No performance at speeds below 1500 RPM
B7Fahrer
2007 Audi A4 Avant
Post06-07-2022, 19:37    Subject: No performance at speeds below 1500 RPM Quote
hello everyone,
On my Audi A4 B7 170hp, I have the problem that the car has absolutely no power up to 1500 rpm and barely accelerates.
From 1500 revolutions, power is applied, and at 2000 revolutions, full power is achieved.
Also, the problem is when I'm driving in 5th or 6th gear and the engine speed drops below 1500, then the car loses speed even though I'm pressing the accelerator pedal all the way down.
Error memory is empty.
what I have done so far: replaced turbocharger (the compressor wheel looked quite worn and the play was quite significant), cleaned AGR and throttle valve, temporarily blocked AGR (for testing purposes), replaced air mass sensor and air filter, re-adjusted the valve timing (the value is 0.35)
Low pressure on the turbocharger, the valve flaps in the intake manifold are also functioning.
Does anyone recognize this error, or does anyone know where it might be coming from?
what else should I check?
What's surprising to me is simply that the performance only drops below full power at around 1500 RPM.
Thank you in advance for your tips.
Log-WL 8-WAUZZZ8E97A230901-203910km.txt
 File name:  Log-WL 8-WAUZZZ8E97A230901-203910km.txt
 File size:  6.47 KB
 Downloaded:  389 times
Post06-07-2022, 20:10    Subject: No performance at speeds below 1500 RPM Quote
Inappropriate Chiptuning? 🙃
B7Fahrer
2007 Audi A4 Avant
Post06-07-2022, 20:32    Subject: No performance at speeds below 1500 RPM Quote
Chiptuning did not affect the car.
Karma: +647 / -0   Thank you, like it!
dieselschrauber likes this.
Post07-07-2022, 4:43    Subject: No performance at speeds below 1500 RPM Quote
Turbocharger new?
B7Fahrer
2007 Audi A4 Avant
Post07-07-2022, 6:24    Subject: No performance at speeds below 1500 RPM Quote
Completely overhauled, the error was exactly the same before the change.
Post11-07-2022, 11:40    Subject: No performance at speeds below 1500 RPM Quote
Is there a guide on how to proceed in case of performance issues, which is always available after logging in under x amounts?
{TEXT}
Maybe not always click away?
B7Fahrer
2007 Audi A4 Avant
Post29-07-2022, 17:21    Subject: No performance at speeds below 1500 RPM Quote
Error fixed, caused by the exhaust gas temperature sensor before the exhaust turbine, which was displaying a temperature of 1000 degrees.
Post29-07-2022, 17:37    Subject: No performance at speeds below 1500 RPM Quote
Was about a warning indicator in the cockpit? Because the charger would have been broken long ago...
The engine control unit reduces the amount of fuel injected when the exhaust temperature becomes too high. Therefore, the car must have generally lost power.
Best regards, Rainer
No new posts Doku Polo MJ 2002, No Power Steering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Document: Tapping Noises Below 1600 RPM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Defect? No Power Below 2400 RPM. Diesel Engine Technology
No new posts Is a roaring sound from the 1Z engine at approximately 15... Diesel Engine Technology
No new posts A6 C5 2.5 V6 TDI: No Power Above 3000 RPM Diesel Engine Technology
No new posts No T4 Acv performance Upload
