Two-mass flywheel end of life
Steffen W
Karma: +104 / -0   Thank you, like it!
Herbert and InlineSix likes this.
Post06-07-2020, 6:58    Subject: Two-mass flywheel end of life Quote
Last Monday, I unexpectedly broke down on my way to work. After 11 years of membership, I used the ADAC roadside assistance service for the first time. It worked perfectly. I can't fault it.
Here are some pictures of the dual-mass flywheel, which was the cause of the problem, for everyone's enjoyment.
[url][/url]https://youtu.be/4Umg2nhNfNw{MARKER}
 File size:  146.93 KB
 Viewed:  478 times
 File size:  155.06 KB
 Viewed:  467 times
 File size:  131.34 KB
 Viewed:  545 times
 File size:  82.66 KB
 Viewed:  472 times
 File size:  145.03 KB
 Viewed:  511 times
Passat Variant BGW 2005
Post06-07-2020, 17:42    Subject: Two-mass flywheel end of life Quote
My condolences! Mileage?
Steffen W
dieselschrauber likes this.
Post06-07-2020, 17:59    Subject: Two-mass flywheel end of life Quote
238,000 km. There's not much to say about that.
It has already been repaired. The starter motor was also replaced.
He could have easily sparked with me. The feather probably created a nice shower of sparks inside the bell before it got stuck.
No new posts Two-mass flywheel?! Diesel Engine Technology
No new posts Defective Dual Mass Flywheel: Symptoms & Repair Diesel Engine Technology
No new posts Two-Mass Flywheel Error Images Diesel Engine Technology
No new posts Verstärkte Kupplung beim AFN mit Zweimassenschwungrad Diesel Engine Technology
