Service Reset (Maintenance Indicator) FB Mondial SMX 125i (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » General Tips
Post07-07-2022, 22:07    Subject: Service Reset (Maintenance Indicator) FB Mondial SMX 125i Quote
Service Reset (resetting maintenance) on the FB Mondial SMX 125i is performed by unlocking the ignition switch, holding down the function button on the right side of the display for at least 5 seconds, and then turning on the ignition while the button is held down.
After a short time, the "Code" appears on the display, and in the three-digit display, you select "211". The selection and confirmation are also done with the function button.
The maintenance indicator on the display is now reset.
OBD can be accessed via the OBDII protocol at the engine control unit for this vehicle, for example, using:
https://shop.dieselschrauber.org/en/obd2-diagnose-kit-p-321.php
You are not permitted to view these file(s), please log in or register for extended rights or status updates.
Ratings - Service Reset (Maintenance Indicator) FB Mondial SMX 125i
No new posts CNG service reset, gas tank Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A1, A4, Q3, A5, A6, Q5, A7, Q7, A8 (Digital Radio Re... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Control Unit / Injection Mondial SMX 125i Gasoline Engine Technology
No new posts Audi A1: First WIV Service Reset On-Board Diagnostics (OBD)
No new posts HEX-NET Reset to factory settings On-Board Diagnostics (OBD)
No new posts Reset by disconnecting the battery - HOW? Diesel Engine Technology
