Jo_T5
28-10-2024, 15:29 Subject: T5 CAAD ash value accidentally set to 0 |
Hello colleagues,
I was troubleshooting the aforementioned issue. Accidentally set the ash values of the DPF to 0 in the basic settings of the T5.
If I try to increase the mileage in the adjustment channels now, the program requires access permission.
How can I correct it?
Thank you and best regards, Jo.
T5 mit CAAD Maschine
4B mit AVF Maschine
Jo_T5
28-10-2024, 16:07 Subject: T5 CAAD ash value accidentally set to 0 |
I was able to fix it again by enabling the customization option!
4B mit AVF Maschine
Herbert Profi-Schrauber
dieselschrauber and Turbinchen likes this. |
28-10-2024, 16:11 Subject: T5 CAAD ash value accidentally set to 0 |
VCDS will show you a tooltip with the access code.
In the APK, you enter the actual mileage in thousands, so 155 represents 155,000 km. Don't be bothered by the fact that the input field shows "0" again; the ash content value will be adjusted accordingly.
Jo_T5
28-10-2024, 19:22 Subject: T5 CAAD ash value accidentally set to 0 |
Thank you very much, Herbert, for the explanation.
He told me that the ash content would be 0.8g for 80,000 km, which seemed a bit low to me.
Good evening!
4B mit AVF Maschine
