Adjusting NW / Boundary PDEs after tuning
Go to page: 1, 2, 3, 4, 5  Next
Post31-08-2004, 13:49    Subject: Adjusting NW / Boundary PDEs after tuning Quote
Last weekend, while browsing for vacation ideas, I stumbled upon a thread where someone was discussing exploding pressure discharge valves (PDVs) in tuned engines. The explanation given (as a tangential topic) was that the PDVs were failing because their closing time was too short. The claimed burst pressure was 2500 bar.
Today, I can't find the topic either through the search function or by browsing the forum icon_question.gif icon_question.gif.
I don't remember the author either...
Actually, I wanted to quote this passage here, but that's not possible now.
I have not yet read any concrete and understandable explanation why the pressure in PDEs can increase without an increase in speed, i.e., only by increasing the opening duration.
The only explanation I can think of would be an increasingly steep angle of the injection cam throughout the entire stroke.
At low engine speeds, the injection occurs relatively late, specifically towards the end of the piston's stroke -> at this point, a large displacement per degree of crankshaft rotation does not yet generate an excessively high pressure.
At high speeds, the injection timing is shifted earlier (i.e., to the first lobe of the injection cam).
Since the pressure increases with the speed, the cam profile could be made flatter in the front area to prevent excessively high pressures.
If the opening duration is extended into the steeper cam lobe area for low speeds at high engine speeds, this would result in excessively high pressures during the injection of the tuning fuel additive.
In any case, the transition from the flat beginning to the steep end of the cam profile must be smooth, as the speed-dependent shift of the injection timing window also occurs smoothly.
This would result in the injection pressure being relatively low at the beginning of each injection process, gradually increasing towards the end (excluding the pre-injection and main injection phases).
That's my theory, as far as it goes.
Can anyone confirm or refute this?
If that is the case, why can a short closing duration of the PDEs lead to excessively high pressures?
loveme
Post31-08-2004, 21:13    Subject: Adjusting NW / Boundary PDEs after tuning Quote
Hello Ulf,
After reading your report about your adjusted NRR (Noise Reduction Rating), I also checked my own NRR.
Mine was exactly in the middle, within the tolerance range of the long hole!
Okay, so I thought I'd try something out and set the NR (noise reduction) to the extreme early setting, which, by the way, works perfectly with a small hand mirror.
Translation: "Following: the improved high-RPM performance in the upper rev range that you described."
Okay, here's a bit more: so I adjusted it a little further towards the front - so that half of the hole for the bolt disappeared - consequence: the car wouldn't even start!
So, the golden mean: 1/3 of the hole was already covered, and the car started!
Result: 5 km/h faster than the factory setting on my usual route up the hill on the highway (195 km/h uphill instead of the usual 190 km/h).
BUT: Fuel consumption at idle is 1.3 liters instead of the usual 0.6-0.7 liters without air conditioning.
and a loud engine noise or sound coming from the PDE units, as if they were about to explode.
That's why I'm now driving again right at the speed limit, heading towards the early hours!
What's the point of all this?
I thought this might help you understand the pressure conditions in the PD a little better, as the pressure seems to have increased here as well, but without any software tuning!
And before I get yelled at again:
My car is a Golf IV ASZ model year 2003, without any modifications.
Post31-08-2004, 21:38    Subject: Adjusting NW / Boundary PDEs after tuning Quote
loveme wrote:
Then I thought I would try something out and set the NR (noise reduction) to the extreme limit of the adjustable range, towards the "early" setting, which, by the way, works perfectly with a small hand mirror.
What specific setting do you consider to be the "absolute limit of what's possible," and how do you measure that value?
It couldn't have been a fluke, since you were still able to follow up with another shot.
So, now a little more: so, I adjusted it a little more towards the early position - so that half of the hole for the bolt disappeared - consequence: the car didn't even start!
This is certainly very interesting.
BUT: Fuel consumption at idle is 1.3 liters instead of the usual 0.6-0.7 liters without the air conditioning
It only displays the converted operating time. If he were actually injecting that much more fuel, the "idle" speed would be incredibly high.
