tobir2501 wrote: |
I actually wanted to edit it, but it's no longer possible.
OK, maybe I didn't express myself clearly. I have a tool for aligning the HD pump. I bought a used one, but how do I know when the engine is at TDC (Top Dead Center) and how the used pump needs to be positioned? Because the alignment tool engages with the adapter plate on the motor. |
Before removing the old pump, simply check how it's positioned relative to the alignment tool and mark it with a marker.
Mark first, then unscrew.
It's definitely worth getting the corresponding repair manual from Erwin.
