Error code 00778 - Steering angle sensor (G85) on the Polo 9N3
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
stolley
Karma: +38 / -1   Thank you, like it!
Post28-05-2022, 12:40    Subject: Error code 00778 - Steering angle sensor (G85) on the Polo 9N3 Quote
Hello everyone,
Maybe you can help me.
I recently removed the dashboard from my Polo 9N3. Of course, this also includes the steering wheel and the steering column controls.
After I had reassembled everything, I received the following error message in the control unit for the brake electronics:
00778 - Steering angle sensor (G85), 005 - No or incorrect basic setting/adaptation.
My first thought was that I might not have properly plugged in the connector on the steering column switch. However, measurement block 005 already provides the correct steering angle.
I believe the steering knuckle is also not installed twisted.
If I try to perform the "Steering Angle Sensor Zero Offset Adjustment (G85)", I receive the error message "Block 001 not available".
An alternative solution is also described. However, I can't find the point "Steering angle sensor initialized/not initialized."
Can you help me? You're welcome!
dieselschrauber likes this.
Post28-05-2022, 17:23    Subject: Error code 00778 - Steering angle sensor (G85) on the Polo 9N3 Quote
"From my experience with Passat 3B models, I know that a specific procedure needs to be followed to calibrate the steering angle sensor, starting with pressing the brake pedal for a certain amount of time. Please look up this procedure for the 9N model."
And I once had to try countless times to get rid of all the error messages on a Passat 3C.
Karma: +440 / -0   Thank you, like it!
Post28-05-2022, 22:33    Subject: Error code 00778 - Steering angle sensor (G85) on the Polo 9N3 Quote
Didn't it just need to be driven a certain distance, reach both checkpoints, and then that would be it?
stolley
Post29-05-2022, 16:14    Subject: Error code 00778 - Steering angle sensor (G85) on the Polo 9N3 Quote
guste100 wrote:
Didn't it just need to be driven a certain distance, reach both ends, and then that would be it?
Yes, I just saw something similar in a YouTube video... I'll give it a try!
I'm just having the problem that my laptop no longer works wirelessly... so I need a long extension cord! icon_wink.gif
stolley
Post29-05-2022, 19:14    Subject: Error code 00778 - Steering angle sensor (G85) on the Polo 9N3 Quote
Ah, it seems VCDS is only necessary to initiate the pairing process.
The adaptation process can also be performed without a connected VCDS device. Just drive straight for a short distance, then turn the steering wheel fully to the right and hold it for a moment, then do the same to the left.
Thank you all for your tips!
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi S3 8V: Steering Angle Sensor Calibration On-Board Diagnostics (OBD)
No new posts A3 Steering Angle Sensor Problem: Diagnosis & Repair On-Board Diagnostics (OBD)
No new posts Steering Angle Sensor G85 Problem - Help! On-Board Diagnostics (OBD)
No new posts Coolant Temperature Sensor for VW Golf III Diesel Engine Technology
