Passat B7 FN3 brake, 16" to C60 17" conversion/reprogramming
Dracula
Post10-05-2024, 11:16    Subject: Passat B7 FN3 brake, 16" to C60 17" conversion/reprogramming Quote
Vehicle year of manufacture: 2012.
Engine: 2.0 TDI, CFGB with 170 horsepower.
Brake electronics control unit: J104 TRW 450M C2 (3AA-614-109.CLB)
Current coding: 0003513
Can anyone tell me the specific part numbers for the two brake calipers, FN3 (16", PR-1ZM, 312x25) and C60 (17", PR-1LA, 340x30)?
Then I could convert the old encoding.
I have only found these values for an MK60 microcontroller.
+0000001 = FS III 54 15" (PR-1ZF/1ZM/1ZC)
+0000002 = FN III 54 15"/16" (PR-1ZE/1LJ/1ZP/1ZD/1LL)
+0000008 = FRNG 57 17" (PR-1LK)
Unfortunately, I couldn't find any information about the TRW 450M C2.
The brake system on the rear axle should also be converted. From CII 38 (16", load rating 1KW, 282x12) to CII 41 (17", load rating 2EA, 310x22). If this is needed for coding.
 File size:  70.91 KB
 Viewed:  537 times
 File size:  117.83 KB
 Viewed:  575 times
 File size:  69.64 KB
 Viewed:  521 times
Post10-05-2024, 12:04    Subject: Passat B7 FN3 brake, 16" to C60 17" conversion/reprogramming Quote
Please perform another diagnostic scan of the vehicle.
Dracula
Post10-05-2024, 13:04    Subject: Passat B7 FN3 brake, 16" to C60 17" conversion/reprogramming Quote
Here is the car scan.
Thank you for your support.
Michael.
Log.txt
 File name:  Log.txt
 File size:  14.44 KB
 Downloaded:  561 times
Dracula
Post11-05-2024, 22:04    Subject: Passat B7 FN3 brake, 16" to C60 17" conversion/reprogramming Quote
Could it be that the TRW 450M C2 ABS control unit doesn't actually code the brake type?
I found a YouTube video with an older version of VCDS (20.4.2), and it has a coding guide for this component. And no brake type is being coded.
https://www.youtube.com/watch?v=4dhktLJiyO8
Does anyone have any idea why this coding help isn't showing up in my VCDS (version 23.11.0)?
 File size:  487.17 KB
 Viewed:  502 times
Post14-05-2024, 19:13    Subject: Passat B7 FN3 brake, 16" to C60 17" conversion/reprogramming Quote
It doesn't look good...
Ross-Tech wrote:
The ESP coding is a set of Engine/Transmission/Brakes which are not meant to be changed individually. The variant he is looking for was not available from the factory, as far as I can tell, therefore, there is no coding option available.
I would strongly advise against making this change, as the brake system will likely not perform ideally under extreme conditions, and there are no measures to check/certify the operation.
The ESP coding is a set of parameters for the engine, transmission, and brakes that should not be modified individually. The version he's looking for, as far as I know, wasn't available from the factory, which is why there's no way to unlock it.
I would strongly advise against making this modification, as the braking system is likely to not function optimally under extreme conditions, and there are no procedures in place for verifying or certifying its operation.
Dracula
Post17-05-2024, 6:12    Subject: Passat B7 FN3 brake, 16" to C60 17" conversion/reprogramming Quote
Hello Rainer,
Thank you for your reply.
I thought the engine/transmission/brakes configuration would be available in the all-wheel-drive version of the B7.
Can you tell me why the coding help isn't being displayed? Is it due to the version?
Michael.
Post17-05-2024, 11:19    Subject: Passat B7 FN3 brake, 16" to C60 17" conversion/reprogramming Quote
Dracula wrote:
Hello Rainer,
Michael
The letters at the end of the VAG part number belong to the VAG part number. You have a different control unit, and I can't tell you whether it will behave the same way as the one in the Screenshot.
If a label file exists for the control unit, it is likely that the coding information is not available.
Dracula
Post20-05-2024, 20:50    Subject: Passat B7 FN3 brake, 16" to C60 17" conversion/reprogramming Quote
Hello Rainer,
The file "3AA-614-109.clb" exists, and a device-specific single value is also displayed in the information box (+1024=TMPS active). Unfortunately, there is no more information available.
Can you determine the individual components that make up the code 0003513?
Greetings.
Michael.
Post21-05-2024, 5:54    Subject: Passat B7 FN3 brake, 16" to C60 17" conversion/reprogramming Quote
Dracula wrote:
Hello Rainer,
Greetings.
Michael
Hello, it will only display what is publicly known...
Dracula
Post24-05-2024, 17:23    Subject: Passat B7 FN3 brake, 16" to C60 17" conversion/reprogramming Quote
After some searching, I would say my encoding is composed as follows:
CFGB engine with manual transmission = 0xB9 = +185
ABS = +256
TPMS = +1024
Start/Stop = +2048
Please provide the German text you would like me to translate into English.
Sum = 3513
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Beetle Won't Accelerate: Brake Issue at 2500 RPM Diesel Engine Technology
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Passat 3B AFN: Lack of Low-End Power (Long) Diesel Engine Technology
No new posts Passat 3C: Raise Ride Height with Auto Leveling On-Board Diagnostics (OBD)
