VW T6, rear shock absorbers - replacement / weak performance (Solution)
Post29-07-2022, 16:46    Subject: VW T6, rear shock absorbers - replacement / weak performance Quote
Some T6 models come from the factory with rear shock absorbers that have inadequate damping.
It is important not to confuse inadequate testing with a shock absorber test stand. VW describes the issue in document 2010609/13. The shock absorbers are designed to provide damping primarily at larger deflections, which can give the impression of limited damping.
However, if there are significant differences between the rear right and left shock absorbers, or if the vehicle has very high mileage and the overall damping performance has decreased, then replacing the shock absorbers may be a worthwhile investment.
Replacing the shock absorbers with aftermarket parts is straightforward. It is recommended to tighten the mounting screws of the shock absorber units only when the suspension is compressed, so that the sleeves in the rubber elements of the mounting points are not constantly twisted. They might then be more prone to premature cracking.
The torque specifications for the screws are as follows:
- Top: VAG part number N10209605, tighten from 25Nm to 75Nm, then rotate a further 180°.
- Below are VAG part numbers N10585602 and N10240304. Tighten to 150 Nm and then rotate a further 90°.
 File size:  182.43 KB
 Viewed:  1582 times
Ratings - VW T6, rear shock absorbers - replacement / weak performance
No new posts P0420 - Catalytic converter system, Bank 1, efficiency to... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B6 Rear Door Won't Unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Weak AHU Performance: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts LLC Effects: Some Mysteries Unveiled? Diesel Engine Technology
No new posts Shock Absorber Condition at 241,000 km Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Suspension and Shock Absorbers Transmission, Chassis, Body & Interior
