Resetting the service interval display / maintenance interval display on Audi vehicles.
Current vehicles, new VCDS versions:
Current versions of VCDS already have a built-in assistant for resetting service intervals, see:
Assistant for service delays
Control units with diagnostics via UDS require the manual reset of the corresponding channels in the instrument cluster.
Service delay via UDS
General information regarding service delays or Service interval display:
This article is by Bertil, thank you very much!
Audi vehicles with a fixed service interval,
valid for:
A4 1997>
A6 -C4 (old Audi 100)
A8 1994-1995
A8 1995-2000 from software version D08
The inspection data is stored in channels 05, 06, 07, and 08.
In control unit 17 (instrument cluster). The individual channels mean the following:
| | Channel 05OIL | Channel 06Service OIL | Channel 07Service IN01 | Channel 08Service IN02 |
Value| | Distance in1000 km or 1 km | Distance in1000 km or 1 km | Remaining time in10 or 1 days | Remaining. Time in 10 or 1 days |
A4 to 97A6 -C4 old (Audi 100) A8 from D08 | 00015 | 00030 | 00036 | 00073 |
A8 to D08| | 15000 | 30000 | 00365 | 00730 |
Simply select the corresponding channels in this table, enter the adjustment value, and save.
Oil change service every
15000 km
. Reset channel 05 + 06.
Inspection every
12 months
. Reset channels 05, 06 + 07.
Inspection service every
30000 km
. Channel 05, 06, 07 + 08 reset
valid for:
A3 97-99 up to serial number 8LYA 000000
A4 98-99 up to serial number 8DYA 000000
A6 98-99 up to serial number 4BYN002888
with fixed service interval
| | Channel 02Service OIL Service OEL | Channel 02Service IN | Channel 02Service OIL & Service IN |
Value| | Oil change serviceevery 15000km | Inspection every12 months | Inspection serviceevery 30000km |
A3, A4, A6| | 00010 | 00001 | 00000 |
R) Vehicles with optional fixed/flexible service interval display from model year 1999/2000:
Valid for:
A2 from introduction
A3 Model Year 99 from chassis number 8LYA000001
A4 Model Year 99 from chassis number 8DYA000001
A4 B6 new, Allroad, Cabriolet
A6 Model Year 00 from chassis number 4BYN002888
A8 Model Year 00 from chassis number 4DYN000181
The flexible interval takes into account: | | Oil quality Time | Mileage | Driving style | |
The fixed interval takes into account: | | Time | Mileage | Resetting the service event: | |
Channel
02
Meaning 00001=Service due| | Adjustment value | during service
00000=Service| | By resetting the display in channel 2, a fixed service interval is automatically set. (15000 / 30000 / 12 months) |
If conventional engine oil was used during the service, this setting is sufficient. If a long-life service was performed, the vehicle must be adjusted to the oil quality according to the table below: | |
Channel 42Min. Running until
next
oil change
LongLife
Diesel/Gasoline
not applicable for LL | Channel 43 | Running until next oil change LongLife Diesel Channel 43 Running until | next oil change 6-cylinder Diesel LongLife Channel 43 Running until | next oil change LongLife Gasoline Channel 43 Running until | next oil change not LongLife Diesel/Gasoline | Channel 44 Time until next oil change Longlife Channel 44 Time until next | oilchsel no Longlife Channel 45 | Approved oil qualityLL Diesel 3/4 cylinder engine Oil according to VW standard 50600(TDI) 50601(PD) Channel 45 | Approved oil qualityLongLife Diesel 6 cylinder engines Channel 45 Used. Oil quality. LongLife gasoline oil according to VW standard | 50300. Channel 45
not | LongLife.
Value | Distance to1000km Distance to1000km |
Distance to1000km| | Distance to1000km | Distance to1000km | Time in days Time in days | Encoding | Encoding Encoding | Encoding | | A2 | 00015 | 00050 | 00035 |
00030 | 00015 | 00730 | 00365 | 00004 | 00003 | 00002 | 00001 | | A3 | 00015 | 00050 | 00035 |
00030 | 00015 | 00730 | 00365 | 00004 | 00003 | 00002 | 00001 | | A4-B5 | 00015 | 00050 | 00035 |
00030 | 00015 | 00730 | 00365 | 00004 | 00003 | 00002 | 00001 | | A6 | 00015 | 00050 | 00035 |
00030 | 00015 | 00730 | 00365 | 00004 | 00003 | 00002 | 00001 | | A4-B6 | 00015 | 00050 | 00035 |
00030 | 00015 | 00730 | 00365 | 00004 | 00003 | 00002 | 00001 | | Allroad | 00015 | 00050 | 00035 |
00030 | 00015 | 00730 | 00365 | 00004 | 00003 | 00002 | 00001 | | Convertible | 00015 | 00050 | 00035 |
00030 | 00015 | 00730 | 00365 | 00004 | 00003 | 00002 | 00001 | | TT + | Roadster | 00015 | 00050 | 00035
00030 00015 | 00730 | 00365 | 00004 | 00003 | 00002 | 00001 | | Attention:
After the LL inspection, the initial value displayed is the minimum interval, which gradually increases over time to reach the target LL value. This happens depending on the driving profile. | | | |
