DPF Reset Audi Q5 8RB: How to Calibrate
burkerw
Post25-11-2020, 19:02    Subject: DPF Reset Audi Q5 8RB: How to Calibrate Quote
Hello, my Audi Q5 3.0 TDI, 245 hp, manufactured in 11/2013, now has 170,000 km on the odometer. I'm considering having my DPF removed and professionally cleaned while it's still working properly, and I have a second car available for that time. I'll also replace the differential pressure sensor at the same time.
Oil ash volume: 0.22 liters.
Oil service interval: 57.4g (according to Audi, up to 30,000 km further).
Loading limit for ash: 327.67g.
When I reinstall the cleaned DPF, do I only need to reset the DPF and differential pressure sensor learning values, or is there a certain amount of loading that needs to be entered?
Thank you.
Walter.
Log-WAUZZZ8R6EA065325-170310km.txt
 File name:  Log-WAUZZZ8R6EA065325-170310km.txt
 File size:  14.74 KB
 Downloaded:  443 times
adpmap-01-8K5-907-401-G_WAUZZZ8R6EA065325-20201125-1618.CSV
 File name:  adpmap-01-8K5-907-401-G_WAUZZZ8R6EA065325-20201125-1618.CSV
 File size:  1.14 KB
 Downloaded:  754 times
Audi Q5 3.0 TDI MJ2014 MKB CDUD
Translated on 27-09-2026, 15:45.
Karma: +807 / -0   Thank you, like it!
Post25-11-2020, 19:37    Subject: DPF Reset Audi Q5 8RB: How to Calibrate Quote
Hi.
When I reinstall the cleaned DPF, do I only need to reset the DPF and differential pressure sensor learning values, or is there a certain loading value that needs to be entered?
Yes, the ash mass or ash volume needs to be reset.
See:
Ich kann den Inhalt dieser URL nicht abrufen, da ich keinen Zugriff auf externe Websites habe. Bitte gib den Text, den du übersetzt haben möchtest, direkt an.
Translated on 27-09-2026, 15:47.
burkerw
dieselschrauber likes this.
Post25-11-2020, 20:23    Subject: DPF Reset Audi Q5 8RB: How to Calibrate Quote
Thank you for your reply.
But I don't quite understand it.
According to the oil ash mass, my value of 57.4 is quite high, nearing the upper limit of what's possible.
Based on the oil ash volume, I haven't even reached two-thirds of the possible limit.
What does that mean for my DPF?
Regarding the reset function: I can only set it to zero, regardless of anything that might still be remaining in the filter, right?
Thank you.
Walter.
Translated on 27-09-2026, 15:49.
Karma: +1359 / -0   Thank you, like it!
Post25-11-2020, 21:24    Subject: DPF Reset Audi Q5 8RB: How to Calibrate Quote
How did you arrive at those values? The limit for oil ash should be 360 ml for the 3.0 l TDI engine. You're probably talking about soot.
You're somehow putting together things that don't make sense.
Translated on 27-09-2026, 15:50.
burkerw
Post26-11-2020, 16:53    Subject: DPF Reset Audi Q5 8RB: How to Calibrate Quote
Hello, yes, that might be possible. Can anyone help me with that?
Here are the values I obtained from the VCDS scan (see attachment):
Oil residue: 57.4g
I found these limit values in Elsa (see attachment).
6-cylinder diesel engine, 3.0 TDI, engine code: CDUD, oil ash volume: 370ml.
What is more important for me: oil ash volume or oil ash mass? And what does the bleeding limit of 327.67g from the VCDS scan indicate?
I understand that these are just calculated values, but I don't want to drive until the DPF is completely clogged. Instead, I want to be prepared and, if necessary, have the DPF cleaned properly.
Thank you.
Walter.
Aschegrenzwert.pdf
 File name:  Aschegrenzwert.pdf
 File size:  136.52 KB
 Downloaded:  248 times
VCDS Scan.pdf
 File name:  VCDS Scan.pdf
 File size:  80.51 KB
 Downloaded:  271 times
Translated on 27-09-2026, 15:51.
Post26-11-2020, 17:33    Subject: DPF Reset Audi Q5 8RB: How to Calibrate Quote
Not every value in the extended measurement data needs to be practical.
For your 3.0 V6 TDI engine (engine code CDUD), the maximum oil ash volume is 370ml. Your engine control unit estimates that 220ml ( = 0.22l) are present.
The latter is a realistic estimate for 170,000 km; extrapolated, the DPF would be "full" after 285,900 km.
Under the same driving conditions, this would likely occur in approximately 4.8 years. At that point, the car would be 12 years old.
Whether you want to exchange something beforehand or not is something you can only decide for yourself.
Translated on 27-09-2026, 15:54.
burkerw
Post26-11-2020, 18:40    Subject: DPF Reset Audi Q5 8RB: How to Calibrate Quote
Thanks, great information!
Then I won't do anything yet, there's still plenty of time icon_smile_thumb_up.gif.
Greetings.
Walter.
Translated on 27-09-2026, 15:55.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4: Cleaned DPF & New Engine - For Sale Diesel Engine Technology
No new posts Do you need to register the battery after replacing it in... On-Board Diagnostics (OBD)
No new posts [Poll] MSW Cleaning Success Rate for VP-TDIs Diesel Engine Technology
No new posts Valve Spring Pressure Changes After Cleaning Diesel Engine Technology