This suggests that you've taken some of the normal fuel delivery for the idle speed, as the rising fuel delivery curve likely flattens out significantly while fuel is still being injected – which, in turn, is compensated for by a longer injection duration.
and the sound of the engine running or noises from the PDE's, as if they were about to explode right next to your ears.
Your report seems to confirm my initial suspicion about the "increasing flank angle" of the injection cams.
Thank you for your attempts and your post!
Do you also have DZR times for before and after?
As a potential future addition, it would be interesting to see if the nighttime fuel consumption, as measured by the MFA (Multi-Function Display), permanently changes due to the adjusted NW (likely referring to a navigation or control setting).
loveme
Post31-08-2004, 22:29    Subject: Adjusting NW / Boundary PDEs after tuning Quote
So, as the absolute limit, I would define the position where the NR (presumably a component or part) is placed, and the hole is still fully visible, meaning it's not partially covered, but the hole and the outer edge of the elongated hole are aligned.
(of course, all of this on the side facing towards the early hours). Still within the manufacturing tolerance!
"I used a small pocket mirror as a reference."
When the car stopped starting, I was likely outside the angular tolerance of the sensor for 1st cylinder detection on the camshaft. This means the deviation between the crankshaft and camshaft was too large! My guess!
"The 1/3 hole cover was probably just within the acceptable angular tolerance!"
I drove approximately 100 km with this setting, mostly at full throttle on the highway.
Then, out of fear of engine damage, I postponed it again.
That was probably too short a period to detect any discrepancies in the MFA's consumption.
What I also noticed is: the maximum consumption is > 3500 RPM. Gang was 13.0 liters.
under load, including when going uphill.
With a normal driving style, it was usually around 13.7 liters +/- 0.2!
But still, I was faster than usual! (+5 km/h uphill and +5 km/h downhill)
I can rule out factors like tailwind, as I conducted numerous test drives on that day with various possible settings, and I tested the routes twice in both directions.
Unfortunately, I didn't take the DZR test back then!
Subjectively, the peak torque at 1900 rpm felt a bit weaker, but it had more power at higher RPMs.
loveme
Post31-08-2004, 22:55    Subject: Adjusting NW / Boundary PDEs after tuning Quote
One more thing!
If you adjust the NR (Neutral Range) towards "late" (i.e., increase the tolerance for being late),
Then, the instantaneous fuel consumption while idling drops to 0.5 liters.
So, the pressure must have increased in this case, assuming...
that the same amount of fuel is needed to reach the idle speed.
Or could it be due to a reduced air mass?
What is the reason for the delayed opening of the intake valves?
Post01-09-2004, 8:30    Subject: Adjusting NW / Boundary PDEs after tuning Quote
loveme wrote:
So, as the absolute limit, I would define the position of the NR (Numerical Register), where the hole is still fully visible, meaning not partially covered, but the hole and the outer edge of the long hole are aligned.
As a control, I used a small mirror!
That is not an "official" indicator.
"On my engine, for example, the NW gear seems to be mounted one tooth later than it should be, meaning that I'm already at approximately 3/4 of the way through the elongated hole, which is the correct position for aligning the crankshaft with top dead center."
I drove approximately 100 km with this setting, mostly full throttle on the highway.
That was probably too short to detect any consumption discrepancies of the MFA.
Hmm... Is your "final new" setting different from the previous one (and if so, by approximately how many degrees Kelvin), so that after a few tankfuls, a change might actually be noticeable?
But what I also noticed: the maximum consumption is > 3500 RPM 6. Gang was 13.0 liters.
With normal settings, it was usually around 13.7 liters +/- 0.2!
I have also seen similar apparent differences at my location, even without changing any settings (!). Once, I even saw a reading of 13.9 liters on the display.
My opinion is that this is likely due to the fact that the maximum power is only achieved within a very narrow speed range around 1900-2000 RPM, and that the instantaneous power consumption is also averaged over a certain distance. Usually, the vehicle accelerates during the measurement, which means that lower "seconds consumption" values are recorded within the measurement interval.
The true maximum value would likely only be achieved on a slope where it takes at least 20 seconds to descend, or with the handbrake firmly applied.
Subjectively, the torque peak at 1900 rpm felt a bit weaker, but it had more power at the higher RPMs!
