Motorcycle ECU Programming: How To Guide
jörg schmidt
Karma: +21 / -0   Thank you, like it!
Post10-07-2021, 19:00    Subject: Motorcycle ECU Programming: How To Guide Quote
Hello everyone,
I didn't find anything about motorcycles here, but maybe this is a starting point.icon_smile.gif
Does anyone here have the equipment to flash/reprogram an ECU? Specifically, I'm talking about a GSX-R 1000 K5 and I want to enable a quickshifter. I have no idea how this is done, or even if it's possible. All I know is that it *can* be done. The price quoted by the place I contacted was "a little" outrageous. At that point, I might as well just buy a complete solution.
If the question is considered inappropriate, I won't be offended if it's deleted.
Jörg.
Seat Ibiza 6L Sport ASZ EZ Mai 2003
>468000km -schweren Herzens verkauft
Seat Ibiza 6J FR CFHD EZ Mai 2015
>178000km
Fiat Ducato Kasten 2.3 Multijet
EZ 3.2011 >230000km
Translated on 14-08-2026, 19:00.
chli1976
dieselschrauber likes this.
Post11-07-2021, 7:08    Subject: Motorcycle ECU Programming: How To Guide Quote
Simply install the retrofit solution and you're done.
Will only the ignition or fuel injection be interrupted?
VCDS
Translated on 14-08-2026, 19:01.
jörg schmidt
Post11-07-2021, 11:18    Subject: Motorcycle ECU Programming: How To Guide Quote
That would be possible. There are several suitable systems available.
"I have something like that installed on my Speed Triple. It was a plug-and-play installation."
For the GSXR, a quickshifter isn't a priority because I rarely use the motorcycle. I can take my time finding a solution. The advantage with this bike is that the control unit can be programmed for a QS. Then all I need is the sensor as hardware to go with it.
Jörg
>178000km
EZ 3.2011 >230000km
Translated on 14-08-2026, 19:02.
chli1976
Post11-07-2021, 12:45    Subject: Motorcycle ECU Programming: How To Guide Quote
Please search for "Brix Motorsport".
VCDS
jörg schmidt
Post20-07-2021, 16:55    Subject: Motorcycle ECU Programming: How To Guide Quote
OK, thank you!
Jörg
>178000km
EZ 3.2011 >230000km
Translated on 14-08-2026, 19:03.
No new posts Coding the service interval display on Golf III Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AHK Coding On-Board Diagnostics (OBD)
No new posts TDI Golf 3: Unlock/Code GRA Functionality On-Board Diagnostics (OBD)
No new posts Coding the ABS control unit for a Polo 6n On-Board Diagnostics (OBD)
No new posts Automatic Transmission Coding: A6 C4 AEL On-Board Diagnostics (OBD)
