brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
dieselschrauber likes this. |
14-07-2015, 20:09 Subject: Wood chips in diesel filter - TPI? |
Hello everyone,
Does anyone know of a TPI (Technical Product Information) that justifies the presence of metal shavings in a diesel filter?
brezelmann01 Audi A3 Sportback [8PA], 2.0 TDI CR [CFGB], STH mit FB
alevuz Schrauber
Joined: 11/27/2011 Posts: 113 Karma: +32 / -0 Location: Tirol
15-07-2015, 19:25 Subject: Wood chips in diesel filter - TPI? |
Hello...
Not good... the cam lobe in the CR pump must have failed.
Similar to the (some) 3.0 TDI engines...
If someone doesn't cover the cost of this disaster, it will be VERY expensive!
Have you ever accidentally put the wrong fuel in your car?
The shavings are usually everywhere, in the tank, in the rail, in the injectors... so everything needs to be replaced.
Greetings.
Alevuz. Golf V 2.0 TDI - 4motion (BKD) im Ruhezustand mit >500Tkm
Touareg V10 TDI (AYH)
vwSchrauber Profi-Schrauber
17-07-2015, 12:50 Subject: Wood chips in diesel filter - TPI? |
Have you ever considered that they might come from the gear pumps in the gas station pumps?
I once observed this with canisters used to transport diesel fuel from the gas station. selber schrauben - statt Werkstattpfusch
17-07-2015, 13:44 Subject: Wood chips in diesel filter - TPI? |
AAAAAAAAAAAAAAAA
Now I see these DIESEL filters.
My brain had always read "DIESEL PARTICULATE FILTER" and wondered how on earth he managed to get there and why someone would look there first.
"Contamination at the gas station (and its supply chain) sounds like a fitting description to me."
m; Transparency, Teamwork
Profile PM Garage |
Autoservice Profi-Schrauber
17-07-2015, 15:52 Subject: Wood chips in diesel filter - TPI? |
Quote: | | The shavings are then normally everywhere, in the tank, in the rail, in the injectors... so everything has to be replaced... |
.... which, from a business perspective, would justify replacing the entire vehicle instead of repairing it.  LG, Onkel BM
17-07-2015, 21:14 Subject: Wood chips in diesel filter - TPI? |
But does anyone know anything about TPIs in this area? I had read about it in another forum and was surprised. Audi A3 Sportback [8PA], 2.0 TDI CR [CFGB], STH mit FB
alevuz Schrauber
Herbert Profi-Schrauber
19-07-2015, 9:18 Subject: Wood chips in diesel filter - TPI? |
The term "chips" itself is somewhat unclear. Are there any images and material data available for these chips? And what about the internal workings of a pump that has been identified as the cause?
Wear and tear would be more understandable in the case of a pump.
Were perhaps poorly manufactured fuel filters installed?
Herbert. Horch A4 8K CJCD
20-07-2015, 11:55 Subject: Wood chips in diesel filter - TPI? |
Quote: | If that were the case, the pump at the gas station probably wouldn't be working for much longer! (With such a high level of wear and tear.)
Furthermore, it's likely that lightning strikes someone who happens to be at the gas station at that very moment. |
It's not as unlikely as it seems. "On various Volkswagen TDI models, metal shavings have occasionally been observed shimmering in the fuel tank when illuminated."
They were so large that they wouldn't have fit through the OUT screw of the VE (vehicle). selber schrauben - statt Werkstattpfusch
10-03-2017, 20:56 Subject: Wood chips in diesel filter - TPI? |
Hello!
Today, I'm doing my second Difi filter change, about 70,000 km after my first one. Last time, I had clear metal shavings in the filter housing. This time, there are absolutely no shavings in the housing. So, those shavings probably came from outside last time. The filter itself was anthracite-colored, and there was a slightly reddish coating on the plastic lid, which looked almost like rust particles (perhaps from the fuel tanks at gas stations?!).
What caused a few problems this time was bleeding the system.
The fuel level was just above 1/4.
Using VCDS, I first tried the "initialization" function, specifically the "first fill" option, but it was not accepted.
Then, during the actuator diagnosis, the fuel pump in the tank and the auxiliary fuel pump were alternately activated. Nevertheless, the engine only started after about 30 seconds of sputtering. What could I have done differently?
Brezelmann01 Audi A3 Sportback [8PA], 2.0 TDI CR [CFGB], STH mit FB
21-03-2021, 11:44 Subject: Wood chips in diesel filter - TPI? |
Hi!
Installed the third filter yesterday. Mileage: 190,000 km. No wood shavings present. The filter color is anthracite, with a very slight reddish tint on top, as described previously.
I performed the bleeding process as I did last time, but this time I pre-filled the filter housing with approximately 0.3 liters of fresh diesel. It then started up completely uneventfully after the pump was activated.
The correct combination seems to be pre-filling plus pump activation controlled via VCDS.
Joined: 04/12/2002 Posts: 18103 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
21-03-2021, 12:24 Subject: Wood chips in diesel filter - TPI? |
Hello.
brezelmann01 wrote: | Hi!
Installed the third filter yesterday. Mileage: 190,000 km. No splinters whatsoever | .
Thank you for the feedback!
So, you haven't repaired anything other than replacing the diesel filter each time?
I still don't understand where the wood shavings came from.
Profile PM WWW Garage |
21-03-2021, 12:40 Subject: Wood chips in diesel filter - TPI? |
Exactly. It's working perfectly and without any errors. I suspect the shavings actually came from the fuel storage tank, or (more unlikely) the manufacturing process.
LG
Wibbing
Joined: 05/09/2021 Posts: 20 Karma: +12 / -0 Location: RheinMain
09-05-2021, 11:59 Subject: Many filters are not uncommon |
Hello Bretzelmann,
After I once had a new fuel filter with a hole in it (and the worm that had eaten the hole was even still inside), I now examine all the filters very carefully before I install them. The filter with the hole was even a "part that had been tested for use in aviation".
Best regards.
Grandpa Lothar.
P.S.
As someone who openly struggles with dyslexia, I'm not entirely sure about the number of "F"s. Macan, 964-4, Alhambra, Duster
Diesel:Transit 2012 2,2l 140PS
Früher u.A. auch:
Lloyd Alexander TTS,
VW Käfer,1500,T2,Passat,Gölfe,
Audi 72 ,75 ,200Q, S4, Ro80,
Ford 12M, 15M, Glas 1700,
BMW V8,2000, Mini,
Opel Rekord,Kadet,Kapitän,
Benz 180,190,219,220s,
Isabella TS, Kombi, Coupe,
Fiat 850,125,128 C, Ducato244,
Lancia Delta C, Simca Ariane,
Ente, R4, R5, Dacia MCV,
