topf20
Joined: 12/08/2018 Posts: 6 Karma: +2 / -0 Location: Ronneburg
16-02-2021, 17:06 Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues |
Hello.
"For some time now, I've been getting the error message "Can't spawn VCSCOPE.EXE" when opening diagrams in Block."
Using Windows 7 without any antivirus software.
I have already uninstalled VCDS (V20120-Installer) and KDataScope (KDataScope_222_GER), deleted the Kaufmann and Ross-Tech folders, and reinstalled everything.
The KDataScope program runs through the Start/Programs menu, regardless of whether VCDS is open or not.
Did I make a user error?
Until recently, I was able to display the values in a chart.
[email protected]
Translated on 19-09-2026, 2:22.
vag-driver Profi-Schrauber
dieselschrauber likes this. |
16-02-2021, 19:59 Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues |
Windows 7 support ended in January 2020. Therefore, I highly recommend using a more recent operating system. I only mention this for your information.
It's not unlikely that your Windows 7 is no longer functioning correctly. I recently experienced the same issue with my Windows 10. The only solution is a clean reinstallation.
What I want to express is that the problem might not be with VCDS itself, but rather with Windows. Viele Grüße
Andreas
Translated on 19-09-2026, 2:23.
Joined: 04/12/2002 Posts: 18102 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
16-02-2021, 21:10 Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues |
Is Windows Defender also not active? What does the Windows Event Viewer say?
Quote: |
Access to the event log is through the Event Viewer. First, press the key combination [Windows] + [R] to open the Run dialog. Then, in the Run dialog, type the command eventvwr. |
Translated on 19-09-2026, 2:24.
Profile PM WWW Garage |
topf20
16-02-2021, 22:47 Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues |
You're welcome, vag-driver.
That would be a real shame if it's due to Windows 7.
I only use the PC for diagnostics, so should I buy a completely new operating system for that? I'm still considering whether to reinstall Windows 7.
Thank you, Rainer.
Interesting point.
I once marked the folders "Kaufmann" and "Ross-Tech" as excluded files in Defender, but unfortunately, it didn't work.
Regarding the event log: Well, it's all full, and I don't know where to look. I tried starting the chart and searching for entries at that time, but it doesn't seem to show anything.
Translated on 19-09-2026, 2:26.
16-02-2021, 23:32 Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues |
Reinstalling Windows 7 is a good starting point. Furthermore, a Windows 10 activation key can be purchased for under 20€. Viele Grüße
Andreas
Herbert Profi-Schrauber
16-02-2021, 23:57 Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues |
Ross-Tech also writes about the possible error messages that can appear in VC Scope:
https://www.ross-tech.com/vag-scope/
Sure, here's the translation:
**Quick instructions, specifically points 1 and 2.**
Herbert. Horch A4 8K CJCD
Translated on 19-09-2026, 2:27.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2402 Karma: +438 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
17-02-2021, 9:32 Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues |
Dangerous half-knowledge:
I believe that a Windows 7 key is still sufficient to activate Windows 10, which means that a new purchase should not be necessary.
Guste.
Translated on 19-09-2026, 2:28.
Profile PM Garage |
17-02-2021, 9:46 Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues |
guste100 wrote: | Dangerous half-knowledge:
I believe that a Windows 7 key is still sufficient for activating Windows 10. | That means a new purchase should not be necessary. https://www.chip.de/news/Windows-10-kostenlos-Windows-7-Gratis-Update_127005018.html
Upgrading from Windows 7 to Windows 10 is still possible even today with a valid product key.
} Viele Grüße
Andreas
topf20
17-02-2021, 17:18 Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues |
Hello.
I once tested a laptop with Windows 7 (which, by the way, had FreeAV installed) and only installed VCDS without KDataScope. In this setup, the diagram even works without KData or VcScope.
It seems there's probably something wrong with my workshop PC running Windows.
Let's see if I can find the error, or if it's easier to just start over.
Translated on 19-09-2026, 2:29.
17-02-2021, 17:43 Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues |
The VC-Scope distributed with VCDS version 20 is no longer compatible with 32-bit systems. Which version of Windows 7 are you using, and what hardware are you running it on?
The simplest solution is probably to take VC-Scope from an older version.
Translated on 19-09-2026, 2:30.
17-02-2021, 17:56 Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues |
topf20 wrote: |
Let's see if I can find the error or just "simply" recreate it. |
Save yourself time and rebuild the system. Then you'll have a solid foundation again. Viele Grüße
Andreas
Translated on 19-09-2026, 2:31.
topf20
17-02-2021, 18:38 Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues |
Yes, I now believe it's due to the old 32-bit computer.
"In any case, the file located at C:/RossTech/VCDS-DRV/VCScope cannot be opened, and I receive an error message indicating that the program requires 64-bit architecture."
Thank you for your support.
I'm looking for a 64-bit computer.
Translated on 19-09-2026, 2:32.
