VW Phaeton 3.0 TDI Engine: CARA Code Details
tobir2501
Post27-10-2021, 19:40    Subject: VW Phaeton 3.0 TDI Engine: CARA Code Details Quote
Hello fellow DIY enthusiasts,
Two weeks ago, my high-pressure pump failed, "eating" itself and leaving debris throughout the entire system.
I've replaced everything that needs to be replaced, except for the high-pressure pump.
The crankshaft and the right camshaft are aligned to TDC, but where should I align the high-pressure pump?
Thank you very much.
Translated on 27-09-2026, 0:17.
tobir2501
Post28-10-2021, 8:39    Subject: VW Phaeton 3.0 TDI Engine: CARA Code Details Quote
I actually wanted to edit it, but I couldn't anymore.
Okay, maybe I didn't explain myself clearly. I have a tool for aligning the high-pressure pump. I bought a used pump, but how do I know when the engine is at top dead center (TDC) and how the used pump needs to be positioned? The alignment tool engages with the adapter plate on the engine.
Translated on 27-09-2026, 0:18.
Karma: +807 / -0   Thank you, like it!
Post28-10-2021, 14:40    Subject: VW Phaeton 3.0 TDI Engine: CARA Code Details Quote
tobir2501 wrote:
I actually wanted to edit it, but it's no longer possible.
OK, maybe I didn't express myself clearly. I have a tool for aligning the HD pump. I bought a used one, but how do I know when the engine is at TDC (Top Dead Center) and how the used pump needs to be positioned? Because the alignment tool engages with the adapter plate on the motor.
Before removing the old pump, simply check how it's positioned relative to the alignment tool and mark it with a marker.
Mark first, then unscrew.
It's definitely worth getting the corresponding repair manual from Erwin.
Translated on 27-09-2026, 0:19.
No new posts Phaeton Repair: 3D2 Seat Wiring Issue Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Phaeton Noise: Front Axle 3D2 Diagnosis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 3.0 TDI V6 VW Phaeton Engine Code CARA Diesel Engine Technology
This topic is locked, you cannot edit or reply. VW Phaeton: P0299 Turbo Boost Problem & Power Loss Diesel Engine Technology
No new posts Audi A3 BMN Engine: Cold Start Problems Diesel Engine Technology
No new posts Audi 80 1.6 TD (Motorcode SB) - Significant Power Loss Diesel Engine Technology
