Injector Nozzle Damage: Causes & Repair
Peter1027
Karma: +0 / -1   Thank you, like it!
Post06-01-2023, 21:50    Subject: Injector Nozzle Damage: Causes & Repair Quote
Hello!
"On my 2.0 TDI BPW engine, the tappets that contact the rocker arm shaft are broken on two of the cylinders."
The setting was definitely correct.
What could be the cause of this?
Sure, here's the translation:
"Thank you in advance!"
Peter.
Translated on 23-10-2026, 8:06.
Post06-01-2023, 21:58    Subject: Pumpe Düse Stößel Bruch Quote
Hi.
Peter1027 wrote:
Hello!
"On my 2.0 TDI BPW engine, the tappets that contact the rocker arm shaft are broken on two of the valves."
Best regards, Peter
Mileage? I also experienced this with a PD element, which also failed at the same time. icon_cool.gif
/garage.php?mode=view_own_vehicle&CID=109
It might have been around 280,000 km.
Translated on 23-10-2026, 8:07.
Peter1027
Post06-01-2023, 22:08    Subject: Injector Nozzle Damage: Causes & Repair Quote
I installed new injector nozzles in the pre-combustion chambers and drove for a while without any problems, until two of them broke.
Translated on 23-10-2026, 8:08.
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Timing Chain Wear: Inspection & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Injector Pump GRA Calibration Diesel Engine Technology
No new posts Pump-nozzle Diesel Engine Technology
No new posts Pump Nozzle Problem AXR - Common Issue? Diesel Engine Technology
No new posts TDI Passat: 85 kW Pump Düse - Power Loss? Diesel Engine Technology
