Saugrohrklappe beim 3.0 TDI Euro6?
Heiner111
Karma: +27 / -0   Thank you, like it!
Post21-03-2023, 15:41    Subject: Saugrohrklappe beim 3.0 TDI Euro6? Quote
hello, now that I have to go to the TÜV, I have the following problem with the A5 3.0 TDI (Euro6 from 2016): the error memory indicates that the intake valve bank 1 is stuck. This is actually an old problem, and I also know roughly how it looks on the old 2.7/3.0 and where they are located. However, on the "new" Euro 6, I can't find anything of that kind on either bank. Is it perhaps sealed off, e.g. under the valve cover (which I can hardly imagine)? I would almost say that the valve doesn't exist here anymore, at least not on either bank. But I can't find a central valve for all 6 cylinders yet, like in the old 2.5 TDI...
Who knows this engine better and can provide more information?
Thank you in advance.
Karma: +808 / -0   Thank you, like it!
Post21-03-2023, 19:23    Subject: Saugrohrklappe beim 3.0 TDI Euro6? Quote
Please provide the error codes from the engine control unit.
Best regards, Rainer
Heiner111
dieselschrauber likes this.
Post21-03-2023, 21:36    Subject: Saugrohrklappe beim 3.0 TDI Euro6? Quote
gerne, hier der Log:
all 3 errors relate to the suction valve, which I can't find....
Address 01: Engine Electronics (J623-CKVC) Label file: None
Part Number SW: 8K5 997 401 B HW: 4G0 907 401 E
Part: 3.0TDI EDC17 H14 0003
Revision: 58H14--- CVN: F8D6D60A15D91B8D755A21130E1FC39E
Encoding: 22254012046603030000
Operating Number: WSC 10627 005 1048576
ASAM Dataset: EV_ECM30TDI0118K5997401B 001003
ROD: EV_ECM30TDI0118K5997401B.rod
VCID: 38788ABC839F5049BD-806C
VINID: 9D196AAAA21625678004004408CBB73687
3 error codes found:
5107 - Bank 1 Sonde 1
P0133 00 [237] - Signal too slow
Warning light ON - confirmed - checked since last discharge
Environmental Conditions:
Error Status: 00000001
Error Priority: 2
Frequency of Errors: 9
Odometer: 103805 km
Date: 2023.02.17
Time: 07:21:13
Motor Speed: 1020.00 /min
Normalized Load Value: 0.0 %
Vehicle Speed: 42 km/h
Coolant Temperature: 42 °C
Intake Air Temperature: 2 °C
Ambient air pressure: 1000 mbar
Voltage Terminal 30: 14.380 V
Fault Counter via OBD: 40
Airflow: Actual Value (mg/cycle): 167.2 mg/cycle
Average Injection Volume: 0.00 mg/stroke
Lambda Sensor 1 Bank 1: Status Check O2 Signal Bits 0-7: 1
Lambda Sensor 1 Bank 1: Raw O2 Signal Voltage: 835.6 mV
Lambda Sensor 1 Bank 1: Voltage of the Ri-Signal: filtered: 1013.4 mV
Lambda Sensor 1 Bank 1: Sensor Heater Ratio: 39.28 %
LSU r O2 Adap 0: 0.14668
9129 - Airflow Control Valve, Bank 1
P2006 00 [096] - closed
Sporadisch - unconfirmed - checked since last deletion
Error Priority: 2
Kilometerstand: 103405 km
Date: 2023.02.05
Time: 16:27:00
Motor Speed: 0.00 /min
Vehicle Speed: 0 km/h
Coolant Temperature: 77 °C
Intake Air Temperature: 3 °C
Voltage Terminal 30: 12.140 V
Airflow: Actual Value (mg/cycle): 0.0 mg/cycle
Suction Pipe Valve for Airflow Control: Operation: 100.00 %
Intake Valve for Airflow Control: Feedback: 43.12 %
Airflow control valve: Offset closed: 0.00 %
Airflow Control Valve: Offset Open: 0.00 %
Saugrohr Valve Actuator for Airflow Control: Status Bits 0-7: 0
Saugrohr Valve Actuator for Airflow Control: Status Bits 0-7: 55
Saugrohr Valve Actuator for Airflow Control: Status Bits 0-7: 4
9130 - Suction tube valve for airflow control Bank 1
P2004 00 [096] - open
Error Priority: 2
Frequency of Errors: 5
Odometer: 103478 km
Date: 2023.02.07
Time: 18:20:04
Voltage Terminal 30: 12.120 V
Fault Counter via OBD: 37
Intake Valve for Airflow Control: Feedback: 107.97 %
Readiness: 1 1 0 0 0
Post22-03-2023, 19:31    Subject: Saugrohrklappe beim 3.0 TDI Euro6? Quote
The two intake valve flaps for air flow control appear to be located after the throttle valve and are electrically actuated.
So, there should be one on each intake manifold, with a control motor on the outside, at each intake manifold.
Why don't you search the web for the VAG part number "059129711" (as an example), then you'll find a lot of pictures of it.
Could you please try to take a picture of the engine with the engine cover removed?
Heiner111
Post23-03-2023, 19:15    Subject: Saugrohrklappe beim 3.0 TDI Euro6? Quote
"Thank you, but I'm familiar with the older version, even if only vaguely. I would have easily found the valves there. However, it looks completely different for me. I just took a few pictures. Actually, there are 2 control valves in a row at the very front of the air duct, so centrally for all cylinders. I hadn't noticed them a few days ago because they were so far from the cylinder head." I have also added 2 images of the expanded part from the internet.
One of the two is likely the valve of the pharynx. But which one - and what does the other do?
