Unlock GRA for Caddy SA 2.0 TDI
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
tinomerbach
Post21-03-2025, 8:30    Subject: Unlock GRA for Caddy SA 2.0 TDI Quote
Hello everyone!
I installed the MFL in my Caddy. The car didn't have GRA before. I replaced the steering column control unit including the turn signal lever with a GRA version and coded it into the steering wheel electronics. The GRA is not responding at all, neither on the lever nor on the MFL. However, the other buttons on the MFL are working (phone, volume, voice input). I couldn't use the search function because I get an error message that the server is overloaded. Does anyone have a tip for me? icon_rolleyes.gif
Translated on 13-07-2026, 16:58.
Post21-03-2025, 15:28    Subject: Unlock GRA for Caddy SA 2.0 TDI Quote
First, check the measured values from the steering column control unit and the engine control unit to see if the controls on the GRA (Gear Ratio Assistance) lever are functioning correctly.
The most common mistake is incorrect wiring.
Translated on 13-07-2026, 16:59.
No new posts Unlock/Enable the Audi A3's outside temperature display Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Towing Hitch Unlock: VW Golf 5 and Newer Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Caddy: Jerky Engine, G28 Sensor, Low Rail Pressure Diesel Engine Technology
No new posts Timing Belt Audi A3 8V1 & Golf 7 2.0 TDI Diesel Engine Technology
No new posts Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp e... Diesel Engine Technology
No new posts Activate AHK on Audi A4 B8 Electrical Systems, Vehicle Electronics, Multimedia
