Question about the fuel cooler control valve. 1.9 TDI PD (ATJ)
karlstein12
dieselschrauber likes this.
Post04-05-2023, 8:38    Subject: Question about the fuel cooler control valve. 1.9 TDI PD (ATJ) Quote
Hello everyone,
I had a leak in the power steering pneumatic system of my car, and I discovered that the pressure accumulator on the fuel cooler valve was defective.
I noticed that the valve is activated as soon as there is a vacuum, which means it's always activated whenever the engine is running. I haven't been able to find a matching solenoid valve.
Can someone explain how it works, or what happens if I simply block the valve in the actuated position? (I've already sealed the vacuum line).
VG
Rupert.
No new posts Timing Belt Tension: 1.9 TDI AHF Help Diesel Engine Technology
No new posts Fuel Cooler Quick Connector 3.0 TDI V6 2006 Upload
No new posts A4 Avant 8E PD 96kW Kraftstoffkühler undicht? Diesel Engine Technology
No new posts Strange behavior with LD-control valve On-Board Diagnostics (OBD)
