chris
Joined: 11/05/2019 Posts: 8 Karma: +0 / -0 Location: wien
20-08-2021, 1:10 Subject: DPF soot mass measured as too high |
Hello from Vienna.
The filter in my 2012 Q7 4L 3.0L was flushed by a company that specializes in DPF cleaning.
A regular train journey was conducted.
*The differential pressure sensor was recalibrated (and the lines were also cleaned).
*then adjusted to 30,000 km (on the safe side, since it's not new).
So the question is:
The measured black carbon mass is very high, as shown in the image.
I've had some before, but never experienced this kind of problem!
Address 01: Engine Control Module (J623-CJMA) Label file: . DRV\059-907-401-V2.clb
Part number SW: 4L1 910 401 J, Part number HW: 4L0 907 401 C.
Component: 3.0TDI EDC17 H37 0002
Revision: 53H37--- Serial number:
Encoding: 2A2A4012A52601020000
Operating number: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114L1910401J 001002
ROD: EV_ECM30TDI0114L1910401J.rod
VCID: 2A62990C4D4BF81AAB-807E
| Description: |
| File size: |
8.34 MB |
| Viewed: |
5421 times |
| Description: |
| File size: |
353.33 KB |
| Viewed: |
4363 times |
matthiasTDI96 Profi-Schrauber
dieselschrauber likes this. |
20-08-2021, 5:41 Subject: DPF soot mass measured as too high |
Okay, I don't really see anything seriously wrong here. The pressure is building up (both theoretically and practically, measured by the interpolated pressure drop, which is why there's an offset during the learning phase) until it regenerates. Since the regeneration, you seem to have driven approximately 400 km.
As soon as the next regeneration cycle begins, the coal will be burned to ash.
Herbert Profi-Schrauber
20-08-2021, 6:02 Subject: DPF soot mass measured as too high |
The measurement, which involved a 400 km driving distance since the last regeneration, was taken before the flush. I wouldn't have seen anything there either; even during the ash loading, there wasn't a reason to flush the DPF.  370 ml is the limit, isn't it?
The soot level in the second image seems a bit high, but it would be helpful to know if this is the first recording after a cleaning cycle, or if the system is now regenerating much more frequently. If so, the process continues with a recording of the differential pressure.
chris
20-08-2021, 7:24 Subject: DPF soot mass measured as too high |
Hello.
Thank you for the quick response.
The 370l figure is correct, but I didn't want to close it completely.
I'm afraid that the flush may have damaged it.
Because how does he immediately get such a high measured soot value?
That's not normal.
Normally, the measured and calculated values are almost the same, right?
I still have a B7 ASB with 120,000 km that needs regeneration every 800-1200 km.
The Q7 has always had around 300-400 kilometers on it since its last oil change, and I wanted to give it a fresh oil change now.
dieselschrauber and Herbert likes this. |
20-08-2021, 7:45 Subject: DPF soot mass measured as too high |
He simply calculates it based on the differential pressure parameter. There's an adjustment that depends on the load, and you've now specified that by entering approximately 30,000 km. I also experimented with the mileage values after the flush. I once achieved an optimum performance at 12,000 km.
How did I get here? I've repeatedly logged differential pressure readings during idle after regeneration, and I've also searched for data online. I then did some interpolation and arrived at a "very clean" differential pressure value after the flush. It seemed to fit well in my case. Do you have any data on that? If so, we can take a look.
chris
20-08-2021, 7:54 Subject: DPF soot mass measured as too high |
Thank you, thank you.
I'll be able to get to it again next week.
I'll take a few more logs and then report back.
Best regards, Chris.
20-08-2021, 8:03 Subject: DPF soot mass measured as too high |
Hello.
Quote: | | The Q7 has always had around 300-400 km since its last oil change, and I wanted to give it a flush this time. |
Never touch a running system.
I am still missing some basic information about the vehicle, such as the mileage, etc.
As long as the regeneration process occurs at reasonable intervals and is successful, and the pressure difference does not become too high, I see no need for action.
Sure, I'd be happy to translate the text for you. Please provide the text you would like me to translate from German to English.
Okay, I'm ready. Please provide the German text you want me to translate.
Profile PM WWW Garage |
chris
21-08-2021, 1:27 Subject: DPF soot mass measured as too high |
hi
You're right, but I've had some issues with loading before, and then encountered problems.
Just for your information, here are the data and another log entry from today.
Is the differential pressure reading okay?
| Description: |
| File size: |
7.08 MB |
| Viewed: |
1031 times |
| Description: |
 Download |
| File name: |
Log-WAUZZZ4L8CD036437-189330km-Q7 scan 29.5.2021.txt |
| File size: |
13.4 KB |
| Downloaded: |
351 times |
22-08-2021, 17:56 Subject: DPF soot mass measured as too high |
Yes, the differential pressure looks good.
chris
22-08-2021, 21:58 Subject: DPF soot mass measured as too high |
I agree.
But the measured soot mass is too high, isn't it?
I don't understand how he arrived at that value so quickly.
23-08-2021, 5:42 Subject: DPF soot mass measured as too high |
Quote: | | The soot loading in the second image seems a bit noticeable, but we would need to know whether this is the first recording after the cleaning process, or whether regeneration is now happening much more frequently. |
Is it being regenerated more often now? What were the testing conditions, and what were the air mass and boost pressure values during the differential pressure measurement?
23-08-2021, 5:57 Subject: DPF soot mass measured as too high |
There are also over 183,000 km since the last regeneration... perhaps there's some confusion. Drive until the next regeneration cycle, or initiate one manually and then observe the new cycle.
vag-driver Profi-Schrauber
23-08-2021, 13:13 Subject: DPF soot mass measured as too high |
What exactly was done during the flushing process? I hope no additives were added. For me, there is only one reliable method to have this done: [url][/url]https://www.russfilterreinigung.de{MARKER}.
Andreas
