WFS light fixture LT35 is burning
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Post30-04-2023, 10:59    Subject: WFS light fixture LT35 is burning Quote
Dear Sir or Madam,
"I am a large language model, trained by Google."
>> in an older camper van:
>> VW LT 35, Typ lt. Building, number 2D.
Year of construction: 1998.
>> Engine code: AHD
>> If a voltage drop occurs, the immobilizer control may be affected.
Attempts to clear this error code at a Volkswagen partner's workshop are...
>> Failed.
Is there a way to achieve this using your software?
>> Control units / Engine control units (ECUs)
>> Correct?
>> Best regards
"Good day, Mr. XXXXXXX,"
>> not the entry in the error memory that causes the flashing.
>> das Problem. Sondern der Grund des Fehlereintrags. "If the..."
"If the control unit is broken, no diagnostic tool will be able to help you."
>> This reason can be read using VCDS.
Rainer Kaufmann
> Hello Mr. Kaufmann,
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
THANK YOU VERY MUCH for the reply on Saturday!
The VW partner cannot access the engine control units with their diagnostic tools.
> access.
Unfortunately, even a "free workshop" using VCDS software couldn't resolve the issue.
> However, I couldn't see which version he tried to use.
> They are also control units from a Mercedes-Benz Sprinter.
Then I have another question.
> Das Womo geht in die Schweiz, zwei Stunden von ihnen. If you are a...
> I would like to offer the buyer the option of having a different control unit programmed as well.
> provide their contact information.
> Best regards
For vehicles with the LT (Type 2D), the engine control unit and immobilizer should be Volkswagen components, while all other control units should be Mercedes-Benz components.
"See the product description for the adapter; I had to look it up myself because the vehicle is quite old."
https://shop.dieselschrauber.org/en/adapter-obd2-vw-lt-mb-sprinter-p-51.php
(mechanical adapter pin configuration)
Accessing the two control units should not be a problem, provided that the wiring and control units are in good condition.
The corresponding diagnostic system would be:
https://shop.dieselschrauber.org/en/vcds-hex-v2-p-329.php
This could allow us to query the two control units about their operational status and any malfunctions they may have experienced.
Does the vehicle run? If the immobilizer is completely defective, it shouldn't be able to start (and should immediately shut off after an attempted start), unless it has been disabled in the engine control unit.
Rainer Kaufmann
Hello Mr. Kaufmann,
Thank you for the reply on Sunday!
The vehicle starts and runs perfectly! I'm very happy about that!
The control system only "reported" the issue after a voltage drop, and there were no startup problems.
Zu Beginn musste ich erst nachsehen, welchen Kontrolle da jetzt blinkt. The vehicle.
showed no limitations!
Sure! You can definitely post that in the forum!
I'm not the only one with this problem, but it's persistent, isn't it?
I already have two adapter cables; the VW dealer provided them.
Tried using the VW tester and "his" adapter cable on Friday.
The open workshop with my cable. The connector (VDSC) was also lit up green (if that's relevant?).
Unfortunately, without success.
Greetings
Thanks for reading. Does anyone have any other ideas? I suspect there might be an error in the WFS's fault memory, something like "control unit defective," but somehow it still manages to start...
Translated on 16-07-2026, 14:47.
No new posts Taillight for trunk lid is dim Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unstetige Beschleunigung LT35 On-Board Diagnostics (OBD)
No new posts Is it worthwhile to convert an LT35 from an AHD (102 hp) ... Diesel Engine Technology
No new posts ABS-Leuchte VW-GOLF III On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Airbags deaktiviert wenn Kontrollleuchte brennt ? On-Board Diagnostics (OBD)
