patmit
08-05-2023, 14:46 Subject: Speed Limit MAN TGE/Crafter |
Good morning, everyone,
has anyone already had experience with the speed limit on TGE/Crafter?
I am trying to activate a (reversible!) limit. The "IDE02248 - Individually adjustable maximum speed limit" adaptation channel seems plausible.
Currently, the speed in the channel is set to 300km/h. A change would require a login code.
Can anyone help me?
a) confirm that I am in the correct channel here and
b) Name the code?
Thank you.
Patrick
| Description: |
 Download |
| File name: |
Logs.zip |
| File size: |
21.64 KB |
| Downloaded: |
625 times |
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
patmit likes this. |
08-05-2023, 22:30 Subject: Speed Limit MAN TGE/Crafter |
Caution. All the HGB (German-language) tax calculators I am familiar with can only be adjusted downwards.
So from 300 km/h to 80 km/h. But not from 80 km/h to 120 km/h.
Before you do anything, make sure to check!
Best regards, Rainer
Profile PM WWW Garage |
patmit
10-05-2023, 7:30 Subject: Speed Limit MAN TGE/Crafter |
Hello Rainer,
yes, I have unfortunately also come across such information.
There are adjustment channels for both static and individual maximum speed limiting.
I was hoping that someone from the forum could shed some light on this.
At least, according to the MAN workshop, there is a possibility to set a limit that can be reversed.
Since the vehicle is not yet registered, I was hoping for a VCDS solution...
Greetings
Patrick
