P0730: Incorrect Gear Ratio
kickpanther
Post12-08-2021, 21:21    Subject: P0730: Incorrect Gear Ratio Quote
Hello fellow enthusiasts, I'm stuck on a problem and could use some help. Maybe you can point me in the right direction?
I would be happy.
I am encountering the following error:
17114 - Gear/Transmission Monitoring.
P0730 - 35-00 - Incorrect gear ratio.
Mileage: 295,000 km
I would be grateful for any tips.
Passat 3B Systemscan.txt
 File name:  Passat 3B Systemscan.txt
 File size:  3.96 KB
 Downloaded:  575 times
Vielen Dank.
Gruß Kickpanther
Translated on 20-10-2026, 15:40.
Ich_Can_nix
Karma: +253 / -0   Thank you, like it!
dieselschrauber likes this.
Post12-08-2021, 21:49    Subject: P0730: Incorrect Gear Ratio Quote
Good evening.
Do you also have an error image for that error entry? Does the transmission shift normally?
The error can have several causes.
It is usually caused by old, contaminated transmission fluid.
However, there may also be a mechanical fault in the transmission. Stuck or jammed solenoid valves are also possible.
Has the transmission ever been flushed?
Michael.
Translated on 20-10-2026, 15:41.
kickpanther
Post12-08-2021, 22:10    Subject: P0730: Incorrect Gear Ratio Quote
The transmission shifts very harshly and late when you put it in "D" (drive).
To my knowledge, a flush/rinse has not yet been performed.
Vielen Dank.
Gruß Kickpanther
Translated on 20-10-2026, 15:42.
vag-driver
Post16-08-2021, 15:12    Subject: P0730: Incorrect Gear Ratio Quote
Then I would definitely perform at least one transmission fluid change. When was the last time it was changed?
Andreas
Translated on 20-10-2026, 15:43.
kickpanther
Post17-08-2021, 20:14    Subject: P0730: Incorrect Gear Ratio Quote
Unfortunately, there is no documentation available for this. We have owned the vehicle for approximately one year.
Best regards, Kickpanther.
Vielen Dank.
Gruß Kickpanther
Post17-08-2021, 21:02    Subject: P0730: Incorrect Gear Ratio Quote
Okay, let's assume the worst. Why don't you do the oil change now? It can't hurt with a long-life oil system, and it's definitely the cheapest option. It's something you can easily do yourself, and then you can see what happens next.
No new posts Audi A4/B5: Wrong ECU? Expert Advice. Diesel Engine Technology
This topic is locked, you cannot edit or reply. Turbo Failure: Oil Issues & Engine Damage? Diesel Engine Technology
No new posts Control panel input not responding, possible faulty diagn... On-Board Diagnostics (OBD)
No new posts Rough idling when accelerating; incorrect PD element?? Diesel Engine Technology