The notification regarding "Bank1" also caused me some concern. Most likely, after the construction change, they simply deleted the control for the former Bank 2 flap, and the new central flap now also displays the error code for the former Bank 1, and is also incorrectly named "Bank1" in VCDS.
So: Does anyone know which of the two flaps it is? Unfortunately, I can't see any part numbers there either, which I could use to search. And I can't get into a parts catalog anymore, since 7zap is no longer accessible. There, the naming would probably be helpful.
 File size:  25.99 KB
 Viewed:  680 times
 File size:  53.59 KB
 Viewed:  1072 times
 File size:  945.38 KB
 Viewed:  1112 times
 File size:  882.64 KB
 Viewed:  535 times
 File size:  1 MB
 Viewed:  1186 times
 File size:  1.08 MB
 Viewed:  1350 times
Post23-03-2023, 21:21    Subject: Saugrohrklappe beim 3.0 TDI Euro6? Quote
If you disconnect the two potentially relevant connectors and turn on the ignition, you should be able to identify which one corresponds to which in the error memory.
Ich_Can_nix
Karma: +253 / -0   Thank you, like it!
Post23-03-2023, 22:09    Subject: Saugrohrklappe beim 3.0 TDI Euro6? Quote
Good evening, Heiner111,
To the right of the oil filter is the intake valve, and the other valve is the throttle valve.
Solution: Clean the flap, then check the position sensor/suction nozzle flap for plausibility/function.
Best regards
Michael
Heiner111
Post23-03-2023, 22:23    Subject: Saugrohrklappe beim 3.0 TDI Euro6? Quote
Thank you already for the tips. This will help me further. Just now, I thought of something: can the switches in the menu be controlled?
I will contact you.
Post24-03-2023, 12:19    Subject: Saugrohrklappe beim 3.0 TDI Euro6? Quote
Heiner111 wrote:
Thanks for the tips. This will help me further. Just now, I thought of something: can the switches in the menu be controlled?
I will get back to you
Likely, the test function in the engine control unit (ECU) using VCDS is what's being referred to.
Heiner111
Post29-03-2023, 19:10    Subject: Saugrohrklappe beim 3.0 TDI Euro6? Quote
hello again, problem found and (so far) solved! However, first, let's talk about troubleshooting. As the good tips above indicate, the intake valve is located in the middle of the engine, and the other one (when viewed from the front) is the throttle valve. What's unclear to me is why this (unlike other TDI engines) needs 2 similar valves in series. In between is only the introduction of the EGR (which I'll explain later). Since the A5 diagnostic process for the control unit is also selective (unlike the software in the B6/B7), it can be conveniently controlled, and you can then hear (of course, the engine must be turned off).
To access the intake valve, you must remove the entire intake pipe: 3 screws M6 T30 below the brackets/measuring pipe; one of them is barely visible and points upwards. And then the 4 long (5mm Allen key, M6), which go through the housing of the intake valve into the distributor. By the way: I always get a little nervous when I write about this intake pipe, especially since it's related to a turbocharged engine. These pipes don't actually suck in air (unlike the "turbo-free" intake diesel/petrol engine). Remove the two clips for the AGR and the fuel hose, as well as pull out the connectors of both valves.
Finally, loosen the screw under the cover to release the holder and "voilà", it's all done icon_smile.gif. I have a size 10 glove, and I can't find my little wrench, so I'm a bit frustrated - but it still works somehow.
At first glance, everything was clear (see pictures): thick layers of soot in the pipe, valve, and distributor, up to almost 10 mm thick, and oily and greasy. It's a miracle that the valve was even able to function. And it had only 105,000 km on the odometer. I haven't seen this much soot in the AGR valve of my old 2.0 TDI before (those are notorious for it).
Further forensic investigations then showed that the AGR pipe is almost completely free. And this raises the suspicion that the problem is, once again, due to Audi's own design (as with so many others). Of course, some oil vapor always comes through the intake pipe, which was already the case with all TDI engines and should be known to Audi. Especially if you also suck the KG ventilation system with it. And I dare to say that, in this particular example, there is even less oil coming with the air compared to my two older cars and my previous Golf 3. This inevitably leads to oil and soot sticking directly after the intake of the AGR. I can imagine what it looks like inside the distributor itself. I strongly doubt that the airflow/distribution/turbulence is still functioning as it did on the test bench... I'm already relieved that the engine is still running. And I believe cleaning the distributor is almost impossible (possibly with ultrasound and sharp tools, etc.). Removing it would also be a major hassle. Or, this one produces significantly more soot instead of oil, likely due to frequent short trips. However, it should be able to. I could also imagine that the problem worsened after he received the Euro6 recall software update 2 years ago. Although it ran somewhat unevenly afterward, it wasn't really that bad before.
Okay, so far as possible cleaned and everything reassembled: The error is gone. Unfortunately, I now have error code P0133 (Lambda sensor value too slow). Perhaps something has become stuck. Hoping it will burn away icon_smile.gif
I would appreciate it if someone could share some more ideas for explaining the strong soot crust.
 File size:  869.68 KB
 Viewed:  1851 times
 File size:  1.09 MB
 Viewed:  1322 times
 File size:  967.57 KB
 Viewed:  1353 times
 File size:  1.23 MB
 Viewed:  433 times
 File size:  931.99 KB
 Viewed:  587 times
 File size:  925.81 KB
 Viewed:  708 times
No new posts P3135 - Airflow Control Valve: Exceeds Limit. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3138 - Airflow Control Valve: Control Difference Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Buy Cheap Euro6 Diesel Now, or Wait? Diesel Engine Technology
No new posts Throttle valve 2 for 3.0 V6 TDI Diesel Engine Technology
No new posts BLS intake flap Upload
No new posts ALH Intake Manifold Flap Problem & Fix Diesel Engine Technology
