Pressure Setpoints for Gas Compressors
Felix1991
Post13-08-2022, 8:39    Subject: Pressure Setpoints for Gas Compressors Quote
Hello.
I have an Audi A6 Quattro with a 2.5 TDI engine, the engine code is AKE.
Can anyone tell me the target values for crankcase pressure when measuring with the oil dipstick?
Translated on 13-08-2026, 1:42.
Karma: +647 / -0   Thank you, like it!
dieselschrauber likes this.
Post13-08-2022, 15:42    Subject: Pressure Setpoints for Gas Compressors Quote
Hi there!
I think it's around 5 millibars.
Are there any problems?
Translated on 13-08-2026, 1:43.
Felix1991
Post13-08-2022, 20:53    Subject: Pressure Setpoints for Gas Compressors Quote
I noticed some leaks, and there's oil around the crankcase gasket. I measured approximately 1 mbar on the dipstick tube.
"I'm experiencing intermittent power loss below 1800 RPM."
Are you referring to 5 mbar as the maximum overpressure? I thought there should be some negative pressure, or am I mistaken?
Translated on 13-08-2026, 1:44.
No new posts Target values for 6-cylinder engines. VP AYM Technical Data
No new posts PD ARL Setpoints: Values and Optimization Diesel Engine Technology
No new posts ASZ Setpoints: Values and Configuration On-Board Diagnostics (OBD)
No new posts ABS, no pressure Diesel Engine Technology
No new posts T4 Engine MKB: Target Values & Specs Diesel Engine Technology
