Audi A6 Vp44 issues after pump replacement
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Consulting
Post23-12-2022, 20:35    Subject: Audi A6 Vp44 issues after pump replacement Quote
Good evening, everyone.
I've been reading this forum for a while now, and I've reached a point where I'm stuck. I bought an Audi A6 Allroad with a faulty fuel pump. The Audi has a 2.5 TDI engine with the engine code BAU, manufactured in December 2004. I bought a new VP 44 fuel pump from Bosch and installed it. After that, the car wouldn't start because the immobilizer was active. To save myself some trouble, I sent the engine control unit (ECU) to a programmer, who deactivated the immobilizer and the pump lock. At that time, I thought I could bypass the immobilizer because I wouldn't have the immobilizer login code anymore. Today, I installed the ECU, and the car started right up. However, I'm getting a lot of error messages, and it feels like all the other control units remain deactivated even with the engine running. For example, the Airmatic system isn't working at all. Unfortunately, I currently only have a basic diagnostic tool, and the following error messages are displayed in the engine control unit's memory:
- Databus error in the powertrain.
- Engine control unit locked.
- Powertrain: No communication from the steering column module.
I have already contacted the programmer, and he tested my data on a control unit and could not find any problems.
My question is, does the new pump definitely need to be coded? Are there any people here who can help me, for example, with reading the WFS log and configuring the pump? I would also like to buy VCDS. The Audi was working perfectly fine before. Thank you for your help.
Sure, here's the translation:
'P.S. I'm from 44235.'
 File size:  62.96 KB
 Viewed:  1867 times
Post24-12-2022, 10:54    Subject: Audi A6 Vp44 issues after pump replacement Quote
Okay, I will translate the text. Please provide the text you want me to translate from German to English. I will only provide the translation, without any explanations.
and
Consulting
Post24-12-2022, 12:14    Subject: Audi A6 Vp44 issues after pump replacement Quote
Hey Diesel Mechanics,
Thank you for your links. I will calibrate and test the pump.
chli1976
dieselschrauber likes this.
Post25-12-2022, 10:38    Subject: Audi A6 Vp44 issues after pump replacement Quote
Then, the person who unlocks the immobilizer should also provide the login information, provided they have stored it in the EEPROM and not in the flash memory.
VCDS
Consulting
Post25-12-2022, 18:30    Subject: Audi A6 Vp44 issues after pump replacement Quote
Hey, I received the login information from the programmer and am now waiting for my vcds order.
Consulting
Post27-12-2022, 12:25    Subject: Audi A6 Vp44 issues after pump replacement Quote
I have calibrated the pump, but nothing has changed. Could it be that my engine control unit (ECU) is possibly defective? Are there any people in this forum who can check that? Here is my current error log.
 File size:  450.1 KB
 Viewed:  536 times
Karma: +645 / -0   Thank you, like it!
Post27-12-2022, 16:54    Subject: Audi A6 Vp44 issues after pump replacement Quote
Hi.
Perhaps we can fix the existing errors as much as possible.
Post27-12-2022, 20:31    Subject: Audi A6 Vp44 issues after pump replacement Quote
Sorry, outdated version from the wrong provider.
"Purchased elsewhere" means:
https://shop.dieselschrauber.org/en/obd-support-key-p-112.php
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AKE won't start after pump replacement Diesel Engine Technology
This topic is locked, you cannot edit or reply. Pump Replacement Due to Flow Meter Issues Diesel Engine Technology
No new posts Pump replacement from an 81kW TDI engine Diesel Engine Technology
No new posts GRA Installation Issues: Troubleshooting Guide On-Board Diagnostics (OBD)
