Octavia: Resetting the ECU clock/date
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Dampfi
Post08-02-2022, 21:08    Subject: Octavia: Resetting the ECU clock/date Quote
I've checked the logs and noticed that the timestamps/dates vary significantly across all control units.
Therefore, my question is: How can I correct this or synchronize it with the computer's time?
Is there possibly a "time server" in the system?
Thank you for your help.
Translated on 19-07-2026, 22:00.
Post09-02-2022, 21:33    Subject: Octavia: Resetting the ECU clock/date Quote
Good question. Speculation: I suspect the instrument cluster sets the time on one or more CAN buses.
It should work automatically if the clock in the instrument cluster is set correctly.
Translated on 19-07-2026, 22:01.
vag-driver
Post09-02-2022, 22:37    Subject: Octavia: Resetting the ECU clock/date Quote
dieselschrauber wrote:
I suspect that the instrument cluster sets the time on one or more CAN buses.
That is definitely not the case, as I have already observed this on several vehicles.
I doubt there is a conductor.
Andreas
Post10-02-2022, 15:59    Subject: Octavia: Resetting the ECU clock/date Quote
You can find the mileage, date, and time in CAN ID 0x7D0 on the CAN drive. For example. I suspect this information is also of interest to other control units that are not directly connected to the CAN drive.
This is at least the case with vehicles that have an EDC17 system. icon_wink.gif
"LG" translates to "Best regards" or "Sincerely" in English. It is a common abbreviation used at the end of emails and letters.
Translated on 19-07-2026, 22:02.
No new posts EDC15 Steuergeräte, Software updatefähig Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf IV / Octavia 1 Water ingress at the doors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wirres Datum/Uhrzeit im Fehler On-Board Diagnostics (OBD)
No new posts 130 HP Engine: Upgrade from 30 HP Now! Diesel Engine Technology
No new posts Reset ash mass to 0 On-Board Diagnostics (OBD)
No new posts Set readiness Gasoline Engine Technology