It's funny - I had the same feeling after adjusting my ovulation window from about 3 days late to the exact target value.
What we can hardly assess is the effect of the also altered valve timing icon_sad.gif.
It's possible that the altered engine noise is due to a shift in the timing of the intake air swirl, which also "wraps" around the fuel injection jet... ?
loveme
Post01-09-2004, 21:32    Subject: Adjusting NW / Boundary PDEs after tuning Quote
Hello Ulf!
Okay, based on my current understanding, here's how I calculated overtime:
Turn the engine forward until the notch on the flywheel aligns with the mark in the inspection window on the transmission.
Then rotate it 2mm further forward.
This is the setting where my car was out of time, specifically with the timing pin inserted at the bottom of the crankshaft.
It's a good thing to remember for all future adjustments, after you've checked it once.
Okay, and now set the NWR to the specified "maximum setting within tolerance," and let's proceed quickly!
If the notch on the flywheel were currently perfectly aligned with the mark in the inspection window, then everything would be off by those 2mm.
I have no idea how much 2mm on the flywheel translates to in degrees of KW, but I think it's probably less than 3 degrees, like in your car!
This is now the best setting for my needs.
The knocking sound at the top end has been relatively eliminated, at least for a diesel engine!
According to the MFA, the idling fuel consumption is also acceptable (0.7-0.8 liters)!
Since I have to commute approximately 100 km to work every day, I can't afford a high fuel consumption (whether the MFA is displaying the correct information is another matter).
After refueling and checking the mileage, it was found that the fuel consumption displayed by the MFA (Multi-Function Display) was always about 0.1-0.2 liters less than the actual consumption.
The maximum speed is quite impressive compared to other options!
According to the official specifications, it has 148 horsepower and 350 Nm of torque!
Post01-09-2004, 21:59    Subject: Adjusting NW / Boundary PDEs after tuning Quote
loveme wrote:
I have no idea how much 2mm on the timing wheel translates to in degrees of KW, but I think it's probably less than 3 degrees, like in your car!
Probably not... 1 degree on the balance wheel is approximately 2.5 mm, if I recall correctly.
This is now the best setting for my needs, because -
The tendency to stall at low RPMs has been relatively eliminated, at least for a diesel engine!
That's probably about 5° KW (kilowatt) too advanced. How does the engine sound now, compared to before?
After checking the fuel consumption after refueling, it was found that the MFA (Multi-Function Display) always showed approximately 0.1-0.2 liters less than the actual consumption!
Are these values reflecting data after the new hire was onboarded, or before?
According to the DZR, it has 148 horsepower and 350 Nm of torque!
Nisch is looking for a used, unmodified ASZ engine.
loveme
Post01-09-2004, 22:20    Subject: Adjusting NW / Boundary PDEs after tuning Quote
I'm a little confused right now!
2 mm on the flywheel correspond to approximately 1.5 degrees, okay.
Why should it then be 5 degrees too early?
Basically, everything is within the tolerance limits: the KW (rear axle) is within the specified range according to the bolt on the KWR (rear axle carrier), and the NW (front wheel alignment) is within the adjustable range of the elongated hole in the NWR (front wheel alignment rod).
After the new setup, the power consumption calculation is not the same as it was with the previous extreme setting, and it wasn't different even with the factory settings initially.
It doesn't sound any different compared to before!
Definitely much quieter than a 74kW D4 of the same year!
Ah, yes, AGR used to be...!
Post02-09-2004, 7:19    Subject: Adjusting NW / Boundary PDEs after tuning Quote
loveme wrote:
2 mm on the balance wheel correspond to approximately 1.5 degrees, OK.
Um. . . if 2.5 mm equals 1°, then 2 mm is more like 0.8°.
The 5-degree angle was a rough estimate based on your descriptions of the elongated holes near the northwest wheel.
Basically, everything is within the tolerance - the KW is aligned with the OT according to the bolt on the KWR, and the NW is within the possible adjustment range of the long hole in the NWR.
Hmm... To get a definitive answer, it would be interesting to hear about your "final" new position.
To do this, you would need to rotate the engine forward again to the Northwest (NW) timing mark and then tell me the position of the crankshaft relative to the Top Dead Center (TDC) mark – if it's possible and not too complicated for you.
