Audi A4 B6 VP44 replaced, now showing code P1841
Hans Dampf
Karma: +9 / -0   Thank you, like it!
2013 Ford Galaxy
Post23-08-2024, 9:26    Subject: Audi A4 B6 VP44 replaced, now showing code P1841 Quote
Good day, I'm having the following problem.
The fuel injection pump in my Audi A4 B6 (manufactured in 2004, 2.5 TDI engine code "BAU") was defective. I had a working fuel injection pump from a 2003 A4 with the engine code "AKE" that I wasn't using.
After installing the pump and programming the immobilizer, the following error message appears from the automatic transmission control unit (see car scan). The transmission is only shifting into 4th gear and reverse. Furthermore, there is an error message from the pump.
Could it be possible that the AKE pump is not compatible with the BAU system?
The AKE was a manual transmission car, while the BAU was an automatic.
Thank you in advance.
Thursday, August 22, 2024, 7:31:31 PM, 07236.
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x86.
VCDS Version: RKS 24.7.0.0
Data as of: 20240731 DS356.3
Company number: 666 12345 145288.
Mileage: Repair order: A4 B6
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 8E - Audi A4/S4/RS4 B6/B7 (2001 > 200http://shop.dieselschrauber.org/en
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 77 77
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Unit
Label file: DRV\059-907-401-AKE.clb
Part number: 8E0 907 401 J
Component: 2.5L V6 TDI G000SG 0006
Encoding: 02005
Operating number: WSC 12345
VCID: 2C5CBAD4DC1773F64F-4B18
Subsystem 1 - Part number: 00005059
Component: 130 106LC150_1.V79
WAUZZZ8E95A101957 AUZ6Z0D0382866
"1 error found:"
01318 - Control unit for fuel injection pump (J399)
34-10 - No error type detected - Intermittent.
Readiness: 0 0 X X X
Address 02: Transmission Label file: DRV\01V-927-156.lbl
Part number: 8E0 927 156 R
Part number: AG5 01V 2.5l TDI, Roadworthy certificate 2222.
Encoding: 00001
Operating Number: WSC 00000
VCID: 3D7A8790376DEA7EE8-5178
"1 error found:"
18249 - Motor/Transmission Control Unit.
P1841 - 35-00 - Variants do not match.
Audi A4 AKE
Rüdi likes this.
Post23-08-2024, 19:00    Subject: Audi A4 B6 VP44 replaced, now showing code P1841 Quote
Yes, it might be possible to bypass the pump, but the simpler solution is to install the correct pump.
dieselschrauber likes this.
Post24-08-2024, 9:00    Subject: Audi A4 B6 VP44 replaced, now showing code P1841 Quote
The fuel injection pumps for the AKE and BAU engines should have the same part number - 059 130 106L or LX - which means they are essentially interchangeable.
Regarding the MSG error, there are some strange statements online about a "problem" that is triggered during the diagnosis.
The error in the GSG (presumably a technical term) should be described in more detail in the RLF (another technical term) document for the 01V, including the causes. I suspect there might be an incomplete adaptation of the ECUs (Engine Control Units).
No new posts VP44 fuel injector on Audi A6 AKN model drawing air, caus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Diesel Engine Technology
No new posts GSK Shares Traded: Analysis & Trends Diesel Engine Technology
No new posts Zylinderkopf AFN getauscht! Diesel Engine Technology
No new posts Unterdruckdose getauscht Upload
