Fuel Injection Deviation 2.5 TDI BDG - Out of Spec
Florian320
2004 Audi Cabriolet
Post21-03-2021, 14:09    Subject: Fuel Injection Deviation 2.5 TDI BDG - Out of Spec Quote
Hi!
I just took a short test drive. Actually, I was mainly interested in the generator load, but I thought I might as well log the idle speed at the same time.
Unfortunately, cylinder five was above the limit of 1.5mg per stroke.
Here are the values.
Would you try to find the cause of the problem, or is it acceptable as long as the car drives well otherwise?
It's also interesting that all the cylinders are showing a negative reading - could cylinder two potentially have a problem?
Florian.
Sunday, March 21, 2021, 12:59:41:63257
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: RKS 20.4.1.1
Data as of: 20200709 DS317.0
http://shop.dieselschrauber.org/en
Dealer/Workshop name: Florian Meppen.
Vehicle Identification Number:
License plate: HEI DU 35
Mileage: 171928. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Module (8E0 907 401 T)
12:59:27
766 /min Motor speed (G28)
82.5°C Coolant temperature (G62)
215.9 mg/H - Exhaust Gas Recirculation (Target Value)
215.9 mg/H - Exhaust Gas Recirculation (Actual Value)
14.21 V - Voltage (terminal 30)
-1.57 mg/H Injection volume deviation (Cylinder 3)
-0.63 mg/H Injection volume deviation (Cylinder 1)
-1.25 mg/H Injection volume deviation (cylinder 6)
-1.02 mg/H Injection volume deviation (Cylinder 4)
-2.20 mg/H Injection volume deviation (cylinder 5)
35.2% Generator load.
Translated on 24-09-2026, 2:49.
Post21-03-2021, 21:38    Subject: Fuel Injection Deviation 2.5 TDI BDG - Out of Spec Quote
Hello.
It's also interesting that all the cylinders are showing a negative reading - could cylinder two possibly have a problem?
Plausible. Are the auxiliary components and belt tensioners okay?
Do the injection quantity deviations also not migrate?
Consider this suspicious: The sum of all deviations from the norm is approximately zero. This may indicate a potential problem with cylinder 2. Are the camshaft and compression okay?
Possibly, the injector nozzle holes in cylinder 2 are also clogged with carbon deposits.
Translated on 24-09-2026, 2:54.
Florian320
2004 Audi Cabriolet
Post22-03-2021, 11:55    Subject: Fuel Injection Deviation 2.5 TDI BDG - Out of Spec Quote
Hello Rainer,
Thank you for your reply.
At least there's no noise coming from the auxiliary components; however, I would need to check the belt tensioner.
The engine has never been opened, not even the VDD (valve distribution device), which is why I unfortunately can't make any informed statements about the camshafts.
I almost exclusively use Aral Ultimate Diesel, but of course, an injector can still get clogged.
I suppose I'll probably have the compression checked, as that can be quite informative.
The idle stability has actually changed over time. Cylinder five was initially at -1.5mg per cycle and then, at some point, it shifted direction and went below -2, although it wasn't a continuous "drift," which might be helpful information.
The battery is quite worn and will be replaced soon, but I had fully charged it before running the diagnostic. Therefore, it shouldn't have any impact on the idle behavior, right? Also, the generator load wasn't particularly high.
Translated on 24-09-2026, 2:55.
Post23-03-2021, 6:28    Subject: Fuel Injection Deviation 2.5 TDI BDG - Out of Spec Quote
When I said "wandern," I meant whether the highest value shifts from one cylinder to another. Since the mechanics of the cylinders are unlikely to repair themselves or swap cylinders, this would indicate problems with the timing belt and auxiliary components.
Translated on 24-09-2026, 2:57.
Karma: +1354 / -0   Thank you, like it!
dieselschrauber likes this.
Post23-03-2021, 7:11    Subject: Fuel Injection Deviation 2.5 TDI BDG - Out of Spec Quote
The injector combination with the needle lift control is located on cylinder 2. Unfortunately, it is not possible to swap it with another cylinder (which would allow you to "move" the fault).
What you can do:
- Compression test to rule out mechanical faults;
- while simultaneously comparing the carbon buildup on the injector nozzles (by looking through the holes for the glow plugs);
- Remove the nozzle in question, clean it in an ultrasonic bath, and have its opening pressure checked.
I had a weak cylinder 2 on the 1Z engine, even with perfect compression, and I couldn't completely eliminate it, not even with a replacement injector.
Translated on 24-09-2026, 2:58.
Florian320
2004 Audi Cabriolet
Post23-03-2021, 7:49    Subject: Fuel Injection Deviation 2.5 TDI BDG - Out of Spec Quote
Best regards, Rainer
Thank you for the clarification, Rainer!
No, the values and their trends relative to each other remained constant. This likely argues against the use of a belt drive.
Translated on 24-09-2026, 3:00.
Florian320
2004 Audi Cabriolet
Post23-03-2021, 7:51    Subject: Fuel Injection Deviation 2.5 TDI BDG - Out of Spec Quote
What you can do:
Hello Herbert, thank you for the reply!
I plan to tackle that in the medium term. The engine is completely untouched except for the glow plugs and the dual-temperature sensor (okay, the timing belt, water pump, and related components were replaced as a precaution at 109,000 km). Accordingly, after seventeen years and a considerable 173,000 km, some parts might be starting to age.
I will let you know if I find anything out.
Translated on 24-09-2026, 3:01.
Florian320
2004 Audi Cabriolet
dieselschrauber and Herbert likes this.
Post06-02-2022, 20:21    Subject: Fuel Injection Deviation 2.5 TDI BDG - Out of Spec Quote
Hi!
Here's a quick update: I've already been to my friend, the car mechanic.
There, the largest outlier was 1.57 mg per injection, which was only slightly above the threshold.
Since the engine is running perfectly smoothly, doesn't require any oil, the fuel consumption hasn't changed, and the error memory was even empty, we decided to leave it as it is for now.
If anything changes in the way the engine is running, we'll need to investigate further, but at least my friend didn't see any reason to dig deeper.
If anything changes, I'll provide an update.
Florian.
Translated on 24-09-2026, 3:04.
Post06-02-2022, 21:08    Subject: Fuel Injection Deviation 2.5 TDI BDG - Out of Spec Quote
Thank you for the feedback!
Translated on 24-09-2026, 3:05.
No new posts Tire Size Tolerance: What You Need to Know Diesel Engine Technology
No new posts 1.2 TDI CWFA: Fuel Injection Problems & Solutions Diesel Engine Technology
No new posts Diesel Engines: Who Makes 90 HP, 1.9L Models? Diesel Engine Technology
No new posts Seat Altea 5P rear wiper out of order Electrical Systems, Vehicle Electronics, Multimedia
