Good day, I'm having the following problem.
The fuel injection pump in my Audi A4 B6 (manufactured in 2004, 2.5 TDI engine code "BAU") was defective. I had a working fuel injection pump from a 2003 A4 with the engine code "AKE" that I wasn't using.
After installing the pump and programming the immobilizer, the following error message appears from the automatic transmission control unit (see car scan). The transmission is only shifting into 4th gear and reverse. Furthermore, there is an error message from the pump.
Could it be possible that the AKE pump is not compatible with the BAU system?
The AKE was a manual transmission car, while the BAU was an automatic.
Thank you in advance.
Thursday, August 22, 2024, 7:31:31 PM, 07236.
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x86.
VCDS Version: RKS 24.7.0.0
Data as of: 20240731 DS356.3
Company number: 666 12345 145288.
Mileage: Repair order: A4 B6
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 8E - Audi A4/S4/RS4 B6/B7 (2001 > 200http://shop.dieselschrauber.org/en
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 77 77
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Unit
Label file: DRV\059-907-401-AKE.clb
Part number: 8E0 907 401 J
Component: 2.5L V6 TDI G000SG 0006
Encoding: 02005
Operating number: WSC 12345
VCID: 2C5CBAD4DC1773F64F-4B18
Subsystem 1 - Part number: 00005059
Component: 130 106LC150_1.V79
WAUZZZ8E95A101957 AUZ6Z0D0382866
"1 error found:"
01318 - Control unit for fuel injection pump (J399)
34-10 - No error type detected - Intermittent.
Readiness: 0 0 X X X
Address 02: Transmission Label file: DRV\01V-927-156.lbl
Part number: 8E0 927 156 R
Part number: AG5 01V 2.5l TDI, Roadworthy certificate 2222.
Encoding: 00001
Operating Number: WSC 00000
VCID: 3D7A8790376DEA7EE8-5178
"1 error found:"
18249 - Motor/Transmission Control Unit.
P1841 - 35-00 - Variants do not match.