The consumption calculation after the new setup is therefore not the same as the previous extreme setting, and it wasn't different even with the factory settings at the very beginning.
Ah, so, no (significant) changes in power consumption or noise levels.
Do you still have the DZR values with the old settings?
Has the final new setting maintained the impression of "better performance at the top end with a less pronounced torque surge around 2000 rpm" compared to the old setting?
btreyer
Post04-09-2004, 8:07    Subject: Adjusting NW / Boundary PDEs after tuning Quote
Regarding 'Exploding PDs'.
When you delve into the workings of engines, you'll notice that in tuning, the injection times are always extended, and this extension occurs in the direction of later timing.
The duration of the injection time determines the pressure within the element.
Simply put, the longer the valve is open, the higher the pressure becomes, because in the same amount of time, less fuel can escape through the nozzle relative to the compression.
One could, of course, influence the compression by adjusting the valve lift profile on the intake side, but to my knowledge, this is not done. It wouldn't make sense anyway, because if the injection timing were changed or adjusted, the pressure buildup in the pump nozzle would also be shifted.
Sure. Extremely long nozzle opening times result in extremely high pressures.
Greetings btreyer.
loveme
Post04-09-2004, 11:08    Subject: Adjusting NW / Boundary PDEs after tuning Quote
Hello Ulf!
Do you still have any DZR values with the old settings?
Unfortunately, I don't have any old DZR documents, as I only started dealing with them later.
I'm going to test various settings today and document them using a digital recording device.
I will report the results here later.
With the final new setting, has the impression of "better performance at the top end with a less pronounced torque bump around 2000 rpm" remained compared to the old setting?
It's hard to say, as it's been over half a year since I last used the factory settings.
What I can say is that the handling is better in the higher RPM range (above 3500).
As I said, this is always just my subjective impression!
Perhaps my new DZR measurements will provide more insight.
Mfg, loveme
OCTAVIA RS 2.0 TDI Bj.2019, DJGA
Post04-09-2004, 11:45    Subject: Adjusting NW / Boundary PDEs after tuning Quote
btreyer wrote:
The length of the injection time determines the pressure in the element.
Simply put, the longer the valve is activated, the higher the pressure, because in the same time unit, less fuel can escape through the nozzle in relation to the compression.
Hmm, that sounds logical at first glance.
But as the internal pressure increases, so does...
1. The flow rate through the nozzle holes = Injection rate (mg / °KW)
2. the outflow due to leakage losses within the PDE (Positive Displacement Element).
so that, in my opinion, a balance would have to be established between higher pressure and higher flow.
However, if the PDE is designed in such a way that establishing this equilibrium takes "some time" (on the order of milliseconds) and the injection is terminated in the serial state before this equilibrium is reached , then your argument would be correct.
Diagrams in the yellow Bosch PD manual seem to confirm this:
After that , the injection pressure not only increases with the engine speed, but also with the injection quantity , i.e., during the nozzle opening time.
-> Thank you for your answer - I think it provides the explanation icon_smile.gif
It would also be interesting to know, from what engine speed and fuel injection quantity (for the various PDE sizes), the critical pressure limit of 2500 bar is reached.
loveme
Post04-09-2004, 15:15    Subject: Adjusting NW / Boundary PDEs after tuning Quote
I just did some DZR (Direct Injection Retrofit) test runs with different camshaft settings.
The result of the DZR is astonishing!
Okay, let's start with the values:
Golf 1J with ASZ engine (completely stock!!!)
Weight included. Driver: 1377 kg (unladen weight determined using a calibrated scale!)
Trip 1: Settings as usual, i.e. NW on OT + KW on OT!
The reading on the flywheel scale is 2mm before the marking in the direction of rotation , which exactly corresponds to the precise timing setting with the timing pin on the crankshaft pulley!
Okay, so you would need to rotate it another 2mm so that both markings on the flywheel align. I hope that makes sense.
Temperature: 22° C
Fuel consumption while idling without air conditioning: 0.7 liters.
DZR Time: average 6.19 s. According to DZR, this corresponds to an increase in performance of 13.8%, and 148 PS and 352 NM.
