Error code P1351 (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » General Tips
Karma: +796 / -0   Thank you, like it!
Post17-03-2019, 14:36    Subject: Error code P1351 Quote
The error code P1351 is a manufacturer-specific error code, meaning that its specific meaning can vary depending on the vehicle manufacturer.
Generally, it indicates problems with the ignition system (misfires in gasoline engines) or the glow plug system (in diesel engines), and more broadly, combustion issues in one or more cylinders.
The corresponding subsystem should therefore be checked, and don't forget the fuel filter (a lack of fuel can sometimes cause combustion interruptions).
Translated on 14-07-2026, 0:14.
Ratings - Error code P1351
No new posts ESP function test, error code 01486 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code 01276 - ABS hydraulic pump (V64) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P1115, Overvoltage Temperature Sensor General Tips
No new posts Error code Diesel Engine Technology
No new posts Fehlercode 2.5 tdi, AAT u.ä. Diesel Engine Technology
No new posts Fehlercode 575 (saugrohrdruck) Diesel Engine Technology
No new posts Fehlercode 65535 037 On-Board Diagnostics (OBD)
