Pump Nozzle Repair: Find a Reliable Service
MrMcFly79
Post30-12-2021, 14:54    Subject: Pump Nozzle Repair: Find a Reliable Service Quote
Hello everyone, does anyone know of a reliable provider where you can have your PD elements refurbished?
Tobias.
Translated on 09-09-2026, 17:08.
chli1976
dieselschrauber likes this.
Post30-12-2021, 20:23    Subject: Pump Nozzle Repair: Find a Reliable Service Quote
You can replace the injectors yourself, but after replacing them, you can't properly check their performance without the appropriate testing equipment.
VCDS
MrMcFly79
Post31-12-2021, 12:58    Subject: Pump Nozzle Repair: Find a Reliable Service Quote
"I just need to find out where to get the nozzles."
But I'd rather not deal with that.
I found the two shops.
https://www.diesel-technik-biberach.de
They would replace my components, either with Firad or Bosch, at a cost of about 100 euros per component.
Or https://dieselfixneuss.de/
They offer to replace the PD elements, and the cost is supposedly between 300 and 400 euros, using Bosch injectors.
I have no idea how realistic these prices are, but I think they might be sourcing the nozzles in such a large quantity that it could make sense.
And overtaking itself shouldn't be that difficult.
What do you think, are they reliable? The opinions online are mixed, but generally leaning towards a positive view of Biberach... although "Dieselfix" on eBay has 24,000 reviews and not a single negative one.
Translated on 09-09-2026, 17:09.
chli1976
Post31-12-2021, 14:25    Subject: Pump Nozzle Repair: Find a Reliable Service Quote
You can find nozzles at any Bosch service or accessory dealer. If I remember correctly, they cost around 30-50 euros each.
VCDS
Translated on 09-09-2026, 17:11.
Post15-01-2022, 16:58    Subject: Pump Nozzle Repair: Find a Reliable Service Quote
I wouldn't even disassemble PD elements myself, even just once.
"If you know how, it's not magic. However, to do everything correctly the first time, you often need specialized tools (which I built myself) and prior knowledge, depending on the component. Nevertheless, on my first attempt, I damaged the guide pins and more. That usually means it's the end of the road for DIYers..."
It's definitely worth having the tires changed and inspected for 1-2 cars, as the necessary investment wouldn't be worthwhile otherwise, and the risk of errors is high due to a lack of experience and practice.
MrMcFly79
Post15-01-2022, 20:48    Subject: Pump Nozzle Repair: Find a Reliable Service Quote
I probably wouldn't do it myself. But, as you say, it's probably not witchcraft... so it should be reasonably priced. At Bieberach, the overhaul costs around €400. I have another offer for over €1000.
What is realistic?
Translated on 09-09-2026, 17:13.
Post15-01-2022, 20:58    Subject: Pump Nozzle Repair: Find a Reliable Service Quote
It depends on what can be done and what is possible. After all, solenoid valves also have a certain degree of wear and tear.
Unfortunately, I am not familiar with either of those companies.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts Timing Chain Wear: Inspection & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pumpe Düse: Components & Overview Diesel Engine Technology
No new posts Pumpe-Düse vs. Common Rail: Differences Explained Diesel Engine Technology
No new posts Passat 1.9 TDI (AVF), Compatibility of Pump Nozzle Injectors Diesel Engine Technology
No new posts Integrated Pump Nozzle Elements - Questions. Prevention? Diesel Engine Technology
