OBD2 Check: No Connection to VW T5 Multivan?
Can2021
Post09-07-2021, 6:44    Subject: OBD2 Check: No Connection to VW T5 Multivan? Quote
I'm trying to read error codes from a VW Multivan T5...
First registration: 07/2008.
KOBD2Check V1.90 Scan, 20210709-073844
http://shop.dieselschrauber.org/en
Reading vehicle information...
Reading error codes...
Surgery failed.
THANK YOU for your help...
Alex.
Translated on 21-08-2026, 15:05.
Post09-07-2021, 6:51    Subject: T5 Multivan: KOBD2Check connection issues? Quote
Can2021 wrote:
I am trying to read error codes from a VW Multivan T5...
Surgery failed.
Alex
Hello Alex,
It's quite likely that your VW T5 uses a K-line instead of a CAN bus for the OBD2 interface. The manufacturer's own diagnostic system probably runs over CAN, but that won't be helpful to you.
The preferred method for this vehicle would be VCDS:
https://shop.dieselschrauber.org/en/vcds-hex-v2-p-329.php
Translated on 21-08-2026, 15:07.
No new posts Automatic Transmission: No Rebuild Needed (01K-01F) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vagcom303: No Connection to 1Z B4 - Troubleshooting On-Board Diagnostics (OBD)
No new posts HEX-NET: No Wi-Fi connection On-Board Diagnostics (OBD)
No new posts VAG-COM fails to connect On-Board Diagnostics (OBD)
No new posts VAG COM: No Connection T5 2008 (German) On-Board Diagnostics (OBD)
