VCDS-Mobile®, HEX-NET® Interface
Go to page: 1, 2, 3  Next
Post18-02-2014, 10:15    Subject: VCDS-Mobile®, HEX-NET® Interface Quote
The Ross-Tech HEX-NET is the latest generation of VCDS diagnostic tools. Thanks to the HEX-NET® Wi-Fi interface, it can be used without any cable restrictions!
In VCDS, for vehicles from 2018 onwards, the following message appears: Please purchase a current Ross-Tech diagnostic interface -> HEX-NET or HEX-V2 required!
Edit: As of the end of 2020, Generation 2 of the HEX-NET diagnostic hardware will be available. It is recognizable by its blue casing and a serial number that starts with "HN2-..." instead of "HN1-..."
At the current time, the functionality is the same as that of HEX-NET, but it is prepared for DoIP. All instructions and guidelines on the following pages also apply to the new generation blue HEX-NET.
 Neueste Generation 2 vom HEX-NET mit Vorbereitung für DoIP: blaues HEX-NET.
 File size:  921.55 KB
 Viewed:  3937 times
 Drahtlose Weiterentwicklung des Ross-Tech HEX-USB+CAN® Interface: Das VCDS-Mobile® System.
(Bild zeigt die Vorgänger-Generation)
 File size:  136.48 KB
 Viewed:  19793 times
Styrian
Post19-02-2014, 10:28    Subject: ...not bad, Mr. Woodpecker! Quote
*astonished*... approximately 802.11a/b/g/n??? Does this mean that VCDS is being developed for WinRT/Android/iOS/macOS/...? Is there any price information available yet? Interesting, especially because it avoids loops...are there any limitations compared to the wired module?
Best regards, Styrian.
Edit: Okay, never mind... I already read about it on the Ross-Tech website. It seems to be a kind of web interface that's integrated, making it OS-independent. Apparently, it functions as a pure diagnostic dongle. It looks SUPSI great!!!
Post19-02-2014, 16:37    Subject: VCDS-Mobile®, HEX-NET® Interface Quote
The basic version can only handle 10 VINs icon_sad.gif.
For a few more US dollars, you can get the unlimited option.
Too bad...
Post17-09-2014, 17:44    Subject: VCDS-Mobile®, HEX-NET® Interface Quote
VCDS-Mobile® and the HEX-NET® interface have recently undergone several firmware updates. As a wireless solution for using the VCDS Windows software via Wi-Fi, I find it very convenient.
    - no more cable clutter in the footwell.
    - No "distance limitation" diagnostic port
    - Workshop computer/laptop
    - no more "ground loops"
    - no loose USB connectors in the demanding workshop environment
 VCDS® mit HEX-NET® Interface
 File size:  170.29 KB
 Viewed:  14931 times
Post23-10-2014, 16:41    Subject: VCDS-Mobile®, HEX-NET® Interface Quote
Still waiting...
Christmas is coming soon icon_exclaim.gif.
Greetings.
Post23-10-2014, 20:39    Subject: VCDS-Mobile®, HEX-NET® Interface Quote
1000 euros should be enough. That remains.
There's probably still something left over for the Christmas tree. icon_biggrin.gif
Post23-10-2014, 21:46    Subject: VCDS-Mobile®, HEX-NET® Interface Quote
That needs to be enough for a pack of three, offering "unlimited VINs" icon_wink.gif.
Post26-10-2014, 22:02    Subject: VCDS-Mobile®, HEX-NET® Interface Quote
Is there also a warning message for forgetful people that reminds them to remove the OBD sensor from the car?
Post27-10-2014, 10:13    Subject: VCDS-Mobile®, HEX-NET® Interface Quote
...and do not use it in the Touareg icon_biggrin.gif.
At least, don't engage the "hand" brake, because then the diagnosis will end icon_exclaim.gif.
Post27-10-2014, 10:15    Subject: VCDS-Mobile®, HEX-NET® Interface Quote
T3Surfer wrote:
Is there also a warning message for forgetful people that the OBD sensor is still plugged into the car?
Post27-10-2014, 17:08    Subject: VCDS-Mobile®, HEX-NET® Interface Quote
It is configurable, and when that setting is enabled, the component goes into a sleep mode.
vw-doka
Post04-04-2015, 9:10    Subject: VCDS Mobile Quote
Hello everyone, and Happy Easter.
Is there any new information available about VCDSMobile?
When will it be available, and is there a price yet?
The last post was quite a while ago.
Ralf
Post15-09-2016, 16:05    Subject: VCDS-Mobile®, HEX-NET® Interface Quote
Update: Official sales launch after Automechanika 2016!
The HEX-NET vehicle diagnostic system will soon be available for purchase from us, and it offers the following advantages:
- Replaces HEX-USB+CAN, with more space for firmware to support new vehicle models from Audi, Seat, Skoda, and VW.
- Can be used as before via USB, or now also via Wi-Fi.
- The WIFI solution is completely independent of any specific manufacturer; instead of Windows, any device with an internet browser can be used, whether it's a smartphone, Android tablet, or Mac!
As always, KDataScope is with us.
https://www.youtube.com/embed/ozEpUHR9bKs
 File size:  101.29 KB
 Viewed:  6574 times
Wiesel
Post20-09-2016, 14:03    Subject: VCDS-Mobile®, HEX-NET® Interface Quote
Post20-09-2016, 15:09    Subject: VCDS-Mobile®, HEX-NET® Interface Quote
You can be sure that it will be listed in the shop as soon as it is available. icon_wink.gif
VCDS-Mobile utilizes the new HEX-NET interface, which can be connected via a USB cable as before, but can also be operated wirelessly (via WiFi).
Using VCDS on the computer, the HEX-NET is significantly faster than the previous HEX-USB+CAN diagnostic interface. icon_biggrin.gif
Accessible via web browser and VCDS-Mobile, it no longer requires a Windows computer. This functionality is suitable for quick diagnostics on the go, for example, using a smartphone.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post20-09-2016, 17:35    Subject: VCDS-Mobile®, HEX-NET® Interface Quote
Does the dongle itself create a Wi-Fi hotspot, or is a router or similar device required?
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS Mobile App for Sharan 7N On-Board Diagnostics (OBD)
No new posts VCDS Mobile App not in Store On-Board Diagnostics (OBD)
No new posts VCDS Mobile: Incorrect Data Display? Fix Now! On-Board Diagnostics (OBD)
No new posts VCDS Interface for 24V systems On-Board Diagnostics (OBD)
