Injektor: Positive or Negative Values?
Peter59
2008 Audi A6 Avant
Post12-03-2023, 10:04    Subject: Injektor: Positive or Negative Values? Quote
Hello to all diesel enthusiasts,
question about the values of the injectors, must they be negative or positive! I haven't been able to find anything about it anywhere, could you help me further?
A6 2.7 BPP Engine 1/2008
Measurement block
072 to 1. 10ms, to 2. 2ms, to 3. 6ms,
073 to 1. 10ms, to 2. 0ms, to 3. 2ms,
074 to 1. 16ms, to 2. 8ms, to 3. 8ms,
075 to 1. 6ms, to 2. 4ms, to 3. 8ms,
076 to 1. 14ms, to 2. 4ms, to 3. 6ms,
o77 to 1. 4ms, to 2. 0ms, to 3. 6ms,
These are the values displayed to me when the engine is cold, with the ignition on, only.
Question: Are the values good, or bad? Burnt or leaking?
While some believe that a minus sign should be added before every number, others feel that everything is already in the right place.
I would appreciate any news or comments.
No new posts Injector calibration with VCDS Troubleshooting & Guides
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
This topic is locked, you cannot edit or reply. Replacing injector(s) on a Volvo V70 D5 185? Yes or no? Diesel Engine Technology
No new posts Parameter Injector PDE On-Board Diagnostics (OBD)
No new posts CR Injector Failure: Common Causes & Solutions Diesel Engine Technology
No new posts 1.6 TDI Injector Base Adjustment Small Quantity Deviation Diesel Engine Technology
