Hello everyone,
I had a leak in the power steering pneumatic system of my car, and I discovered that the pressure accumulator on the fuel cooler valve was defective.
I noticed that the valve is activated as soon as there is a vacuum, which means it's always activated whenever the engine is running. I haven't been able to find a matching solenoid valve.
Can someone explain how it works, or what happens if I simply block the valve in the actuated position? (I've already sealed the vacuum line).
VG
Rupert.
