Tiguan Coding: Error Code II-11 Fix
MBtuning
Post24-04-2024, 18:38    Subject: Tiguan Coding: Error Code II-11 Fix Quote
Hi.
"Someone might be able to help me. After replacing some control units, the ABS lost its coding. When I try to access "Coding II-11" in VCDS, it's grayed out and unavailable. Unfortunately, I only work on Mercedes vehicles and don't really know much about this."
VW Tiguan 2013 TDI.
Translated on 29-07-2026, 8:52.
Post24-04-2024, 22:34    Subject: Tiguan Coding: Error Code II-11 Fix Quote
VAG uses both long and "short" coding methods, which can be identified by the code itself. Long coding consists of a lengthy hexadecimal string. Short coding, on the other hand, is a decimal number that essentially adds together several bitmasks.
Use the other coding button on your diagnostic tool. If you hover the mouse cursor over the input field in VCDS, VCDS will display coding information for the respective control unit (if available).
It's best to use the coding from an old scan of the vehicle and not try to create it yourself.
Translated on 29-07-2026, 8:54.
MBtuning
Post24-04-2024, 23:18    Subject: Tiguan Coding: Error Code II-11 Fix Quote
Thanks, Rainer, I'll give it a try.
Translated on 29-07-2026, 8:55.
MBtuning
Post25-04-2024, 12:15    Subject: Cannot be translated Quote
Hello Rainer,
Unfortunately, nothing is appearing for me. Any other ideas?
 File size:  331.87 KB
 Viewed:  257 times
Post25-04-2024, 19:36    Subject: Tiguan Coding: Error Code II-11 Fix Quote
Do you have the old/correct encoding? Where does the one shown in the Screenshot come from?
Did you read the message that you posted?
MBtuning
Post25-04-2024, 19:57    Subject: Tiguan Coding: Error Code II-11 Fix Quote
Okay, I've been working exclusively with Mercedes vehicles for about 30 years, and I think I know pretty much everything about them. But when it comes to Volkswagen, I'm completely clueless. X
My employee found something online, but it doesn't work. I can't use that, and I don't understand that message. I usually only work with Mercedes software, but my ex drives a VW, and unfortunately, I can't say no;-)
Translated on 29-07-2026, 8:56.
No new posts FSE Premium Retrofit for Passat, Golf, Tiguan Troubleshooting & Guides
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Caddy: Onboard Network Coding Problem Solution Electrical Systems, Vehicle Electronics, Multimedia
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts Automatic Transmission Tiguan Diesel Engine Technology
No new posts VW Tiguan AD1: P0684 Error Code Explained Diesel Engine Technology
