Golf1989
Joined: 08/08/2021 Posts: 18 Karma: +2 / -0 Location: Mönchengladbach
08-08-2021, 16:26 Subject: Golf V Intake Manifold Flap - Airflow Control & P138 Error |
Hello community,
I have a Volkswagen Golf V GT Sport 2.0 TDI 170, manufactured in 2007, with engine code BMN.
This morning, I was driving and suddenly the yellow warning light started flashing, and the display showed "Engine fault - visit a workshop."
When I turn the ignition off and on again, the error disappears, but after a few hundred meters, it starts blinking again.
I once scanned the vehicle with VCDS, and it showed the following (see the images attached).
"Intake manifold flap for airflow control, P138."
I then cleared the error code, drove the vehicle once around the block, and then it started blinking again, and the error memory now shows:
"Is the air mass flow rate too low in regeneration mode?"
The car still drives and has power, but what could be the problem?
Update: I drove yesterday and today, and now none of the lights are flashing anymore.
Perhaps someone has some advice?
What I still wanted to know, because many people define it differently.
Is the intake manifold flap the part that sits in front of the EGR valve, essentially like a throttle valve, or is the intake manifold flap the swirl flaps?
I always get confused about that.
I would really appreciate your help.
| Description: |
| File size: |
188.94 KB |
| Viewed: |
1507 times |
| Description: |
| File size: |
167.53 KB |
| Viewed: |
1715 times |
| Description: |
| File size: |
198.35 KB |
| Viewed: |
1634 times |
| Description: |
| File size: |
191.26 KB |
| Viewed: |
1476 times |
Translated on 18-08-2026, 19:21.
Golfer5
Joined: 05/08/2022 Posts: 1 Karma: +0 / -0 Location: Düsseldorf
09-05-2022, 12:12 Subject: Golf V Intake Manifold Flap - Airflow Control & P138 Error |
Hello, has the problem been resolved yet?
I'm currently experiencing the same error.
Volkswagen Golf 5, 2.0 TDI engine code BMN.
Translated on 18-08-2026, 19:24.
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
10-05-2022, 9:28 Subject: Golf V Intake Manifold Flap - Airflow Control & P138 Error |
It's not a rare mistake  . You can buy a new throttle body, which is also available from independent retailers.
Profile PM WWW Garage |
Golf1989
dieselschrauber likes this. |
11-05-2022, 18:58 Subject: Golf V Intake Manifold Flap - Airflow Control & P138 Error |
Yes, the error has been fixed.
I removed the throttle valve and it was stuck, making it very difficult to open and close due to heavy carbon buildup.
I cleaned it, and then it started working again. However, I decided to buy a new one, and since then, everything has been quiet.
Translated on 18-08-2026, 19:25.
