelift Towing Hitch Coding
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
[email protected]
Post23-11-2019, 16:09    Subject: Skoda Superb 3 T Facelift Towing Hitch Coding Quote
Hallo, ich habe einen Superb 3T Facelift Modelljahr 2020. Ich habe jetzt eine Anhängerkupplung mit 13-poliger e-Satz von Bosal an diesem Fahrzeug montiert. Bis jetzt alles in Ordnung. Aber ich kann das Auto nicht auf die Anhängerkupplung einstellen. Can anyone help me and provide me with the information on what I need to refactor?
I installed the trailer hitch on the gateway.
In the engine control unit, I had programmed them, and in the brakes, I had performed the trailer stabilization, etc. Afterwards, nothing really worked in the car anymore. The trailer hitch did not transmit any bus information. The error message was stored. No communication. Everything has been re-coded, and the vehicle is now functioning again.
In the attachment is a dump of the error memory.
Log-TMBJJ9NP8L7029978-562km-.txt
 File name:  Log-TMBJJ9NP8L7029978-562km-.txt
 File size:  16.68 KB
 Downloaded:  741 times
Post23-11-2019, 21:06    Subject: Skoda Superb 3 T Facelift Towing Hitch Coding Quote
Hello
What happens if you activate the trailer ECU in the gateway?
Your car scan is unfortunately quite useless if you only post the functional original state. Should we guess what you have set up for each task?
Best regards, Rainer
[email protected]
Post23-11-2019, 21:19    Subject: Skoda Superb 3 T Facelift Towing Hitch Coding Quote
Then there's the error that the trailer control unit is not establishing communication.
I have re-checked all the connections and pin configurations. I suspect that the problem may be with the AHK (Audio/Head Unit) control unit.
Log-TMBJJ9NP8L7029978-577km.txt
 File name:  Log-TMBJJ9NP8L7029978-577km.txt
 File size:  17.83 KB
 Downloaded:  822 times
[email protected]
Post23-11-2019, 22:07    Subject: Skoda Superb 3 T Facelift Towing Hitch Coding Quote
After some thought and searching, I found the error. The connection from the permanent power supply at the fuse box was loose. Just reconnected and the error is gone.
But what exactly do I need to recode in order to accommodate the trailer hitch?
 File size:  17.58 KB
 Downloaded:  309 times
Post24-11-2019, 12:26    Subject: Skoda Superb 3 T Facelift Towing Hitch Coding Quote
ok, vielen Dank fĂźr die RĂźckmeldung!
The general steps on how to adjust are found here:
/viewtopic.php?t=24420
[email protected]
dieselschrauber likes this.
Post24-11-2019, 12:29    Subject: Skoda Superb 3 T Facelift Towing Hitch Coding Quote
Super, vielen Dank.
No new posts Skoda Superb Estate (Wagon), 2012, Tailgate Actuator Defe... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia I-Anhängerkupplung Westfalia codieren? On-Board Diagnostics (OBD)
No new posts VW Crafter Tow Hitch Coding Electrical Systems, Vehicle Electronics, Multimedia
No new posts Skoda Superb 3U: Fault Codes & Diagnostics On-Board Diagnostics (OBD)
No new posts DPF Questions: Skoda Superb 3U (BSS) Diesel Engine Technology
