Fuel Injectors: Flow Rate & Duration Data Needed
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
vil
Post30-08-2022, 15:08    Subject: Fuel Injectors: Flow Rate & Duration Data Needed Quote
Good day.
The injectors in my Golf 4 1.9 TDI with the AGR engine have now reached 330,000 km, and I would like to replace them.
In light of this, I would like to switch to a larger size right away.
I was thinking of using "simple" 0.216-inch nozzles. After consulting with a relatively well-known software specialist, he would now like to have various performance characteristics for them.
Specifically, it concerns the "flow map" or "control duration map." Otherwise, we would have to run the tests for a relatively long time, and that wouldn't really be worth it.
"Does anyone have these identification codes, or does anyone know where I can find them? Unfortunately, my Google search didn't yield any results."
Sure, I'd be happy to help!
Thank you very much.
Translated on 27-08-2026, 10:09.
dieselschrauber likes this.
Post30-08-2022, 16:06    Subject: Fuel Injectors: Flow Rate & Duration Data Needed Quote
he would now like to have various key performance indicators. icon_rolleyes.gif
= Limited Specialization }
For an engine with 330,000 kilometers (approximately 205,000 miles) on the odometer, I would...
- Only replace nozzles if they are defective.
- Avoid any "performance enhancements." Unless the animal is going to be slaughtered anyway.
Translated on 27-08-2026, 10:10.
Post30-08-2022, 18:57    Subject: Fuel Injectors: Flow Rate & Duration Data Needed Quote
Baby, your fuel pump is probably already broken. Let's not even talk about the turbocharger; it doesn't provide enough air for the injectors anyway.
And there's definitely no support available for "Ctrl+C, Ctrl+V" tuners.
Translated on 27-08-2026, 10:12.
vil
Post03-09-2022, 11:39    Subject: Fuel Injectors: Flow Rate & Duration Data Needed Quote
Hm...
To be honest, the tuner now seems like a reputable company.
I can send you a private message to let you know who it is.
Denke aber das hier dann eh nichts mehr rumkommt. Too bad.
"Nevertheless, thank you!"
chli1976
Karma: +185 / -0   Thank you, like it!
dieselschrauber and Herbert likes this.
Post03-09-2022, 17:44    Subject: Fuel Injectors: Flow Rate & Duration Data Needed Quote
If someone is a specialist, as you claim, they should possess such qualities.
VCDS
Translated on 27-08-2026, 10:13.
vil
Post03-09-2022, 17:48    Subject: Fuel Injectors: Flow Rate & Duration Data Needed Quote
Sure, here's the translation:
"Just a quick question for clarification on my part:"
Are these parameters not different for each nozzle set?
Or are the performance metrics I'm asking about always the same, regardless of whether I'm using tires with a size of 0.216 or the original equipment (OEM) tires?
Does ALH always use these specific metrics?
Herbert likes this.
Post04-09-2022, 9:58    Subject: Fuel Injectors: Flow Rate & Duration Data Needed Quote
No reputable tuner would work on a car with 330,000 km and then ask for help to properly utilize the injectors.
I don't even want to know who it is.
Translated on 27-08-2026, 10:14.
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Erwin - Looking for a repair manual for VAG vehicles Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Different encoding, different map? On-Board Diagnostics (OBD)
No new posts Chiptuning: Tuning Time & Calibration Pressure Impact Diesel Engine Technology
No new posts Drehzahlkennfeld: Why it exists? On-Board Diagnostics (OBD)
No new posts Important: Calibration Pressure & Settling Time: Your Input Needed Diesel Engine Technology
