Hi again,
Normally, the vehicle, engine with its associated components, and control unit are designed to work together. The manufacturer provides a specific part number (STG) for this combination.
You have equipped your vehicle with a different engine, and therefore you must
also use the appropriate ECU (Engine Control Unit). You can determine whether a particular ECU is compatible with the AFN engine more easily by looking at its origin, rather than searching for part numbers.
Beim Suchen im weiten Netz findest Du sicher auch Listen, welches STG wo mit dem AFN verbaut wurde. Hard work.