Trip 2: Setting 1/3 hole at the northwest position, early timing, which corresponds to approximately 11 mm before TDC (Top Dead Center) on the flywheel (~4.5° BTDC - Before Top Dead Center)
Temperature: 24°C
Fuel consumption at idle without air conditioning: fluctuating between 1.0 liters and 1.1 liters.
DZR Time: average 6.02 s
According to the DZR, this corresponds to an increase in power of 17.06%, and a power output of 151.8 horsepower and 360 Nm of torque.
Someone should try to tell me that this is useless!
Setting 2 is probably a bit milder than the extremes I mentioned in a few previous responses, as it only uses 1.1 to 1.3 liters at idle.
Regarding the noise levels of the PDEs, I couldn't detect any deviation with this setting.
The torque peak now has less of a pronounced "peak" and starts around 1900 RPM, and subjectively decreases less sharply than before, more like a gently sloping plateau.
I really like this setting, so I'm going to keep it for now to see how much the consumption changes!
Mfg, loveme
Post04-09-2004, 15:46    Subject: Adjusting NW / Boundary PDEs after tuning Quote
So, you would need to rotate it another 2mm so that both
markings on the disc align, I hope that makes sense.
Okay, I don't understand... if KW is aligned with OT, then what markings are still separated by a distance of 2 mm?
1. 148 HP, 352 Nm.
2. 151.8 horsepower and 360 Nm of torque.
Someone should try to tell me that it's useless!
It seems to be roughly the same as the continuation of my adjustment experience: on average, about 2 horsepower more with a 3° KW earlier setting.
The torque peak now has less of a "peak" characteristic, but it starts around 1900 RPM and subjectively decreases less than before, so it's more like a slightly sloping plateau.
So, it appears that the subjective characteristics of the engine can be varied.
"Lagging = significant power boost around 2000 rpm, but then it falls off at higher RPMs."
"Early torque means less low-end power, but better performance at higher RPMs and slightly more power in the mid-range."
The question is, what proportion of that is due to the change in valve timing... unfortunately, you can't just adjust the injection camshaft.
Regarding the noise level of the PDEs, I couldn't detect any deviation whatsoever with this setting!
I like this setting very much, so I will keep it for now to see to what extent the consumption changes!
Okay, I will occasionally provide the translation.
And thank you for your "basic research." If you don't mind, I will incorporate the results into the technical article on PD-NW settings.
loveme
Post04-09-2004, 17:04    Subject: Adjusting NW / Boundary PDEs after tuning Quote
loveme wrote the following::
The reading on the timing wheel is 2mm before the mark in the direction of rotation, which exactly corresponds to the precise timing setting achieved using the timing pin on the crankshaft pulley!
So, you would need to rotate it another 2mm so that both markings on the disc align. I hope that makes sense.
Okay, I don't understand... if KW is on top of OT, then what other markings have a distance of 2 mm between them?
It's actually quite simple:
I noticed that the timing mark on the crankshaft pulley, when viewed through the inspection hole in the gearbox casing with the timing cover removed, is offset by 2mm from the mark on the flywheel.
The discrepancy is between the marking on the flywheel and the marking on the inspection window in the gearbox, where the rubber stopper is located.
I believe that the setting value using the dowel pin on the crankshaft is more accurate than this notch on the flywheel!
That's why, when I'm doing adjustments where the timing belt cover isn't completely removed, I simply use that exact adjustment position (2mm before the marking) visible through the inspection hole in the crankshaft pulley.
It's actually simpler.
The most important thing is to be 100% on time!
P.S.: Feel free to continue using my test results!
Mfg, loveme
No new posts Oil proliferation in the ASZ. Incorporate PDEs and images Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 10Cent Tuning Technical Articles
No new posts Tuning: Pay attention to intake manifolds and intercooling Technical Articles
No new posts MFA nach Eco-Tuning On-Board Diagnostics (OBD)
No new posts _DEFINE0_ Wassertemperatur nach Tuning _DEFINE1_ Diesel Engine Technology
No new posts Leistung nach Tuning BKD 2.0TDI 16V On-Board Diagnostics (OBD)
No new posts Schlechterer Motorwirkungsgrad nach Tuning? Diesel Engine Technology
