TDI AHU: Turbo Oil Return Line Replacement
bindpe
Karma: +5 / -2   Thank you, like it!
Post07-05-2023, 13:26    Subject: TDI AHU: Turbo Oil Return Line Replacement Quote
Hello.
My Golf 3 TDI with the AHU engine has never let me down in the last 400,000 km, and I want to keep it that way. All the hoses and lines are still original, so I figured it's time to replace them.
Regarding the TL (presumably a specific vehicle or component), I wanted to replace the oil return and supply lines. Is it possible to do this with the component still installed?
Does anyone have any tips for me on the best way to do this without stripping any screws?
Thank you.
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 25-09-2026, 6:22.
Karma: +1355 / -0   Thank you, like it!
dieselschrauber likes this.
Post07-05-2023, 14:36    Subject: TDI AHU: Turbo Oil Return Line Replacement Quote
All the hoses and pipes are still original, and I wanted to finally get around to replacing them.
At the TL, I wanted to replace the oil return and supply lines,....
"Why? Are the pipes rusted?"
Translated on 25-09-2026, 6:23.
bindpe
Post07-05-2023, 16:50    Subject: SEO: Best German to English Translation Services Quote
Not yet.
But the return line doesn't look very reliable anymore.
I also sometimes drive 600 km non-stop in this car, and I don't want to be stranded on the side of the road. I simply want to continue to have the maximum reliability.
I guess if it broke, it was probably due to the turbo.
vg
Spritmonitor.de
Translated on 25-09-2026, 6:24.
Karma: +805 / -0   Thank you, like it!
Post07-05-2023, 17:00    Subject: SEO: Best SEO Agency | Top SEO Services Quote
bindpe wrote:
not yet.
I also sometimes drive 600 km non-stop in this car, and I don't want to get stranded on the road. I simply want to continue to have the maximum reliability.
vg
Hi.
If the line were to "tear," the mechanical stress wouldn't be your biggest concern.
If it looks very worn out, you will eventually lose engine oil from it. icon_idea.gif
Translated on 25-09-2026, 6:26.
bindpe
Post07-05-2023, 18:04    Subject: TDI AHU: Turbo Oil Return Line Replacement Quote
Hello Rainer,
"How do you mean 'in the event of a detachment,' the cable would be your least problem'?"
Spritmonitor.de
Translated on 25-09-2026, 6:27.
Herbert and E30_V8 likes this.
Post07-05-2023, 19:21    Subject: TDI AHU: Turbo Oil Return Line Replacement Quote
bindpe wrote:
Hello Rainer.
How do you mean "in the event of a detachment," the line would be your least problem."
If the turbocharger is still bolted to the cylinder head, the hose cannot "break off". icon_wink.gif
bindpe
Post08-05-2023, 5:34    Subject: TDI AHU: Turbo Oil Return Line Replacement Quote
Okay, don't panic, but it looks like the pipe connections might be coming loose.
Spritmonitor.de
Translated on 25-09-2026, 6:28.
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CDI: Air in Fuel Line? Diesel Engine Technology
No new posts ESP Flow Rate: How to Calculate & Optimize Diesel Engine Technology
No new posts Clear Lead: How to Gain and Maintain It Diesel Engine Technology
No new posts Check Valve for Radiator - Diesel Heater Part Diesel Engine Technology
