Schmierpfote Schrauber
Joined: 07/31/2016 Posts: 93 Karma: +21 / -0 Location: Erfurt
25-11-2024, 20:34 Subject: NOX Bank1 P2200 - Electrical Fault |
Hello everyone,
I replaced the DPF (Diesel Particulate Filter) on my T6 CXHA engine at 314,000 kilometers.
After driving 140km, the MKL light illuminates. A fault code P2200, indicating an electrical issue with the NOX sensor bank 1, was found using VCDS 32137.
Is this the sensor located after the DPF, requiring a 22mm wrench?
How can I check the oxygen sensors using VCDS? Thank you for your help. Best regards, Wolfgang.
Profile PM Email |
Joined: 04/12/2002 Posts: 18138 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
25-11-2024, 21:35 Subject: NOX Bank1 P2200 - Electrical Fault |
I don't quite understand the problem.
Check the wiring harness/connector. If nothing is visible, clear the error codes, start the engine, and then gently wiggle or move each cable individually.
Then you can check the error memory to see if the problem is with the cable or the sensor itself.
Profile PM WWW Garage |
25-11-2024, 21:47 Subject: NOX Bank1 P2200 - Electrical Fault |
Hello Rainer,
Profile PM Email |
dieselschrauber and Herbert likes this. |
26-11-2024, 12:49 Subject: NOX Bank1 P2200 - Electrical Fault |
Hello everyone in the forum,
NOX sensor installed by Metzger.
T6 is running again.
Profile PM Email |
26-11-2024, 20:39 Subject: NOX Bank1 P2200 - Electrical Fault |
Schmierpfote wrote: | Hello to the forum,
Greetings Wolfgang |
Thank you for your feedback!
Was was the outage foreshadowed? And is the NOx reduction now working at an adequate rate?
dieselschrauber and Turbinchen likes this. |
26-11-2024, 20:51 Subject: NOX Bank1 P2200 - Electrical Fault |
Hello Rainer,
The DPF contained 128.8 grams of oil ash. The maximum load according to VCDS is 110 grams. No error messages were received.
Therefore, the DPF was replaced and the old sensors were reinstalled.
See my question in the forum on November 25, 2024, at 20:34.
Profile PM Email |
