Audi A2 Throttle Body, cannot set default settings
Rocksound
Post18-10-2021, 18:40    Subject: Audi A2 Throttle Body, cannot set default settings Quote
Hello everyone,
I have a problem with an Audi A2 engine, engine code BBY.
The throttle lever does not allow for the default setting.
When I perform a test with the actuator, the valve opens and closes properly. However, when I control it with the measurement block 60, it only vibrates slightly and opens minimally. Shortly thereafter, an error message appears.
I'm trying to upload a video, as well as some pictures of measurement block components.
Best regards, Daniel
Audi A2 Throttle Body, cannot set default settings - 20211018_184433.mp4
 Hier noch die Klappe bei der Stellglieddiagnose
 File size:  5.42 MB
 Viewed:  2456 times
Audi A2 Throttle Body, cannot set default settings - 20211018_172817.mp4
 So sieht es am Diagnosegerät aus, bei der Grundeinstellung
 File size:  4.33 MB
 Viewed:  2358 times
Audi A2 Throttle Body, cannot set default settings - 20211018_172747.mp4
 So macht es, wenn man die Klappe grundeinstellen will
 File size:  4.65 MB
 Viewed:  2323 times
 Gaspedal ganz durchgetreten, sind da 78% ok ?
 File size:  5.79 MB
 Viewed:  2479 times
 Gaspedal in Ruhestellung, passt da der Wert 14% ?
 File size:  5.07 MB
 Viewed:  2642 times
 Gaspedal ganz durchgedrückt
 File size:  6.59 MB
 Viewed:  2472 times
 File size:  6.2 MB
 Viewed:  2485 times
Post19-10-2021, 18:33    Subject: Audi A2 Throttle Body, cannot set default settings Quote
yes, we don't know, so we use VCDS here. The forum also generates revenue with it.
Following is a guide for VCDS:
Train the throttle lever for gasoline engine Audi, Seat, Skoda, VW.
Best regards, Rainer
Rocksound
Post19-10-2021, 19:16    Subject: Audi A2 Throttle Body, cannot set default settings Quote
Okay, so.
Yes, it works the same way as in the instructions.
It is also possible that this is due to the fact that the error code P1581 "Base setting not performed" is stored in the fault memory. This, however, cannot be deleted as long as it is not linked icon_smile.gif.
Greetings
Karma: +645 / -0   Thank you, like it!
dieselschrauber likes this.
Post22-11-2021, 6:05    Subject: Audi A2 Throttle Body, cannot set default settings Quote
Use VCDS with a license, but there are often problems with "third-party devices".
My Autodia S101, which I use "occasionally", also sometimes refuses to function properly, and these issues can usually be resolved with the VCDS diagnostic system.
No new posts A4 Doku: Engine Control Not Connecting to WFS. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body V157 Fault, P3103 Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentary: Air vent nozzle cannot be closed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 6N Throttle Body Initial Adjustment Gasoline Engine Technology
No new posts Audi A5 throttle body Diesel Engine Technology
No new posts Parking Heater: Incorrect/Missing Initial Settings On-Board Diagnostics (OBD)
No new posts Brake Electronics: Incorrect or No Calibration On-Board Diagnostics (OBD)
