MBtuning
24-04-2024, 17:38 Subject: Tiguan Coding: Error Code II-11 Fix |
Hi.
"Someone might be able to help me. After replacing some control units, the ABS lost its coding. When I try to access "Coding II-11" in VCDS, it's grayed out and unavailable. Unfortunately, I only work on Mercedes vehicles and don't really know much about this."
VW Tiguan 2013 TDI.
Translated on 29-07-2026, 7:52.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
24-04-2024, 21:34 Subject: Tiguan Coding: Error Code II-11 Fix |
VAG uses both long and "short" coding methods, which can be identified by the code itself. Long coding consists of a lengthy hexadecimal string. Short coding, on the other hand, is a decimal number that essentially adds together several bitmasks.
Use the other coding button on your diagnostic tool. If you hover the mouse cursor over the input field in VCDS, VCDS will display coding information for the respective control unit (if available).
It's best to use the coding from an old scan of the vehicle and not try to create it yourself.
Translated on 29-07-2026, 7:54.
Profile PM WWW Garage |
MBtuning
24-04-2024, 22:18 Subject: Tiguan Coding: Error Code II-11 Fix |
Thanks, Rainer, I'll give it a try.
Translated on 29-07-2026, 7:55.
MBtuning
25-04-2024, 11:15 Subject: Cannot be translated |
Hello Rainer,
Unfortunately, nothing is appearing for me. Any other ideas?
| Description: |
| File size: |
331.87 KB |
| Viewed: |
263 times |
25-04-2024, 18:36 Subject: Tiguan Coding: Error Code II-11 Fix |
Do you have the old/correct encoding? Where does the one shown in the Screenshot come from?
Did you read the message that you posted?
MBtuning
25-04-2024, 18:57 Subject: Tiguan Coding: Error Code II-11 Fix |
Okay, I've been working exclusively with Mercedes vehicles for about 30 years, and I think I know pretty much everything about them. But when it comes to Volkswagen, I'm completely clueless. X
My employee found something online, but it doesn't work. I can't use that, and I don't understand that message. I usually only work with Mercedes software, but my ex drives a VW, and unfortunately, I can't say no;-)
Translated on 29-07-2026, 7:56.
